8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
F
2868
UPDATE 'BOM' ON PRODUCTION DRAWING
11/26/2013
KV
H
3182
UPDATE DWG FORMAT, UPDATE INSERT
INSTALLATION IN 'V' MOUNTING
4/16/2015
MG
J
3652
REMOVE 'A' MATERIAL, ADD 'Q' MATERIAL, , UPDATE
'R' MATERIAL OPERATING TEMPERATURE, REMOVE
'Y' & 'S' PLATING
4/6/2017
EP
F
E
F
E
D
C
2X
A
.125 3.18
THRU
+.005
+0.13
.370
9.40
- .015
- 0.38
D
D
B
(.025 0.64 ) DEPTH
FROM TOP OF INSULATOR
TO TOP OF PIN
A
FITS EDGECARDS THAT
ACCEPT .062 1.57 PCB's
.540±.010 13.72±0.25
.250 6.35
C
C
.030 0.76
ACCOMMODATES
.062[1.57] PCB
A
.025 0.64
MR = .175±.025 4.45±0.64
MN = .545 .025[13.84 0.64]
.156 3.96
_ _M_ _M_ _D
SECTION A-A
B
A
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE:SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 950 VAC
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
8
7
6
5
CUSTOMER COPY
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
03/14/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
2
_ _M_ _M(MR,MN)_
CAGE CODE
54453
SCALE: 3:1
3
A
MALE, CARD EXTENDER, .156 CC
DWG. NO.
C11074
SHEET 1 OF 3
1
REV
J
FILE NAME: C11074, _ _M_ _M(MR,MN)_
8
7
4
5
6
1
2
3
F
F
2X #4-40
THREADED
INSERTS
E
C
E
E
_ _M_ _M_ _N
_ _M_ _M_ _T
D
D
2X
.125 3.18
C
C
C
C
2X
.125 3.18
.125 3.18
B
.125 3.18
B
2X #4-40
THREADED
INSERTS
_ _M_ _M_ _Z
_ _M_ _M_ _V
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
03/14/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
2
_ _M_ _M(MR,MN)_
CAGE CODE
54453
SCALE: 2:1
3
A
DWG. NO.
C11074
SHEET 2 OF 3
1
REV
J
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
03/14/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
2
_ _M_ _M(MR,MN)_
CAGE CODE
54453
SCALE: 2:1
3
A
DWG. NO.
C11074
SHEET 3 OF 3
1
REV
J
很抱歉,暂时无法提供与“EBM06MMRN”相匹配的价格&库存,您可以联系我们找货
