GWE82DHRQ-T941
GWE82DHRQ-T941
    SULLINS
    P=1mm
    GWE82DHRQ-T941
GWE82DHRQ-T941 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY E 2536 UPDATE PROCESSING FOR "N" MTL 3/30/2012 JH F 2740 REMOVE 'NYLON 46' MATERIAL OPTION 04/24/2013 LH H 3463 ADD NOTE 15 06/06/2016 LH F C 1.73±0.08 .068±.003 A 10.00 .394 PIN #A1 IDENTIFIER E 1.50 .059 1.00 .039 TYP 1.50 .059 PIN A1 7.50 .295 MAX. E 8.85 .348 PIN B1 11.65 .458 14.50 .571 3.75 .148 MAX. 0.90 .035 D 1.50 .059 MAX. CL B A 7.00 .276 D 1.80 .071 4.40 .173 7.80 .307 3.75 .148 10.25 .404 MAX. 3.00 .118 0.80 .031 2.50 .098 4.10 .161 A C 1.70 .067 1.00 .039 2X 1.60 .063 1.50 .059 0.34 .013 TYP 1.50 .059 16.30 .642 SECTION A-A 2.50 .098 2X 18.80 .740 8.60 .339 2.30 .091 2.00[.079] 1.20 .047 2X 1.80 .071 C 5.00 .197 2X 6.50 .256 D 2 X 1.70 .067 B A B 1.78 .070 NOTES: 1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0, COLOR: BLACK. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 1.1 AMPS PER CONTACT. 5. VOLTAGE RATING: 50 VAC/DC. 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 30 MILLI OHMS MAX. 8. DIELECTRIC WITHSTANDING: 500 VAC. 9. OPERATING TEMP.: -10 C TO + 85 C. 10. PROCESSING TEMP.: 260 C FOR 10 SEC. MAX. 11. BOARD THICKNESS ACCOMMODATED: 1.57mm 0.13[.062 .005] 12. INSERTION FORCE: 117.3g(1.173 N) MAX PER CONTACT PAIR USING A 1.70mm (.067") STEEL CARD. 13. WITHDRAWAL FORCE: 15.31g(0.153 N) MIN PER CONTACT PAIR USING A 1.44mm (.057") STEEL CARD. 14. CAP NEEDS TO BE ON DURING IR REFLOW PROCESS TO PREVENT WARPAGE. 15. MATERIAL CODE "N" EQUIVALENT TO "G". 8 7 6 5 Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 3 .X= .35 [.014] .XX= .25 [.010] .XXX= .080 [.0031] DRAWN DATE NAME 07/07/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PCI E, 1.00mm[.039"] CC, STRADDLE, CLIPS PART NUMBER SIZE C CAGE CODE 54453 SCALE: 2:1 3 2 G_E_ _DHRQ-T941 DWG. NO. 11042 SHEET 1 OF 2 1 REV H FILE NAME: 11042, G_E_ _DHRQ-T941 A 8 7 4 5 6 CL 1 2 3 X F F 1.90±0.06 .075±.002 1.00 .039 PIN B11 PIN B1 E B 8.40 .331 MIN. 0.70±0.05 .028±.002 1.50 .059 2.40 .094 PIN 'C' SEE TABLE 16.30 .642 1 E 2X 4.80 .189 W 1.50 .059 PIN B 'N+11' 1 0.50[.020]x45 TYP 10 SPACES @1.00 [.039] EACH 1.90±0.05 .075±.002 'N' SPACES @1.0[.039] EACH=E 12.15 .478 10.00 .394 0.70±0.05 .028±.002 TYP F 2.00 .079 2X I/O PANEL DIRECTION PRIMARY (COMPONENT) SIDE D V WX L 0.05[.002] L 3.20 .126 PIN B12 5.60 .220 2 0.10[.004] L D 6.00 .236 MIN. 5.00 .197 2X2.50 .098 PIN A11 2.40 .094 PIN A1 1.00 .039 A 4X0.5[.02] X 45 PIN A12 PIN A 'N+12' 19.40 .764 PIN A1 D 2X 3.10 .122 3.20 .126 C C 1.40 .055 20.0°±5° 1.57±0.13 .062±0.000 ACROSS PADS I/O PANEL DIRECTION SECONDARY (SOLDER) SIDE V DETAIL B SCALE 8 : 1 RECOMMEND OF PCB DIMENSIONS TOLERANCE: .XX 0.13[ .005] B 1. NO TIE BAR PERMITTED FROM CARD EDGE TO LEADING EDGE OF PAD FOR PINS A1 AND 'C'. PIN B1 B 1.40 .055 1.57±0.13 .062±.005 2. CHAMFER EDGE MUST BE FREE OF CUTTING BURRS. DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] Pb A TOLERANCES: ANGULAR: RoHS COMPLIANT 8 7 6 5 4 3 .X= .35 [.014] .XX= .25 [.010] .XXX= .080 [.0031] DATE NAME 07/07/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PCI E, 1.00mm[.039"] CC, STRADDLE, CLIPS PART NUMBER SIZE C 3 G_E_ _DHRQ-T941 CAGE CODE 54453 DWG. NO. REV 11042 H SCALE: 2:1 SHEET 2 OF 2 2 1 FILE NAME: C:\Users\LHsu.SEC\Desktop\DWG 11042-H\11042, G_E_ _DHRQ-T941 PRINT: 12/5/2016 A
GWE82DHRQ-T941 价格&库存
很抱歉,暂时无法提供与“GWE82DHRQ-T941”相匹配的价格&库存,您可以联系我们找货
