09195105324740
09195105324740
    HARTING(浩亭)
    插件,P=2.54mm
    线对板针座 2x5P 直插 间距:2.54mm
09195105324740 数据手册
SEK IEC 60 603-13 6--64 & Tape aging ack eel p Number of contacts R SMC low-profile male header, straight solder pins SMC male header with straight solder pins Length: 2.9 mm Colour: Beige Packaging: Carton Colour: Beige Packaging: Tape & Reel Vacuum plate for pick & place process Colour: Black Packaging: Tape & Reel Vacuum plate for pick & place process No. of contacts Part number Drawing No. of contacts 6 09 19 506 324 6 10 09 19 510 324 10 14 09 19 514 324 14 16 09 19 516 324 16 20 09 19 520 324 20 26 09 19 526 324 26 30 09 19 530 324 30 34 09 19 534 324 34 40 09 19 540 324 40 50 09 19 550 324 50 60 09 19 560 324 60 64 09 19 564 324 64 6 10 14 16 20 26 30 34 40 09 19 506 09 19 510 09 19 514 09 19 516 09 19 520 09 19 526 09 19 530 09 19 534 09 19 540 324 740 324 740 324 740 324 740 324 740 324 740 324 740 324 740 324 740 6 10 14 16 20 26 30 34 40 09 19 506 09 19 510 09 19 514 09 19 516 09 19 520 09 19 526 09 19 530 09 19 534 09 19 540 324 741 324 741 324 741 324 741 324 741 324 741 324 741 324 741 324 741 Dimensions in mm A B 15.2 20.3 25.4 27.9 33.0 40.6 45.72 50.8 58.4 71.3 84.0 89.1 12.78 17.86 22.94 25.48 30.56 38.18 43.26 48.34 55.96 68.66 81.36 86.44 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 E x 2= x 4= x 6= x 7= x 9= x 12 = x 14 = x 16 = x 19 = x 24 = x 29 = x 31 = 5.08 10.16 15.24 17.78 22.86 30.48 35.56 40.64 48.26 60.96 73.66 78.74 Solder pins for 1 ± 0.1 mm dia. hole SEK Identification Marking No. 1 contact No. 2 contact No. 1 contact No. 2 contact No. 1 contact 7 For performance level 3 please specify digit 6 For performance level 2 please specify digit = 0.76 µm (30 µinch) Au or PdNi eqivalent 5 * S4 Identification Part number Locking lever for female connector with strain relief Drawing Dimensions in mm Strain relief clamp in conjunction with low-profile male header 09 18 000 99054) Female connector Low-profile ­male header * Not normally kept in stock 1) 2)  o polarization slot for 6, 10 or 14 way male header N No polarization slot for 6 way male header 3) 4) When the security of latching is required and space is a ­premium, these locking levers can be fitted onto the strain relief of the ­HARTING female connector.  itch tolerance: ± 0.1 P Order 2 per female connector 08 47
09195105324740 价格&库存
很抱歉,暂时无法提供与“09195105324740”相匹配的价格&库存,您可以联系我们找货
