YMC01DAAN
YMC01DAAN
    SULLINS
    CONN HEADER VERT 2POS
YMC01DAAN 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO C 1062 D 1062 F E 2078 F 2442 G 2743 DESCRIPTION UPDATE DWG. AND TABLES, MOVED RA TERMINATION TO PAGE 2 UPDATE DWG. DATE BY 06/19/2006 HT 3/15/2007 SB UPDATE TEMPERATURE TO 150 C FOR 'G' MTL, CORRECT NOTE 6 & 7, ADD NEW TERMINATION TYPE AI, AJ, AK, FF, FG,FH, FI, FJ, ZB, ZI, ZJ, ZO, ZQ, ZR, COMBINED 'P' MTL IN P/N CODING (DWG 10726, 10167 OBSOLETED) 11/12/2009 JH 9/8/2011 JH 1/24/2014 JHSU UPDATE PROCESSING TIME FOR 'G' MTL, VOLTAGE RATING, REMOVE MOISTURE NOTE, PROCESSING TEMP FOR 'P' MTL ADD PLATING OPTIONS, UPDATE BODY SHAPE, ADD HIGH TEMP MATERIALS F E E D D .200 5.08 .100 2.54 , TYP. B A C .050 1.27 C A HEAD .100 2.54 TAIL B A __C__D__N _ _ C _ _ D _ _ N-M500 .100 2.54 ROW SPACING STRAIGHT A SECTION A-A CUSTOMER COPY NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. UL FLAMMABILITY RATING: 94V-0 5. DIELECTRIC WITHSTANDING VOLTAGE: 1800 VAC 6. CURRENT RATING: 3 AMPS 7. CONTACT RESISTANCE: 30 MILLIOHMS MAX. 8. INSULATION RESISTANCE: 5000 MEGOHMS MIN. 8 7 B .025 0.64 FITS .040 MIN. HOLE Pb RoHS COMPLIANT 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 9/8/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 2 _ _C_ _D_ _N - (M500) CAGE CODE 54453 SCALE: 4:1 3 A .100" MALE HEADER, STRAIGHT DWG. NO. C10419 SHEET 1 OF 1 1 REV G FILE NAME: C10419, _ _C_ _D_ _N-OMIT, M500, STRAIGHT
YMC01DAAN
1. 物料型号:文档中提到了不同型号的物料,例如C01DN至C36DN,以及N C11D至N C33D等。
2. 器件简介:文档提供了关于连接器的详细信息,包括其材料、温度范围、加工温度等。
3. 引脚分配:文档列出了不同引脚分配的型号和尺寸,例如C01DN至C36DN,以及N C11D至N C33D等。
4. 参数特性:文档中包含了连接器的电气特性,如UL阻燃等级94V-0、介电强度1800V AC、电流额定值3安培、接触电阻最大30毫欧姆、绝缘电阻最小5000兆欧姆。
5. 功能详解:文档描述了连接器的功能特性,如其材料组成、尺寸公差、RoHS合规性等。
6. 应用信息:文档提供了连接器的应用信息,包括其适用的温度范围和加工温度。
7. 封装信息:文档中包含了连接器的封装信息,如头部和尾部的尺寸。
YMC01DAAN 价格&库存
很抱歉,暂时无法提供与“YMC01DAAN”相匹配的价格&库存,您可以联系我们找货
