Mounting Option
102-.128 (3.25) Dia. Mounting Holes
Contact Detail
500-Wire Hole .087x.015(2.21x0.38) - Tail LG.=.282(7.16)
.156 [3.96] Contact Spacing with Single Centreline Row
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
ORIGINAL
1
3.898 99.01
3.732 94.79
0.128 3.25
Card Slot Accepts
.054 (1.37) to .070 (1.78)
Thick P.C. Board
0.343 8.71
0.295 7.49
Card Slot
A
0.250 6.35
0.165 4.19
Point of Contact
SECTION A-A
A
0.126 3.20
0.460 11.68
See Accompanying Pages for:
Mounting Options
Features and Specifications
306 / 316 / 356 Card Edge Connector
Part Number: 316-023-500-102
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
306 Assembly
306 ENG MASTER
DATE: SEPT. 14/09
DATE:
SHEET 1 OF 3
ISSUE
1
0.125 3.18
Code x01
Code x12
ISSUE NUMBER
ORIGINAL
1
.128 [3.25] Dia
Through Holes
.128 [3.25] Dia
Through Holes
0.468 11.89
0.344 8.74
0.125 3.18
0.060 1.52
Code x02
0.116 2.95 I.D.
Floating Eyelets
0.090 2.29
0.250 6.35 Dia.
.010 [0.25]
Radial Float
2.750 69.85
Code x03
2.500 63.50
0.328 8.33
0.005 0.13
1.550 39.37
.156 [3.96] Dia
Through Holes
0.250 6.35
Code x04
M3-0.5 Metric
Threaded Insert
#4-40 UNC
Threaded Insert
Code x68
Mounting Options
EDAC INC
Code x08
0.250 6.35
0.242 6.15
0.423 10.74
Code x58
Code x07
0.250 6.35
TORONTO, ONTARIO
CANADA
Code x78
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
306 Assembly
306 ENG MASTER
DATE: SEPT. 14/09
DATE:
SHEET 2 OF 3
ISSUE
1
ISSUE NUMBER
ORIGINAL
1
Features
316/306/356 Series UL Recognized
.156 (3.96) Contact Spacing with Single Centreline Row
Accepts .062 (1.57) Nominal Thickness P.C. Board
Low Profile Insulator Body .460 (11.68)
Contact Termination Options include P.C. Tail, Wire Hole & Wire Wrap
Large Variety of Mounting Options
Pre-assembled Card Guides Available
Accepts Between Contact and In-Contact Polarizing Keys
Specifications
Insulator Material: Thermoplastic Polyester, UL 94V-0
Contact Material: Copper Alloy
Contact Plating: Gold on the Mating Area, Tin on the Contact Tails,
Nickel Underplate
Current Rating: 5 Amperes Continuous
Contact Resistance: 10 Milliohms Maximum
Dielectric Withstanding Voltage: 1800 V AC rms at Sea Level Between
Adjacent Contacts
Insulation Resistance: 5000 Megohms Minimum
Operating Temperature: -65 to +105 Degrees C
Insertion Force: 16 oz (4.45 N) Maximum per Contact Pair when
Tested with a .070 (1.78) Thick Gauge
Withdrawal Force: 1 oz (0.28 N) Minimum per Contact Pair when
Tested with a .054 (1.37) Thick Gauge
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
306 Assembly
306 ENG MASTER
DATE: SEPT. 14/09
DATE:
SHEET 3 OF 3
ISSUE
1
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
EDAC:
316-023-500-102
很抱歉,暂时无法提供与“316-026-521-101”相匹配的价格&库存,您可以联系我们找货
