DF19 Series
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board,
Micro-coaxial Cable-to-Board Connectors
Feb. 2021
DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors
Features
1. De Facto Standard for LCD
Panel Connection
2. Low Profile Design
Cable Connection
Cable, micro- coaxial type : 1. 5mm thickness
( 1. 6mm Max. )
FPC Type : 1. 7mm Max.
8.2
7.2
DF19G-#P-1H(52)
1.5
1.65
Cable
DF19G-#S-1C(05)
DF19A-2830 / 3032 / 36SCFA
PCB
FPC Connection
1.65
(1.7)
FPC
8.2
7.2
DF19G-#P-1H(52)
DF19G-#S-1F(05)
DF19G-#S-1F-GND(06)
3. Common Header
Cable Type
Header is compatible with the 3 socket types
( discrete wire, FPC and micro- coaxial types) , for
a wide selection of mating combinations.
(1.7)
DF19G-#S-1F(05)
+DF19G-#S-1F-GND(06)
(7.7)
(7.7)
DF19G-#S-1C(06)
DF19-#P-1V(52)
(0.78)
Cable, Micro-coaxial Type
1.3±0.2
DF19G-#S-1SD(06)
+DF19G-#S-1SD-GND
DF19-#P-1V(52)
4. Uniform External Dimensions
External dimensions of each socket type are the
same and can be used in a wide array of
applications.
2
PCB
FPC Type
1.5±0.1
(7.7)
DF19 has been accepted as the market standard
for LCD panels ( 12in. or less) due to its high
performance for LVD high speed differential
signals.
DF19-#P-1V(52)
5. Wide Varieties
Top-board Mounted
Header is available in top- board, offset, reverse
mount offset and vertical mounted styles to meet
a wide array of application needs.
Discrete Wire
Offset Mounted
FPC
Reverse Offset Mounted
Micro-coaxial Cable
Vertical Mounted
6. Ground Connection with
Outer Shell
Metal shell enables ground connection.
7. Glow Wire Compatible
( IEC60695- 2- 11 Standard)
Applications
Mobile phones, LCD connections, DVC, DSC, PDA, camera modules, and other small equipment
Micro-coaxial
Cable
DF19
FPC
Twisted
pair cable
Notebook PC
DF19
DF19
DF19
3
Product Specifications
Rated
Current
Ratings
28
AWG
30
AWG
32
AWG
36
AWG
FPC
Micro-coaxial
Cable
40 AWG
1A/
pin
0.9A/
pin
0.8A/
pin
0.5A/
pin
0.5A/
pin
0.3A/pin
Rated
Voltage
Operating Temperature (Note
1)
Operating Humidity Range
(Note 2)
Storage Temperature Range
(Note 3)
100V AC/DC
Storage Humidity Range
(Note 3)
-35 to
+85℃
40 to 80%
-10 to
+60℃
40 to 70%
Note 1 : Includes temperature rise due to current flow.
Note 2 : Please use without condensation.
Note 3 : Applicable to unused items in packaged state.
Item
Specification
Conditions
Insulation
Resistance
500M Ω Min.
100V DC
Withstanding
Voltage
No flashover or insulation breakdown.
300V AC for 1 min.
Contact Resistance
30m Ω Max. (50m Ω Max. for FPC)
1mA
Vibration
No electrical discontinuity of 1μ s or more.
Frequency : 10 to 55 Hz, single amplitude of 0.75mm, in 3
direction for 10 cycles
Humidity
(Steady State)
Contact Resistance : 30m Ω Max. (50m Ω
Max. for FPC)
Insulation Resistance : 500M Ω Min.
96 hours at temperature of 40 ± 2℃ and
humidity of 90 to 95%
Temperature Cycle
Max. for FPC)
Temperature : -55℃ → +5 to +35℃ → +85℃ → +5 to +35℃
Time (Minutes) : 30 → 10 → 30 → 10 for 5 cycles
Mating Durability
Max. for FPC)
30 cycles
Soldering Heat
Resistance
No deformation of the insulator parts affecting
performance.
Re-flow soldering : At the recommended temperature profile
Manual soldering : Soldering iron temperature 350℃ , 5
seconds
Materials / Finish
Product
Pin Header
Crimp Case
Socket Crimp Contact
FPC Socket
FPC Grounding Plate
Micro-coaxial Socket
Grounding Plate for Micro-Coaxial
Component
Material
Finish / Color
Remarks
Insulator
Polyamide
Black or Beige
UL94V-0
Contacts
Phosphor Bronze
Partially Gold Plated
Exterior Shell
Phosphor Bronze
Partially Tin Plated
Insulator
Polyamide
Beige
UL94V-0
Exterior Shell
Stainless Steel
Tin Plated
Contact
Phosphor Bronze
Gold Plated
Insulator
Polyamide
Beige
UL94V-0
Contact
Phosphor Bronze
Gold Plated
Exterior Shell
Stainless Steel
Tin Plated
Insulator
LCP
Beige
UL94V-0
Contact
Phosphor Bronze
Exterior Shell
Phosphor Bronze
Tin Plated
Exterior Shell
Phosphor Bronze
Tin Plated
4
RoHS2
〇
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Connector
DF19 # - # P - 1 H
❶
❷
❸ ❹
❺ ❻
DF19 # - # S - 1 F - GND
❶
❶
❷
❷
❸ ❹
❺ ❻
❼
Series Name
DF19
❸
No. of Pos.
8,14,20,30 (Note 1)
❹
Connector Type
S : Single Row Socket
P : Single Row Pin Header
❺
Contact Pitch
1.0mm
❻
Mounting Type/
Termination Type
Configuration
Pin Header
G : Top-board Mouted (1.65mm Height)
K : Offset Mounted (1.0mm Height)
L : Offset Mounted (1.1mm Height)
KR : Reverse Offset Mounted Version of
DF19K (1.0mm Height)
Crimp Socket
Blank : No Exterior Shell
G : With Exterior Shell
FPC Socket
G : With Grounding Plate
Grounding Plate for FPC
Grounding Plate for Micro-coaxial Cable
H:Right Angle SMT
V:Straight SMT
C:Crimp Case
F : FPC, Socket
SD:Micro-coaxial Socket
❼
Attachable Parts
GND : Ground plate (Note 2)
Note 1 : The pin count availabilities vary based on connection style.
Note 2 : Grounding plates are required when terminating with the FPC and Micro-coaxial cable.
■ Crimp Contact
DF19A - 2830 SCF A (##)
❶
❷
❸
❹
❶
Conductor Size
2830 : 28-30 AWG
3032 : 30-32 AWG
36 : 36 AWG
❸
Plating
A : Gold Plated
❷
Contact Type/
Packaging
SCF : Socket Contact, Reel
❹
Packaging
Blank : 10000pcs per reel
41 : 20000pcs per reel
5
Right Angle Pin Header (SMT) (Top-Board Mounted Type)
A
2.375
B
P= 1
2.175
4.7
2.45
0.25
2
Contact No. 1 Indicator
1.65
5.7
Recommended PCB Mounting Pattern
B±0.05
1.85±0.1
1.65±0.1
1+0.1
P=1±0.05
0.55±0.05
+0.1
2.5±0.05
1.1+0.1
Pictured mounted on board.
1.65
C
Note : If there is a pattern on the
the ground plate.
portion and resist is not applied, it may come into contact with
Unit : mm
HRS No.
No. of Pos.
A
B
C
Embossing
Width
DF19G-8P-1H(52)
CL0685-0021-0-52
8
11.55
7.0
11.95
24.0
DF19G-14P-1H(52)
CL0685-0004-0-52
14
17.55
13.0
17.95
44.0
DF19G-20P-1H(52)
CL0685-0006-6-52
19.0
23.95
44.0
DF19G-30P-1H(52)
CL0685-0015-7-52
30
33.55
29.0
33.95
44.0
Part No.
[Specifications] (52) : Gold plated, tape & reel packaging
[Purchase Unit] 1000pcs per reel
Note : When using in combination with the single row socket (FPC Type), mount on the edge of the PCB.
6
Remarks
1.65mm Height Above
Board
Right Angle Pin Header (SMT) (Offset Mounted Type)
A
2.375
B
2.175
0.25
4.7
2.45
P=1
1
6.7
F
C
F
1.46
2
DF19K Identification Mark
B±0.05
3.175±0.1
2.975±0.1
P=1±0.05
1+0.1
(2.2)
2.5 +0.1
5.3±0.1
0.3
1.5 +0.1
0.55±0.05
5.5±0.1
D+0.2
-0.1
E ±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
E
F
Embossing Width
DF19K-20P-1H(52)
CL0685-0008-1-52
19.0
26.55
24.15
25.15
1.0
44.0
DF19K-30P-1H(52)
CL0685-0032-6-52
30
33.55
29.0
36.55
34.15
35.15
1.0
56.0
DF19L-14P-1H(52)
CL0685-0003-8-52
14
17.55
13.0
20.55
18.15
19.15
1.1
44.0
DF19L-20P-1H(52)
CL0685-0019-8-52
19.0
26.55
24.15
25.15
1.1
44.0
DF19L-30P-1H(52)
CL0685-0016-0-52
30
33.55
29.0
36.55
34.15
35.15
1.1
56.0
7
Remarks
1.0mm Height Above Board
1.1mm Height Above Board
Right Angle Pin Header (SMT) (Reverse Offset Mounted Type)
A
2.375
B
2.175
0.25
2
4.7
2.45
P=1
1
6.7
3.175±0.1
2.975±0.1
B±0.05
P=1±0.05
1+0.1
1.5 +0.1
0.55±0.05
D
(2.2)
0.3
5.3±0.1
2.5
+0.1
5.5±0.1
C
1
1.46
1
+0.2
-0.1
E±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
E
Embossing Width
DF19KR-14P-1H(52)
CL0685-0024-8-52
14
17.55
13.0
20.55
18.15
19.15
44.0
DF19KR-20P-1H(52)
CL0685-0023-5-52
19.0
26.55
24.15
25.15
44.0
8
Remarks
1.12
1.07
Straight Pin Header (SMT)
P=1
0.95
0.25
B
1.3
1.56
5.22
A
1.96
3.8
1
A
0.25
2
+0.1
+0.1
0.65
2.5 0
2.2±0.05
P=1±0.05
注1
0.55±0.05
(E)
(F)
1.7+0.1
0.65±0.05
+0.1
+0
1.45
注1
+0.1
D±0.05
1.5+0
1.46±0.05
C
G±0.05
0.8±0.05
the ground plate.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
E
F
G
DF19-14P-1V(52)
CL0685-0036-7-52
14
17.9
13.0
15.25
14.95
6.675
6.325
13.0
DF19-20P-1V(52)
CL0685-0037-0-52
19.0
21.25
20.95
9.675
9.325
19.0
9
Single Row Socket (Cable Type)
DF19G-#S-1C(06)
DF19-#S-1C
A
P=1
Mark Every 5 Contacts
1.5
1.5
A
A
Shown with terminated and installed contacts
B
6.1
6.1
P=1
A
B
14
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF19-8S-1C
CL0685-0029-1-00
8
11.5
7.0
DF19-14S-1C
CL0685-0012-9-00
14
17.5
13.0
DF19-20S-1C
CL0685-0011-6-00
19.0
DF19-30S-1C
CL0685-0013-1-00
30
33.5
29.0
HRS No.
No. of Pos.
A
B
DF19G-8S-1C(06)
CL0685-0022-2-06
8
11.5
7.0
DF19G-14S-1C(06)
CL0685-0005-3-06
14
17.5
13.0
DF19G-20S-1C(06)
CL0685-0007-9-06
19.0
DF19G-30S-1C(06)
CL0685-0014-4-06
30
33.5
29.0
Purchase Unit
100pcs per bag
Unit : mm
Part No.
10
Purchase Unit
100pcs per bag
Socket Crimp Contacts
0.63
0.5
2
0.9
5.1
0.7
t=0.15
Unit : mm
Part No.
HRS No.
DF19A-2830SCFA(##)
CL0685-0048-6-##
DF19A-3032SCFA(##)
CL0685-0046-0-##
DF19A-36SCFA(##)
CL0685-0047-3-##
Packaging
Finish
Reel
Gold Plated
[Specifications] Blank : 10000pcs per reel / (41) : 20000pcs per reel
● Applicable
Cable (Tin Plated Annealed Conductor)
Wire Size (Stranded Wire Conductor)
Jacket Diameter
28 AWG (7 / 0.127mm)
30 AWG (7 / 0.1mm)
φ 0.5-0.6mm
32 AWG (7 / 0.08mm)
36 AWG (7 / 0.05mm)
● Recommended
φ 0.27mm
Wires : UL1571 Thin Wire Specification (Note 2)
Note 1 : Please contact a Hirose sales representative when using cables other than those specified.
Note 2 : Contact your Hirose sales representative when using 36 AWG.
● Strip
Length : 1.2-1.9mm
● Applicable
Tools
Part
Part No.
HRS No.
Applicator
AP105-DF19S
CL0901-4571-3-00
Press Unit
CM-105C
CL0901-0001-0-00
Note : Please perform crimping work in accordance with the "Crimp Quality Standard" (ETAD-H0945-00 and the "Crimp Condition Table".
Problems caused by tools other than those specified by our company are outside the scope of warranty.
11
Single Row Socket (FPC Type)
Note : Socket and grounding plate is
required.
A
B
C
5.95
P=1
A
1.2
CAV No.
Shown terminated with FPC.
D±0.08
0.45±0.3
0.2±0.1
2.2±0.05
0.2±0.15
0.7±0.03
t=0.145±0.03
グランド面< :はんだめっ
き1~5μm>
Ground
Area
: Solder Plating 1 to 5μm thickness.
.2
±0
.05
R0
0.05
0.05
0.35±0.03
E±0.05
R0.1
.2
MA
0.4±0.05
MAXR0
XR
0.2
( 0.35)
3.6
2 ±0.15
P=1±0.03
1.85±0.25
C±0.05
.2
0.35±0.25
0.3±0.15
R0
Contact Mark Indicator
0.3±0.15
Signal信号面< :はんだめっ
Area
: Solderき
Plating
1 to 5μm thickness.
1~5μm>
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
E
DF19G-14S-1F(05)
CL0685-0017-2-05
14
17.5
17.1
13.0
15.6
14.0
DF19G-20S-1F(05)
CL0685-0009-4-05
23.1
19.0
21.6
20.0
DF19G-30S-1F(05)
CL0685-0033-9-05
30
33.5
33.1
29.0
31.6
30.0
Note : When using in combination with the right angle pin header (Top Board Type), mount on the edge of the PCB.
12
Purchase Unit
100pcs per bag
Ground Plate for FPC
A
B
4.1
No. of Pos. Indicator
SIGNAL
1
4
1.5
C
D
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
DF19G-14S-1F-GND(06)
CL0685-0018-5-06
14
15.75
14.35
17.5
14.4
DF19G-20S-1F-GND(06)
CL0685-0010-3-06
20.35
23.5
20.4
DF19G-30S-1F-GND(06)
CL0685-0034-1-06
30
31.75
30.35
33.5
30.4
● Applicable
Assembly Tools
Type
Part No.
HRS No.
Desktop tool (for 14pos.)
DF19G-14S/PR-MD2
CL0902-4514-6-00
Desktop tool (for 20pos.)
DF19G-20S/PR-MD2
CL0902-4513-3-00
Desktop tool (for 30pos.)
DF19G-30S/PR-MD2
CL0902-4518-7-00
Note : Issues caused by tools other than those specified for Hirose are outside the scope of warranty.
13
Purchase Unit
100pcs per bag
3±0.1
0.7±0.05
0.9MAX
P=1
A
B
6.1
Contact
端子NO.1マ-ク
No. 1 Indicator
C±0.2
D±0.15
P=1±0.1
Inner
conductor
内部導体
Insulator
誘電体
Grounding
bar
金属バ-
スズコ-
ト1.2MIN
Solder Coat
1.2 Min.
Single Row Socket (Micro-coaxial)
外部導体
Outer Conductor
1.33
ジ
ャケット
Jacket
Shown terminated with micro-coaxial cable.
Note 1 : The pitch misalignment prevention tape can be connected without cutting, but please use a
durable material.
Note 2 : The inner conductor must be soldered in advance.
Note 3 : When using a two position coaxial line, there are some pin arrangements that cannot be used
due connector protrusion. Please check the official specifications.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
DF19G-14S-1SD(06)
CL0685-0026-3-06
14
17.4
13.0
14.8
13.0
DF19G-20S-1SD(06)
CL0685-0025-0-06
19.0
20.8
19.0
● Applicable
Cable (Micro-coaxial Cable)
Wire Size (Core Wire Configuration)
40 AWG (7 / 0.03mm)
Jacket Diameter
φ 0.3-0.4mm
14
Purchase Unit
100pcs per bag
4.36
1.27
A
Unit : mm
Part No.
HRS No.
No. of Pos.
A
DF19G-14S-1SD-GND
CL0685-0028-9-00
14
17.5
DF19G-20S-1SD-GND
CL0685-0027-6-00
15
Purchase Unit
100pcs per bag
Embossed Carrier Tape Dimensions (JIS-C-0806 Standard)
● DF19G-#P-1H(52)
● DF19K-#P-1H(52)
● DF19L-#P-1H(52)
12±0.1
2±0.1 4±0.1
G-G
1.75±0.15
t=0.3±0.1
G
2±0.5
φ1.5 Feed
Hole Depth
C±0.1
Part Number Label
1
D±0.3
φ2
H
H
H-H
E
+2
F
G
2.5±0.15
(2.3)
B±0.1
A±0.3
φ13
φ80
+0
0 .1
φ330
1.5
1.75±0.1
φ
Unreeling Direction
7.8±0.3
Unit : mm
Connector
No. of Pos.
A
B
C
D
E
F
8
24.0
11.5
16.1
24.4
30.4
DF19G-14P-1H(52)
14
44.0
40.4
20.2
22.1
44.4
50.4
DF19G-20P-1H(52)
40.4
20.2
28.1
44.4
50.4
DF19G-30P-1H(52)
30
56.0
50.2
26.2
38.1
56.4
62.4
DF19K-20P-1H(52)
40.4
20.2
28.1
44.4
50.4
DF19K-30P-1H(52)
30
56.0
52.4
26.2
38.1
56.4
62.4
DF19L-14P-1H(52)
14
44.0
40.4
20.2
22.1
44.4
50.4
DF19L-20P-1H(52)
40.4
20.2
28.1
44.4
50.4
DF19L-30P-1H(52)
30
56.0
52.4
26.2
38.1
56.4
62.4
DF19G-8P-1H(52)
16
Remarks
Top-board Mounted
(1.65mm Height)
Offset Mounted
(1.0mm Height)
Offset Mounted
(1.1mm Height)
● DF19KR-#P-1H(52)
0 .1
1.75±0.15
t=0.3±0.1
2±0.5
C±0.1
G
φ 80
Øφ13
φ2
1
H
E
G
2.85±0.15
+2
F
Unreeling Direction
H-H
(2.3 )
7.8±0.3
Unit : mm
Connector
No. of Pos.
A
B
C
D
E
F
Remarks
DF19KR-14P-1H(52)
14
44.0
40.4
20.2
22.1
44.4
50.4
DF19KR-20P-1H(52)
40.4
20.2
28.1
44.4
50.4
Reverse type of DF19K
Offset Mounted(1.0mm Height)
3.7±0.2
H
G
Unreeling Direction
φ1.5 Feed
Hole Depth
Ø13
1
H
2±0.5
t=0.4±0.1
φ80
φ380±2
4±0.2
G
Part Number
Label
E+20
F
Ø2
4±0.1
D±0.2
12±0.1
C±0.1
B±0.1
A±0.3
.1
+0 0
5
1.
2±0.1
1.75±0.1
● DF19-#P-1V(52)
φ
D±0.3
B±0.1
A±0.3
H
φ1.5 Feed
Hole Depth
Part Number Label
φ330
12±0.1
.5 +0
G-G
1.75±0.1
Ø1
Unit : mm
Connector
No. of Pos.
A
B
C
D
E
F
DF19-14P-1V(52)
14
32.0
28.4
14.2
18.2
32.4
38.4
DF19-20P-1V(52)
40.4
20.2
24.2
44.4
50.4
17
Remarks
Straight Type
Crimping Precautions
■ Items Required Prior to Crimping
The work- related documents shown below are required before starting harness assembly.
( The ● mark represents required documents. )
Please contact your Hirose sales representative if you do not have these documents.
Document Title
Description
Automatic
Crimping
Machine
Hand
Crimping
Tool
Remarks
Bundled with purchase of main
press machine unit.
① Crimping Machine Main
Unit Instruction Manual
Explanation of main press unit
② Applicator Instruction
Manual
Crimp Method
③ Applicator Spare Parts List
Applicator Installation Instruction
④ Crimp Conditions
Crimp height,
tensile strength standard value
⑤ Crimp Quality Standards
Various standards for crimping
conditions
⑥ Hand Tool Operating
Crimp method, crimp height and
Instructions
tensile height standard value
⑦ Cable Assembly
Cable assembly
applicator.
hand tool.
Contact a Hirose sales
representative.
■ Tools
・Use tools designated by Hirose when crimping.
・Crimping performed using tools other than those specified is outside the scope of warranty.
・The operating instructions are available for the crimping machine and the applicator. Be sure to carefully
read the operating instructions manual before beginning work.
■ Applicable Cables
Check that the cables to be used are within the applicable range.
If you intend to use a cable other than those recommended, contact a sales representative.
[ Precautions]
• Cables applicable to crimping connectors are tin- plated stranded soft- copper wire.
• Avoid crimping solid wire, wires with polyester threads or tin coated wires.
• Avoid crimping two cables together.
• The crimp height setting values ( Note 1) may vary between tin- plated and gold- plated terminals even if the
same electric wires are used.
• The crimp height setting values ( Note 1) may vary depending on the difference in the core wire configuration
even if the computed cross- sectional area is the same.
Note 1 : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value
for the crimp height with high precision, thereby ensuring optimal setup values.
18
Precautions
1. Recommended
Temperature Profile
Temperature (℃)
250℃
220
200℃
180
150℃
Preheating
Soldering
250℃
10s Max.
220℃ Min. 60s Max.
60 to 120s
100℃
50℃
30
100
50
150
200
Time(S)
Note 1 : Up to 2 cycles of reflow soldering are possible under the same conditions,
provided that there is a return to normal temperature between the first and second cycle.
Note 2 : The temperature profile indicates the temperature of the surface of the connector lead.
Note 3 : The color of the grounding plate may change color, although this does not affect
the product performance.
2. Recommended Manual
Soldering Conditions
Manual soldering : 350±10℃ for 5 seconds
3. Recommended Screen
Thickness
0.15mm
4. Board Warpage
Maximum of 0.03mm at the connector center, with both ends of the connector as
reference points.
5. Cleaning Conditions
Refer to “Wire-to-Board Connector Use Handbook.”
6. Termination Conditions
7. Cautions
■ Excessive prying during mating and unmating may result in damage.
8. Handling
Please refer to the following documents when handling the product.
■ Crimp Quality Standard(ETAD-H9045-00)
■ Wire-to-Board Connector Use Handbook
■ Cable Assembly Procedure (ETAD-H0963-00)
19
Single Row Socket (FPC Type) Assembly Method
Insert the FPC diagonally from the top surface of the grounding plate.
Pass the FPC through the grounding plate.
Step1
After passing the FPC through lower downwards.
Signal Surface
Step2
Ground Surface
Extend the FPC out and fully insert into the socket.
Step3
Step4
Assembly point: Slightly raise the FPC to an angle of about 30 degrees,
and then insert the grounding plate over the socket.
Using the dedicated installation tool, insert the
grounding plate.
1.7
Final
completion
Note 1 : The grounding plate and the socket are supplied as separate components.
Note 2 : Dedicated assembly tools are required for assembly.
Note 3 : When temporarily inserting the ground plate, the FPC can be easily inserted by lightly lifting the FPC up to 30°
and designing a self- alignment guide.
However, if excessive force ( bending, twisting, etc. ) is applied to the FPC, the FPC ( edge of the cover film)
copper foil may crack.
Note 4 : If the ground plate cannot be inserted, make sure it is aligned parallel to the socket and do not force it in.
Note 5 : To protect the FPC, insert and remove the connector parallel to the mating surface.
Note 6 : To protect the FPC, do not apply excessive tension.
Note 7 : Refer to the FPC manufacture recommended bending radius and other specifications. Distance should be allowed
for bending as shown below.
MIN 5
SIGNAL
MIN 10
Temporarily insert the grounding plate into the socket.
Note 8 : When terminating the FPC there is a risk of misuse of the tools, or injury from the ridge on the metal part of the
connector, etc. Follow the terminal tools instruction manual to ensure proper termination.
While taking in consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given.
Please consult with your Hirose sales representative if you are planning to use the product for any of the following
applications. ( Automotive, medical, public infrastructure, aerospace/ defense, etc. )
Hirose will consider the validity of the warranty depending on the conditions.
21
[ JAPAN ]
[ GERMANY ]
[ TAIWAN ]
Headquarters
GERMAN Branch / STUTTGART Office
TAIWAN Office
HIROSE ELECTRIC EUROPE B.V.
HIROSE ELECTRIC (TAIWAN) CO., LTD.
Phone : +81-45-620-7410
http://www.hirose.com
Phone : +49-711-456002-1
http://www.hirose.com/eu/
Phone : +886-2-2555-7377
http://www.hirose.com/tw/
NUREMBERG Office
[ U.S.A ]
US Headquarters / CHICAGO Office
HIROSE ELECTRIC ( U.S.A.), INC.
Phone : +1-630-282-6700
http://www.hirose.com/us/
SAN JOSE Office
Phone : +49-911-326889-63
Phone : +49-511-978261-30
[ FRANCE ]
SINGAPORE Office
HIROSE ELECTRIC SINGAPORE PTE. LTD.
PARIS Office
Phone : +1-734-542-9963
Phone : +33-1-85764886
DALLAS Office
[ ITALY ]
BANGKOK Liaison Office
MILAN Office
Phone : +39-02-36636350
Phone : +1-972-324-3370
IRVINE Office
[ CHINA ]
PENANG Representative Office
CHINA Headquarters / SHANGHAI Branch
Phone : +1-949-930-3750
HIROSE ELECTRIC ( CHINA ) CO., LTD.
[ THE NETHERLANDS ]
SHENZHEN Branch
EU Headquarters / AMSTERDAM OFFICE
Phone : +86-755-8207-0851
http://www.hirose.com/cn/
Phone : +31-20-6557460
[ UNITED KINGDOM ]
UK Branch
Phone : +44-1908-202050
Phone : +66-2-686-1255
http://www.hirose.com/sg/
[ MALAYSIA ]
Phone : +65-6324-6113
[ THAILAND ]
BOSTON Office
Phone : +1-978-655-9850
Phone : +82-31-496-7000
http://www.hirose.co.kr/
[ SINGAPORE ]
DETROIT Office (AUTOMOTIVE)
KOREA Office
HIROSE KOREA CO.,LTD.
HANOVER Office
Phone : +1-408-253-9640
[ KOREA ]
Phone : +86-21-6391-3355
Phone : +60-4-648-5536
[ INDIA ]
BANGALORE Office
HIROSE ELECTRIC INDIA PVT. LTD.
Phone : +91-80-4120-1907
BEIJING Branch
HIROSE ELECTRIC ( CHINA ) CO.,LTD.
Phone : +86-10-5165-9332
GUANGZHOU Branch
DELHI Office
Phone : +91-120-660-8018
Phone : +86-180-9895-1861
[ HONG KONG ]
HONG KONG Office
HIROSE ELECTRIC
HONGKONG TRADING CO., LTD.
Phone : +852-2803-5338
http://www.hirose.com/hk/
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com https://www.hirose-connectors.com
※ The contents of this catalog are current as of date of 2/ 2021. Contents are subject to change without notice for the purpose of improvements.
22
