8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
E
2536
UPDATE PROCESSING FOR "N" MTL
3/30/2012
JH
F
2740
REMOVE 'NYLON 46' MATERIAL OPTION
04/24/2013
LH
H
3463
ADD NOTE 15
06/06/2016
LH
F
C
1.73±0.08 .068±.003
A
10.00 .394
PIN #A1
IDENTIFIER
E
1.50 .059
1.00 .039 TYP
1.50 .059
PIN A1
7.50 .295 MAX.
E
8.85 .348
PIN B1
11.65 .458
14.50 .571
3.75 .148 MAX.
0.90 .035
D
1.50 .059 MAX.
CL
B
A
7.00 .276
D
1.80 .071
4.40 .173
7.80 .307
3.75 .148
10.25 .404 MAX.
3.00 .118
0.80 .031
2.50 .098
4.10 .161
A
C
1.70 .067
1.00 .039
2X 1.60 .063
1.50 .059
0.34 .013 TYP
1.50 .059
16.30 .642
SECTION A-A
2.50 .098
2X
18.80 .740
8.60 .339
2.30 .091
2.00[.079]
1.20 .047
2X 1.80 .071
C
5.00 .197
2X 6.50 .256
D
2 X 1.70 .067
B
A
B
1.78 .070
NOTES:
1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0, COLOR: BLACK.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 1.1 AMPS PER CONTACT.
5. VOLTAGE RATING: 50 VAC/DC.
6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 30 MILLI OHMS MAX.
8. DIELECTRIC WITHSTANDING: 500 VAC.
9. OPERATING TEMP.: -10 C TO + 85 C.
10. PROCESSING TEMP.: 260 C FOR 10 SEC. MAX.
11. BOARD THICKNESS ACCOMMODATED: 1.57mm 0.13[.062 .005]
12. INSERTION FORCE: 117.3g(1.173 N) MAX PER CONTACT PAIR USING A 1.70mm (.067") STEEL CARD.
13. WITHDRAWAL FORCE: 15.31g(0.153 N) MIN PER CONTACT PAIR USING A 1.44mm (.057") STEEL CARD.
14. CAP NEEDS TO BE ON DURING IR REFLOW PROCESS TO PREVENT WARPAGE.
15. MATERIAL CODE "N" EQUIVALENT TO "G".
8
7
6
5
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN MM[INCHES]
TOLERANCES:
ANGULAR:
3
.X= .35 [.014]
.XX= .25 [.010]
.XXX= .080 [.0031]
DRAWN
DATE
NAME
07/07/09
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PCI E, 1.00mm[.039"] CC, STRADDLE, CLIPS
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
2
G_E_ _DHRQ-T941
DWG. NO.
11042
SHEET 1 OF 2
1
REV
H
FILE NAME: 11042, G_E_ _DHRQ-T941
A
8
7
4
5
6
CL
1
2
3
X
F
F
1.90±0.06 .075±.002
1.00 .039
PIN B11
PIN B1
E
B
8.40 .331
MIN.
0.70±0.05 .028±.002
1.50 .059
2.40 .094
PIN 'C'
SEE TABLE
16.30 .642
1
E
2X 4.80 .189
W
1.50 .059
PIN B 'N+11' 1
0.50[.020]x45 TYP
10 SPACES @1.00 [.039] EACH
1.90±0.05 .075±.002
'N' SPACES @1.0[.039] EACH=E
12.15 .478
10.00 .394
0.70±0.05 .028±.002 TYP
F
2.00 .079
2X
I/O PANEL DIRECTION
PRIMARY (COMPONENT) SIDE
D
V WX L
0.05[.002] L
3.20 .126
PIN B12
5.60 .220
2
0.10[.004] L
D
6.00 .236 MIN. 5.00 .197
2X2.50 .098
PIN A11
2.40 .094
PIN A1
1.00 .039
A
4X0.5[.02] X 45
PIN A12
PIN A 'N+12'
19.40 .764
PIN A1
D
2X 3.10 .122
3.20 .126
C
C
1.40 .055
20.0°±5°
1.57±0.13 .062±0.000
ACROSS PADS
I/O PANEL DIRECTION
SECONDARY (SOLDER) SIDE
V
DETAIL B
SCALE 8 : 1
RECOMMEND OF PCB DIMENSIONS
TOLERANCE: .XX 0.13[ .005]
B
1. NO TIE BAR PERMITTED FROM CARD EDGE TO LEADING EDGE OF PAD FOR PINS A1 AND 'C'.
PIN B1
B
1.40 .055
1.57±0.13 .062±.005
2. CHAMFER EDGE MUST BE FREE OF CUTTING BURRS.
DRAWN
Pb
A
TOLERANCES:
ANGULAR:
RoHS COMPLIANT
8
7
6
5
4
3
.X= .35 [.014]
.XX= .25 [.010]
.XXX= .080 [.0031]
DATE
NAME
07/07/09
JH
TITLE
PART NUMBER
SIZE
C
3
G_E_ _DHRQ-T941
CAGE CODE
54453
DWG. NO.
REV
11042
H
SCALE: 2:1
SHEET 2 OF 2
2
1
FILE NAME: C:\Users\LHsu.SEC\Desktop\DWG 11042-H\11042, G_E_ _DHRQ-T941 PRINT: 12/5/2016
A
很抱歉,暂时无法提供与“GWE49DHRQ-T941”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+42.391741+5.51079
- 10+36.0255210+4.68320
- 25+33.7659125+4.38946
- 50+32.1531450+4.17981
- 100+30.61711100+3.98013
- 250+28.70038250+3.73096
- 500+27.33110500+3.55296
- 1950+24.830681950+3.22791
