RZB92DHFR-S250
RZB92DHFR-S250
    SULLINS
    SMD
    CONN PCI CARDEDGE FEMALE 184POS
RZB92DHFR-S250 数据手册
8 7 4 5 3 2 6 .500 12.70 .590 14.99 2.490 63.25 1 ITEM NO. QTY. DESCRIPTION 1 1 B92HN-A351 2 184 EZB-DHH 3 2 BOARD LOCK 1.645 41.78 DRAWING # REF 10132 10011 10131 F 2.400 60.96 F 1.550 39.37 .070 1.78 .050 1.27 .150 3.81 .150 3.81 E E .370 9.40 5.040 128.02 .015 B .610 15.49 .300 7.62 INSERTION DEPTH .550 13.97 D D B BOARD LOCK FITS .096 HOLE .135 3.43 .570 14.48 4.910 124.71 SECTION B-B 49 POSITION 11 POSITION 32 POSITION C B A C NOTES: 1. THIS SPECIFICATION COVERS THE REQUIREMENT FOR A DUAL 92/184 ROW EDGECARD CONNECTOR 2. INSULATOR MATERIAL: POLYPHENYLENE SULFIDE. (BLACK) 3. CONTACT MATERIAL: PHOSPHOR BRONZE. 4. PLATING: .00001" GOLD ON CONTACT SURFACE .0001 INCH TIN/LEAD ON TERMINAL .00005 INCH NICKEL UNDERPLATE 5. TEMPERATURE: -65 C TO 125 C 6. UL FLAMMABILITY RATING: 94V-0 7. VOLTAGE RATING: 125 VDC MINIMUM AT SEA LEVEL. 8. CURRENT RATING: 1 AMP 9. VOLTAGE DROP: 30 MILLI VOLT AT RATED CURRENT 10. INSULATION RESISTANCE: 1000 MEGA OHM COMPUTER 11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART GENERATED DOCUMENT DO NUMBER AND DATE CODE. NOT CHANGE MANUALLY 12. BOARD THICKNESS ACCOMMMODATED: .054/.070[1.3716/1.7780] 13. BOARD INSERTION FORCE: 6 OUNCE AVERAGE PER CONTACT PAIR USING .062 [1.57]PCB PROPRIETARY AND CONFIDENTIAL 14. BOARD WITHDRAWL FORCE: 1 OUNCE MINIMUM PER CONTACT PAIR USING .062[1.57] PCB THIS DRAWING AND DESIGN IS THE 15. TOLERANCE: .005" UNLESS OTHERWISE NOTED. PROPERTY OF SULLINS ELECTRONICS. IT MAY NOT BE USED FOR ANY 16. MODIFICATION: PCI 64 BIT, 5 VOLT. 92 POSITION CONNECTOR WITHOUT GUIDE POST. PURPOSE OTHER THAN BY THE OWNER. SULLINS ELECTRONICS DOES NOT AUTHORIZE THE REPRODUCTION OR CONVEYANCE OF ANY INFORMATION CONTAINED HEREIN. 8 1 1 7 6 5 4 B A REV. 120 ORIGINAL RELEASE ECO NO. DESCRIPTION UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL 1/32 ANGULAR: 1 TWO PLACE DECIMAL .02 THREE PLACE DECIMAL .005 FOUR PLACE DECIMAL .0005 DATE NAME DRAWN 1/13/04 ARIA CHECKED 1/13/04 AJT COMMENTS: USED ON APPLICATION 3 MATERIAL NOTED FINISH N/A AN AJT DATE BY APPV'D SULLINS ELECTRONICS A PART NO./DESCRIPTION: RZB92DHFR-S250 INTERPRET GEOMETRIC TOLERANCING PER: NEXT ASSY 1/13/04 SIZE DWG. NO. C REV 10130 SCALE: 2:1 DO NOT SCALE DRAWING 2 A SHEET 1 OF 1 1
RZB92DHFR-S250 价格&库存
很抱歉,暂时无法提供与“RZB92DHFR-S250”相匹配的价格&库存,您可以联系我们找货
