YMC29SAAN
YMC29SAAN
    SULLINS
    CONN HEADER VERT 29POS 2.54MM
YMC29SAAN 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY M 3749 UPGRADE PBT ON 36 POSITION, UPDATE NOTCH ON TOP VIEW 1/12/2018 JH F F E E D D .100 2.54 B A .050 1.27 A C C HEAD DIMENSION .100 2.54 TAIL DIMENSION .100 2.54 TYP. B A .025 0.64 B SECTION A-A A .100 2.54 A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. UL FLAMMABILITY RATING: 94V-0 5. DIELECTRIC WITHSTANDING VOLTAGE: 1800 VAC 6. CURRENT RATING: 3 AMPS 7. CONTACT RESISTANCE: 30 MILLIOHMS MAX. 8. INSULATION RESISTANCE: 5000 MEGOHMS MIN. 8 7 .040 1.02 MIN CUSTOMER COPY PCB LAYOUT RECOMMENDED Pb RoHS COMPLIANT 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 9/9/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE .100" CC, HEADER, STRAIGHT PART NUMBER SIZE C _ _C_ _S_ _N - (M500,M594) CAGE CODE 54453 SCALE: 4:1 3 A 2 DWG. NO. C10436 SHEET 1 OF 1 1 REV M FILE NAME: C10436, _ _C_ _S(AA,AB,AC,AD,AE,AF,AG,AH,AI,AJ,AK,FA,FB,FC,FD,FE,FF,FG,FH,FI,FJ,ZA,ZB,ZC,ZD,ZI,ZJ,ZO,ZQ,ZR)N-(OMIT,M500,M594)
YMC29SAAN 价格&库存
很抱歉,暂时无法提供与“YMC29SAAN”相匹配的价格&库存,您可以联系我们找货
