8
7
REVISIONS
B
A
PIN B1
PIN B2
REV.
ECO. NO
F
2791
H
3406
J
4243
.075 1.91
CARD SLOT
SEE NOTE 13
2X
DESCRIPTION
REMOVED 'E' & 'H' MTL OPTION, ADD CONTACT GAP DIM. ,
UPDATED INSULATOR INNER WALL ON SECTION VIEW A-A
& DWG FORMAT
ADD 'M' MATERIAL OPTION, REVISE NOTE 15 ON
CUSTOMER DWG TO 1/2 OZ (was 1 OZ), UPDATE
INSPECTION FORMAT ON PRODUCTION DWG, UPDATE
PROCESSING TEMP FOR ALL MATERIALS, ADD PIN CALL
OUT TO CUSTOMER DWG
TABULATE ALL POSITIONS
C
1/28/14
JH
3/22/2016
MG
8/10/2020
JH
F
E
.300 7.62
INSERTION DEPTH
.360 9.14
.595 15.10
.915 23.24
3 X .100 2.54
D
.041 1.04
A
_ _B_ _DHAD
_ _B_ _DHBD
SECTION A-A
SCALE 3 : 1
A
PIN A1
C
.040 1.02 MIN
.050 1.27
PIN A2
C
.104 2.64
FOR R MOUNTING
.100 2.54
3 X .100 2.54
.410 10.41
D
HA = .100±.025 2.54±0.64
HB = .170 .025[4.32 0.64]
F
B
BY
+.005
+0.13
.370 - .015 9.40 - 0.38
.030 0.76
A
.250 6.35
DATE
.125 3.18
.050 1.27 TYP
E
1
2
3
E
D
PIN A2
PIN A1
1ST POSITION
INDICATOR
F
4
5
6
.150 3.81
.050 1.27
NOTES:
F
2X .125 3.18
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
PIN B1
FOR S & A MOUNTING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
D
PIN B2
3. PLATING: SEE PART NUMBER CODING
RECOMMENDED PCB LAY0UT
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
COMPONENT SIDE
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 300 VAC
8. CURRENT RATING: 1 AMP
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
DIMENSIONS ARE IN INCHES [MM]
9/25/08 ASK
10. INSULATION RESISTANCE: 5000 MEGA OHMS
TOLERANCES:
TITLE
11. DURABILITY: 500 CYCLES MINIMUM
EDGECARD, .050 CC, RAB
ANGULAR: 1
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
PART NUMBER
DECIMALS
_ _B_ _D(HA, HB)_
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
.XX= .02 [.5]
.XXX= .005 [.13]
CAGE CODE DWG. NO.
SIZE
14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
.XXXX= .0005 [.013]
C
54453
C10091
RoHS COMPLIANT
15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE
SHEET 1 OF 3
SCALE: 3:1
B
CUSTOMER COPY
A
Pb
8
7
6
5
4
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
3
2
1
A
REV
J
FILE NAME: C10091, _ _B_ _D(HA,HB)_
8
7
4
5
6
1
2
3
D
2X #4-40
THREADED INSERTS
F
F
E
E
_ _B_ _DHAT
_ _B_ _DHBT
C
D
D
2X
D
.125 3.18
.485 12.32
.410 10.40
_ _B_ _DHAN
_ _B_ _DHBN
C
_ _B_ _DHAS
_ _B_ _DHBS
2X BOARD LOCK
C
F
.174±.010 4.41±0.25
B
B
D
.485 12.32
2X #4-40
THREADED INSERTS
(FARSIDE)
.410 10.40
Pb
A
_ _B_ _DHAA
_ _B_ _DHBA
RoHS COMPLIANT
8
7
6
.150 3.81
_ _B_ _DHAR
_ _B_ _DHBR
5
4
CUSTOMER COPY
9/25/08 ASK
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
2
_ _B_ _D(HA, HB)_
CAGE CODE
54453
SCALE: 2:1
3
A
DWG. NO.
C10091
SHEET 2 OF 3
1
REV
J
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
9/25/08 ASK
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
2
_ _B_ _D(HA, HB)_
CAGE CODE
54453
SCALE: 4:1
3
A
DWG. NO.
C10091
SHEET 3 OF 3
1
REV
J
很抱歉,暂时无法提供与“RZB85DHAS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+217.8570925+28.06746
