GRPB481VWTC-RC
GRPB481VWTC-RC
    SULLINS
    CONN HEADER SMD 48POS 1.27MM
GRPB481VWTC-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY E 1811 UPDATE POSITION NO. 2/16/2009 JH F 3087 UPDATE 'B' TOLERANCE ON DIMENSION TABLE AND PCB LAYOUT DRAWING, ADD GEOMETRIC 10/31/2014 TOLERANCE ON TAIL LH F F A PIN 1 LEFT B .050 1.27 .100 2.54 PIN 1 LEFT E E .089 2.25 .177 4.50 .084 2.14 .030 0.76 .050 1.27 RECOMMENDED PCB LAYOUT GRPB_ _1VWTC-RC GRPB_ _1VWTC-RC (STANDARD) D D A .030 0.76 .084 2.14 PIN 1 RIGHT .089 2.25 .050 1.27 PIN 1 RIGHT .177 4.50 GRPB_ _1VWTD-RC (OPPOSITE BEND, ONLY APPICABLE ON EVEN PIN COUNTS) .100 2.54 C A .050 1.27 C RECOMMENDED PCB LAYOUT GRPB_ _1VWTD-RC .118 3.00 .039 1.00 B A .083 2.10 B .016 0.40 .138 3.50 NOTES: 1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0, COLOR: BLACK *PROCESSING TEMPERATURE: 260°C FOR 10 SECONDS 2. CONTACT MATERIAL: BRASS 3. PLATING: .000030"-.000050" NICKEL UNDERPLATE, GOLD FLASH OVERALL 4. OPERATING TEMPERATURE: -40°C TO +105°C 5. INSULATION RESISTANCE: 5000 MEGA OHM MIN 6. CONTACT RESISTANCE: 20 MILLI OHM MAX 7. DIELECTRIC WITHSTANDING: 500 VAC 8. CURRENT RATING: 1 AMP *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 6 .004[0.10] Pb RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 1 DECIMALS .XX= .012 [0.3] .XXX= .008 [0.20] .XXXX= .0040 [0.100] DRAWN DATE NAME 08/13/07 RAH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE .050" SINGLE ROW MALE HEADER, SMT PART NUMBER SIZE C CAGE CODE 54453 SCALE: 8:1 3 2 GRPB_ _1VWT_-RC DWG. NO. 10962 SHEET 1 OF 1 1 REV F FILE NAME: 10962, GRPB_ _1VWT_-RC A
GRPB481VWTC-RC
1. 物料型号:文档中提到了物料型号为"GRPB_ _1VWT_-RC",并且有一个CAGE码"54453"。
2. 器件简介:文档中提到了绝缘体材料为NYLON 9T,符合UL 94V-0标准,颜色为黑色。处理温度为260°C持续10秒。接触材料为黄铜,镀层为0.000030"至0.000050"的镍底层,表面为金闪镀层。操作温度范围为-40°C至+105°C。绝缘电阻至少为5000兆欧,接触电阻最大为20毫欧,介电强度为500V AC,电流额定值为1安培。
3. 引脚分配:文档中提供了两种引脚分配方式,一种是"PIN 1 LEFT",另一种是"PIN 1 RIGHT"。每种方式都有详细的引脚布局和尺寸。
4. 参数特性:文档中列出了详细的尺寸和公差信息,包括引脚之间的距离和引脚的尺寸。
5. 功能详解:文档中提到了该器件的电气特性,包括绝缘电阻、接触电阻、介电强度和电流额定值。
6. 应用信息:文档中没有明确提到应用信息,但根据电气特性和引脚布局,可以推断该器件可能用于需要电气连接和信号传输的应用。
7. 封装信息:文档中提到了封装类型为SMT(表面贴装技术),并且提供了封装的详细尺寸和公差信息。
GRPB481VWTC-RC 价格&库存
很抱歉,暂时无法提供与“GRPB481VWTC-RC”相匹配的价格&库存,您可以联系我们找货
GRPB481VWTC-RC
  • 1000+26.132011000+3.38721
