8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
D
2024
HEAD HEIGHT 3.60 WAS 4.00, UPDATE PCB LAYOUT
& WARP TOLERANCE
8/11/09
JH
2828
ADD 'LCP' MATERIAL OPTION, UPDATE PROCESSING
TEMPERATURE FOR NYLON 6T MATERIAL, UPDATE
OVERALL LENGTH TOL TO 0.50mm (WAS 0.35mm), 04/09/2015
UPDATE CURRENT RATING TO 2 AMPS (WAS 1 AMP)
E
F
F
LH
E
E
B±.020 [ .50]
.157 4.00
D
D
A±.010 [ .25]
.079±.002 2.00±0.05
.079±.002 2.00±0.05
.020 0.50
.142±.008 3.60±0.20
.059 1.50
2X .089 2.25
C
2X
.039 1.00
.087 2.20
A
.006 [0.15] A
C
.018±.008 0.45±0.20
OPTIONAL
.256±.012 6.50±0.30
C±.008 [ .20]
02-20, 0.20mm MAX.
21-30, 0.30mm MAX.
31-40, 0.40mm MAX.
B
A±.004 [ .10]
C±.004 [ .10]
.079±.002 2.00±0.05
.040±.002 1.02±0.05
.047±.002 1.20±0.05
.116±.002 2.95±0.05
.295±.004 7.50±0.10
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, COLOR: BLACK.
2. CONTACT MATERIAL: BRASS.
3. CONTACT PLATING: .000030"-.000050" MIN NICKEL UNDERPLATE,
GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMPS
5. VOLTAGE RATING: 150 V AC/DC.
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 500 VAC.
9. OPERATING TEMPERATURE: SEE PART NUMBER CODING.
8
7
6
B
.063 1.60
RECOMMENDED PCB LAYOUT
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
1
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
06/15/2005 TT
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER, MALE 2mm CC, 2 ROWS, SMT
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 12:1
3
2
xRPNxx2MAMx-RC
DWG. NO.
10495
SHEET 1 OF 1
1
REV
E
FILE NAME: 10495, NRPNxx2MAMx-RC
A
很抱歉,暂时无法提供与“NRPN232MAMS-RC”相匹配的价格&库存,您可以联系我们找货
