RZB92DHRN-S378
RZB92DHRN-S378
    SULLINS
    CONN PCI CARDEDGE FEMALE 184POS
RZB92DHRN-S378 数据手册
8 7 4 5 3 2 6 .500 .005 2.490 F 1 ITEM NO. QTY. DESCRIPTION DRAWING # REF 1 1 B92HN-A353 10120 2 184 E_B-DHH 10011 .590 F 1.645 1.550 .005 2.400 .005 .050 .070 .050 .075 CARDSLOT .060 E .124 E .124 5.040 .370 1 A .300 INSERTION DEPTH .758 D D A 49 POSITION SECTION A-A 32 POSITION 2 11 POSITION 3x .096 GUIDE POSTS C C .050 B A NOTES: 1. THIS SPECIFICATION COVERS THE REQUIREMENT FOR A DUAL CARD EXTENDER EDGECARD CONNECTOR. 2. INSULATOR MATERIAL: POLYPHENYLENE SULFIDE. 3. CONTACT MATERIAL: PHOSPHOR BRONZE. 4. PLATING: Z PLATING: .00001" GOLD ON CONTACT SURFACE .0001" TIN/LEAD ON TERMINAL .00005" NICKEL UNDERPLATE 5. TEMPERATURE: -65 C TO 125 C 6. UL FLAMMABILITY RATING: 94V-0 7. VOLTAGE RATING: 125 VDC MINIMUM AT SEA LEVEL. 8. CURRENT RATING: 1 AMP 9. VOLTAGE DROP: 30 MILLI VOLT AT RATED CURRENT 10. INSULATION RESISTANCE: 1000 MEGA OHM 11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND DATE CODE. COMPUTER GENERATED 12. BOARD THICKNESS ACCOMMMODATED: .054/.070 DOCUMENT DO NOT CHANGE 13. BOARD INSERTION FORCE: 6 OUNCE AVERAGE PER CONTACT PAIR USING .062 PCB MANUALLY 14. BOARD WITHDRAWL FORCE: 1 OUNCE MINIMUM PER CONTACT PAIR USING .062 PCB 15. TOLERANCE: .010" UNLESS OTHERWISE NOTED. PROPRIETARY AND CONFIDENTIAL 16. MODIFICATION: CARD EXTENDER BEND THIS DRAWING AND DESIGN IS THE PROPERTY OF SULLINS ELECTRONICS. IT MAY NOT BE USED FOR ANY PURPOSE OTHER THAN BY THE OWNER. SULLINS ELECTRONICS DOES NOT AUTHORIZE THE REPRODUCTION OR CONVEYANCE OF ANY INFORMATION CONTAINED HEREIN. 8 1 1 7 6 5 4 B A REV. 118 ORIGINAL RELEASE ECO NO. DESCRIPTION UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL 1/32 ANGULAR: 1 TWO PLACE DECIMAL .02 THREE PLACE DECIMAL .005 FOUR PLACE DECIMAL .0005 DATE NAME DRAWN 01/08/04 ARIA CHECKED 01/08/04 AJT COMMENTS: APPLICATION 3 FINISH AJT BY APPV'D A PART NO./DESCRIPTION: RZB92DHRN-S378 SIZE DWG. NO. MATERIAL USED ON AN DATE SULLINS ELECTRONICS INTERPRET GEOMETRIC TOLERANCING PER: NEXT ASSY 01/08/04 C N/A REV 10119 SCALE: 2:1 DO NOT SCALE DRAWING 2 A SHEET 1 OF 1 1
RZB92DHRN-S378 价格&库存
很抱歉,暂时无法提供与“RZB92DHRN-S378”相匹配的价格&库存,您可以联系我们找货
