TCXO Specification
Part No. + Packaging: LFPTXO000291Bulk
Customer Part:
Description
Surface mount temperature compensated voltage controlled
crystal oscillator.
Freq Adj option
Option A (standard):
Ageing adjustment by means of external Control Voltage
applied to pad 1
Range (frequency ≤ 20MHz) ≥ ±5ppm
Range (frequency > 20MHz) ≥ ±7ppm
Linearity ≤2%
Slope Positive
Input resistance ≥100kΩ
Modulation bandwidth ≥2kHz
Standard control voltage range 1.5V±1V
Model
CFPT-9301-A
Model Issue number
7
Frequency Parameters
Frequency
32.7680MHz
Frequency Tolerance
±1.00ppm
±1.00ppm
Frequency Stability
Operating Temperature Range
Ageing
Outline (mm)
-40.00 to 85.00°C
±1ppm max in 1st year (see
Note 1)
Supply Voltage Variation (@ ±5% change):
Frequency
很抱歉,暂时无法提供与“LFPTXO000291BULK”相匹配的价格&库存,您可以联系我们找货
