RZB105DHAS
RZB105DHAS
    SULLINS
    CONN EDGE DUAL FMALE 210POS .050
RZB105DHAS 数据手册
8 7 REVISIONS B A PIN B1 PIN B2 REV. ECO. NO F 2791 H 3406 J 4243 .075 1.91 CARD SLOT SEE NOTE 13 2X DESCRIPTION REMOVED 'E' & 'H' MTL OPTION, ADD CONTACT GAP DIM. , UPDATED INSULATOR INNER WALL ON SECTION VIEW A-A & DWG FORMAT ADD 'M' MATERIAL OPTION, REVISE NOTE 15 ON CUSTOMER DWG TO 1/2 OZ (was 1 OZ), UPDATE INSPECTION FORMAT ON PRODUCTION DWG, UPDATE PROCESSING TEMP FOR ALL MATERIALS, ADD PIN CALL OUT TO CUSTOMER DWG TABULATE ALL POSITIONS C 1/28/14 JH 3/22/2016 MG 8/10/2020 JH F E .300 7.62 INSERTION DEPTH .360 9.14 .595 15.10 .915 23.24 3 X .100 2.54 D .041 1.04 A _ _B_ _DHAD _ _B_ _DHBD SECTION A-A SCALE 3 : 1 A PIN A1 C .040 1.02 MIN .050 1.27 PIN A2 C .104 2.64 FOR R MOUNTING .100 2.54 3 X .100 2.54 .410 10.41 D HA = .100±.025 2.54±0.64 HB = .170 .025[4.32 0.64] F B BY +.005 +0.13 .370 - .015 9.40 - 0.38 .030 0.76 A .250 6.35 DATE .125 3.18 .050 1.27 TYP E 1 2 3 E D PIN A2 PIN A1 1ST POSITION INDICATOR F 4 5 6 .150 3.81 .050 1.27 NOTES: F 2X .125 3.18 1. INSULATOR MATERIAL: SEE PART NUMBER CODING PIN B1 FOR S & A MOUNTING 2. CONTACT MATERIAL: SEE PART NUMBER CODING D PIN B2 3. PLATING: SEE PART NUMBER CODING RECOMMENDED PCB LAY0UT 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING COMPONENT SIDE 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 300 VAC 8. CURRENT RATING: 1 AMP UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX DIMENSIONS ARE IN INCHES [MM] 9/25/08 ASK 10. INSULATION RESISTANCE: 5000 MEGA OHMS TOLERANCES: TITLE 11. DURABILITY: 500 CYCLES MINIMUM EDGECARD, .050 CC, RAB ANGULAR: 1 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE PART NUMBER DECIMALS _ _B_ _D(HA, HB)_ 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] .XX= .02 [.5] .XXX= .005 [.13] CAGE CODE DWG. NO. SIZE 14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE .XXXX= .0005 [.013] C 54453 C10091 RoHS COMPLIANT 15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE SHEET 1 OF 3 SCALE: 3:1 B CUSTOMER COPY A Pb 8 7 6 5 4 THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. 3 2 1 A REV J FILE NAME: C10091, _ _B_ _D(HA,HB)_ 8 7 4 5 6 1 2 3 D 2X #4-40 THREADED INSERTS F F E E _ _B_ _DHAT _ _B_ _DHBT C D D 2X D .125 3.18 .485 12.32 .410 10.40 _ _B_ _DHAN _ _B_ _DHBN C _ _B_ _DHAS _ _B_ _DHBS 2X BOARD LOCK C F .174±.010 4.41±0.25 B B D .485 12.32 2X #4-40 THREADED INSERTS (FARSIDE) .410 10.40 Pb A _ _B_ _DHAA _ _B_ _DHBA RoHS COMPLIANT 8 7 6 .150 3.81 _ _B_ _DHAR _ _B_ _DHBR 5 4 CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 9/25/08 ASK TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE EDGECARD, .050 CC, RAB PART NUMBER SIZE C 2 _ _B_ _D(HA, HB)_ CAGE CODE 54453 SCALE: 2:1 3 A DWG. NO. C10091 SHEET 2 OF 3 1 REV J FILE NAME: C10091, _ _B_ _D(HA,HB)_ 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 9/25/08 ASK TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE EDGECARD, .050 CC, RAB PART NUMBER SIZE C 2 _ _B_ _D(HA, HB)_ CAGE CODE 54453 SCALE: 4:1 3 A DWG. NO. C10091 SHEET 3 OF 3 1 REV J FILE NAME: C10091, _ _B_ _D(HA,HB)_
RZB105DHAS 价格&库存
很抱歉,暂时无法提供与“RZB105DHAS”相匹配的价格&库存,您可以联系我们找货
