QT26S-32.768KEZF-T
QT26S-32.768KEZF-T
    QST(矽睿)
    DT-26
    无源晶振 12.5pF 50KΩ ±10ppm 206 -40℃~+85℃ 32.768KHz
QT26S-32.768KEZF-T 数据手册
QT26S kHz Crystal Fuel The Digital World Features ● ● ● ● ● Applications Frequency range : 32.768 kHz SMD : Cylinder type External dimensions (mm) Φ : 2.0 x L : 6.1 Reflowable cylinder type RoHS compliant & Pb free ● Real-time clock (RTC) Smart meters Security devices Consumer products Electrical Characteristics Item Symbol QT26S f0 32.768 kHz ∆f/f0 ±10ppm, ±20ppm CL 6.0pF, 12.5pF Operating Temperature Range TOTR -40°C ~ +85°C Storage Temperature Range TSTR -55°C ~ +125°C TM 25°C ± 5°C Temperature Coefficient β -0.034 ± 0.006ppm/°C2 Motional Resistance (ESR) R1 50 kΩ Max. Drive Level DL 1 μW Max. ∆f/f0 ±3 ppm Max. C0 1.35 pF Typ. Nominal Frequency Frequency Tolerance Load Capacitance Turnover Temperature Aging Shunt Capacitance Conditions at 25°C at 25°C at 25°C ± 3°C,first year Dimensions (Unit: mm) Rev. 1.03 Page 1 www.qstproducts.com QT26S kHz Crystal Fuel The Digital World Ordering Information QT26S - 32.768K - D Z F - T Frequency Tolerance (at 25°C) ± 20 ppm ± 10 ppm D E Packaging Method T Tape & Reel Load Capacitance Frequency Stability (over Temp.) Z Standard for kHz B F 6 pF 12.5 pF Packing (Unit: mm) Reflow Profile Rev. 1.03 Page 2 www.qstproducts.com
QT26S-32.768KEZF-T 价格&库存
很抱歉,暂时无法提供与“QT26S-32.768KEZF-T”相匹配的价格&库存,您可以联系我们找货
