7W
MHz CMOS Oscillator
Features
Frequency range : 1MHz to 170MHz
SMD seam sealing ceramic package
Supply voltage : 1.8V ~ 3.3V
CMOS output
Tri-state function available
External dimensions (mm)
L : 7.0 x W : 5.0 x H : 1.3
RoHS compliant & Pb free
Applications
Networking, Server, Storage
Wireless communications
Fibre channel, Ethernet, SATA, SAS,
PCI-E, USB, WLAN, xDSL, xPON
PC mainboard, Notebook, HDD, SSD,
Graphics card, Computer peripherals
Audio, Video, Gaming, Printer, DSC,
IP CAM, Consumer products
Electrical Characteristics
Item
Frequency Range (F 0)
Frequency Stability (F stab)
Operating Temperature Range (T OTR)
Supply Voltage (VDD)
Current Consumption (IDD)
7W
1MHz ~ 170MHz
±50ppm, ±30ppm, ±25ppm
1.8V, 2.5V, 3.3V
1MHz ~ 75MHz
20 mA Max.
75MHz ~ 170MHz
Output Load (CL)
15 pF
Output Voltage High (VOH)
90% VDD Min.
Output Voltage Low (VOL)
10% VDD Max.
Rise & Fall Time (Tr / Tf)
8 ns Max.
Duty Cycle
40% ~ 60%
Start-up Time
5 ms Max.
Enable Voltage High, Logic "1"
70% VDD Min.
Enable Voltage Low, Logic "0"
30% VDD Max.
Storage Temperature Range (T STR)
VDD ± 10%
10 mA Max.
CMOS
Aging (Faging)
Note [1]
-40°C ~ +85°C
Output Type
Phase Jitter, RMS
Conditions
1 ps Max.
±3 ppm Max.
10% ~ 90% of VDD
Input to Pin1
Note [2]
Note [3]
at 25°C±3°C,first year
-55°C ~ +125°C
Notes:
[1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating
temperature, supply voltage, and load.
[2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0".
[3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz.
Rev. 1.03-a
Page 1
www.txccrystal.com
7W
MHz CMOS Oscillator
Dimensions
(Unit: mm)
Ordering Information
7W
30.000M B E - T
Frequency in Hz
Packaging Method
T
Please contact us for
available frequencies
Frequency Stability
Supply Voltage
B
C
D
Rev. 1.03-a
Tape & Reel
A
D
E
3.3 V
2.5 V
1.8 V
Page 2
± 25 ppm (-10˚C ~ +70˚C)
± 25 ppm (-40˚C ~ +85˚C)
± 50 ppm (-40˚C ~ +85˚C)
www.txccrystal.com
7W
MHz CMOS Oscillator
Packing
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min.
Peak temperature : 260°C ± 10°C, 10 sec. Min.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.03-a
60 sec
Page 3
Time (sec)
www.txccrystal.com
很抱歉,暂时无法提供与“7W-14.7456MBD-T”相匹配的价格&库存,您可以联系我们找货
