8
7
4
5
6
1
2
3
REVISIONS
F
D
C
A
REV.
ECO. NO
DESCRIPTION
DATE
BY
F
3177
UPDATE DWG FORMAT, UPDATE INSERT
INSTALLATION IN 'V' MOUNTING
3/10/2015
MG
H
3182
UPDATE GAP FROM PIN TO BODY TO .050 FROM .030
4/23/2015
MG
J
3613
ADD S2196, REMOVE 'A' MATERIAL, ADD 'Q' MATERIAL,
UPDATE 'R' MATERIAL OPERATING TEMPERATURE,
REMOVE 'Y' & 'S' PLATING
2/2/2017
EP
F
+.005
+0.13
.370
9.40
- .015
- 0.38
E
E
2X
.100 2.54
B
.125 3.18 THRU
FITS EDGECARDS THAT
ACCEPT .062[1.57] PCB'S
A
D
.540±.010 13.72±0.25
.030 0.76
.250 6.35
MA = .100±.025 2.54±0.64
MV = .130 .025 [3.30 0.64]
MB = .180 .025 [4.57 0.64]
MD = .250 .025 [6.35 0.64]
MJ = .500 .025 [12.70 0.64]
MK = .560 .025 [14.22 0.64]
D
.050±.010 1.27±0.25
C
.025 0.64
STD = .150 3.81 ROW SPACING
S189 = .200 [5.08] ROW SPACING
A
_ _C_ _M_ _D
_ _C_ _M_ _D-S189
_ _C_ _M_ _D-S2196)
C
SECTION A-A
C
.125 3.18
USE FOR Z & V
MOUNTING ONLY
(SEE SHEET 2)
A
B
B
.145 3.68
.100 2.54
.043 1.09 MIN
.150 3.81 (FOR STANDARD)
.200[5.08] (FOR S189)
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
RECOMMENDED PCB LAYOUT
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
UNLESS OTHERWISE SPECIFIED: DRAWN
5. PROCESSING TEMP: SEE PART NUMBER CODING
DIMENSIONS ARE IN INCHES [MM]
6. UL FLAMMABILITY RATING: 94V-0
TOLERANCES:
7. OPERATION VOLTAGE: 700 VAC
8. CURRENT RATING: 3 AMP
ANGULAR: 1
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
DECIMALS
.XX= .02 [.5]
10. INSULATION RESISTANCE: 5000 MEGA OHMS
.XXX= .005 [.13]
11. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
.XXXX= .0005 [.013]
RoHS COMPLIANT
12. MODIFICATION: SEE PART NUMBER CODING
CUSTOMER COPY
A
Pb
8
7
6
5
4
DATE
NAME
02/05/08 MNH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
3
TITLE
A
MALE, RIGHT ANGLE BEND, .100 CC
PART NUMBER
_ _C_ _M_ _(MA,MV,MB,MD,MJ,MK)_-(S189,S2196)
SIZE
C
CAGE CODE
54453
SCALE: 4:1
2
DWG. NO.
C11052
SHEET 1 OF 3
1
REV
J
FILE NAME: C11052, _ _C_ _M(MA,MV,MB,MD,MJ,MK)_ -(OMIT,S189,S2196)
8
7
4
5
6
E
C
2X #4-40
THREADED
INSERTS
F
1
2
3
F
E
E
_ _C_ _M_ _N
_ _C_ _M_ _N-S189
_ _C_ _M_ _N-S2196
D
_ _C_ _M_ _T
_ _C_ _M_ _T-S189
_ _C_ _M_ _T-S2196
D
C
C
C
C
2X
.125 3.18
.125 3.18
B
B
.125 3.18
2X #4-40
THREADED
INSERTS
_ _C_ _M_ _Z
_ _C_ _M_ _Z-S189
_ _C_ _M_ _Z-S2196
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
_ _C_ _M_ _V
_ _C_ _M_ _V-S189
_ _C_ _M_ _V-S2196
6
5
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 3:1
3
A
2
DWG. NO.
C11052
SHEET 2 OF 3
1
REV
J
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C11052
SHEET 3 OF 3
1
REV
J
