CR22A-44D-2.54DSA(70)
    HRS(广濑)
    插件
CR22A-44D-2.54DSA(70) 数据手册
2.54mm Pitch Card Edge Connector CR22 Series ■Features 1. 2.54mm pitch Contact 2. Variation in number of contacts 20, 30, 34, 36, 44, 50, 60, 62, 68, 72, 80,100, and 120 contacts are available. 3. Board Mount Type Straight dip and right angle through hole types are available. Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. To prevent mis-insertion in the board Using the polarizing key prevents mis-insertion in the printed board. ■Product Standards Current rating: 3A Operating Temperature Range: -30 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç (Note 2) Voltage rating: 300VAC Operating Humidity Range: 40 to 80% Storage Humidity Range: 40 to 70% (Note 2) Rating Item Specification Condition 1.Insulation Resistance 1000M ohms min. 500V DC 2.Withstanding Voltage No flashover or insulation breakdown. 1000V AC/1 minute. 3.Contact Resistance 20m ohms max. 100mA 4.Vibration No electrical discontinuity of 10μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5.Humidity(Steady state) Insulation resistance : 1000M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6.Temperature Cycle (-65ç : 30 minutes→15 to 35ç: 5 minutes max.→ 125ç : 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles No damage, cracks, or parts looseness. 500 cycles 7.Durability (Mating/un-mating) Contact resistance : 20m ohms max. 8.Resistance to Soldering heat No deformation of components affecting performance. Manual soldering: 350ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Parts Material Finish Remarks Insulator PBT Black UL94V-0 Contact Copper alloy Contact area Selective gold plated --------------- Lead area Tin plated --------------- ■Ordering Information CR22 1 1 2 A2 A - 50 D - 2.54 DS 2 3 4 Series Name : CR22 Blank : With Mounting hole A : Without mounting hole B : Card Edge 7.62mm type with mounting hole C : Card Edge 7.62mm type without mounting hole D : VERSA bus type with mounting hole E : VERSA bus type without mounting hole 5 6 3 Number of contacts : 20, 30, 34, 36, 44, 50, 60, 62, 68, 72, 80, 100, 120 4 Contact alignment : D : Double side 5 Contact pitch : 2.54mm 6 Contact type DS : Straight type DSA : Right angle type CR22 Series●2.54mm Pitch Card Edge Connector Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Straight Through hole Type Unit: mm Part Number CL No. Number of Contacts A B C D E F G CR22 - 20D-2.54DS(70) CL522-0063-9-70 20 49.04 41.44 34.04 27.94 22.86 34.04 9.5 CR22 - 30D-2.54DS(70) CL522-0009-3-70 30 61.74 54.14 46.74 40.64 35.56 46.74 9.5 CR22 - 34D-2.54DS(70) CL522-0011-5-70 34 66.82 59.22 51.82 45.72 40.64 51.82 9.5 CR22 - 44D-2.54DS(70) CL522-0001-1-70 44 79.52 71.92 64.52 58.42 53.34 64.52 9.5 87.14 79.54 72.14 66.04 60.96 72.14 9.5 CR22 - 50D-2.54DS(70) CL522-0003-7-70 50 84.71 78.11 70.10 66.04 60.96 70.10 9.4 CR22 - 68D-2.54DS(70) CL522-0017-1-70 68 110.00 102.40 95.00 88.90 83.82 95.00 9.5 CR22 - 72D-2.54DS(70) CL522-0019-7-70 72 115.08 107.48 100.08 93.98 88.90 100.08 9.5 CR22 - 80D-2.54DS(70) CL522-0049-8-70 80 125.24 117.64 110.24 104.14 99.06 110.24 9.5 CR22 -100D-2.54DS(70) CL522-0005-2-70 100 150.64 143.04 135.64 129.54 124.46 135.64 9.5 Note CR22D-120D-2.54DS(70) CL522-0053-5-70 120 176.04 168.44 161.04 154.75 149.86 161.04 10 CR22B- 50D-2.54DS(70) CL522-0047-2-70 RoHS YES Note : The 120 contacts type differs in configuration. A3 CR22 Series●2.54mm Pitch Card Edge Connector Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Straight Through hole Type Unit: mm Part Number CL No. Number of Contacts A B C D CR22A- 20D-2.54DS(70) CL522-0064-1-70 20 34.04 27.94 22.86 9.5 CR22A- 30D-2.54DS(70) CL522-0010-2-70 30 46.74 40.64 35.56 9.5 CR22A- 34D-2.54DS(70) CL522-0012-8-70 34 51.82 45.72 40.64 9.5 54.36 48.26 43.18 9.5 52.32 48.26 43.18 9.4 64.52 58.42 53.34 9.5 72.14 66.04 60.96 9.5 70.10 66.04 60.96 9.4 84.84 78.74 73.66 9.5 87.38 81.28 76.20 9.5 85.34 81.28 76.20 9.4 CR22A- 36D-2.54DS(70) CL522-0008-0-70 36 CR22C- 36D-2.54DS(70) CL522-0072-0-70 CR22A- 44D-2.54DS(70) CL522-0002-4-70 44 CR22A- 50D-2.54DS(70) CL522-0004-0-70 50 CR22C- 50D-2.54DS(70) CL522-0048-5-70 CR22A- 60D-2.54DS(70) CL522-0014-3-70 60 CR22A- 62D-2.54DS(70) CL522-0016-9-70 62 CR22C- 62D-2.54DS(70) CL522-0060-0-70 CR22A- 68D-2.54DS(70) CL522-0018-4-70 68 95.00 88.90 83.82 9.5 CR22A- 72D-2.54DS(70) CL522-0020-6-70 72 100.08 93.98 88.90 9.5 CR22A- 80D-2.54DS(70) CL522-0050-7-70 80 110.24 104.14 99.06 9.5 CR22A-100D-2.54DS(70) CL522-0006-5-70 100 135.64 129.54 124.46 9.5 Note CR22E-120D-2.54DS(70) CL522-0054-8-70 120 161.04 154.75 149.86 10 Note : The 120 contacts type differs in configuration. A4 RoHS YES CR22 Series●2.54mm Pitch Card Edge Connector ■Right Angle Through hole Type Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note : Mounting hole of CR22D is design symmetry Unit: mm Part Number CL No. CR22 - 30D-2.54DSA(70) CL522-0023-4-70 CR22A- 30D-2.54DSA(70) CL522-0034-0-70 CR22 - 34D-2.54DSA(70) CL522-0024-7-70 CR22A- 34D-2.54DSA(70) CL522-0035-3-70 Number of Contacts 30 34 A B C D E F G H 61.74 54.14 46.74 40.64 35.56 9.5 16.5 9 --------- --------- 46.74 40.64 35.56 9.5 16.5 9 66.82 59.22 51.82 45.72 40.64 9.5 16.5 9 --------- --------- 51.82 45.72 40.64 9.5 16.5 9 CR22 - 36D-2.54DSA(70) CL522-0025-0-70 36 69.36 61.76 54.36 48.26 43.18 9.5 16.5 9 CR22A- 44D-2.54DSA(70) CL522-0037-9-70 44 --------- --------- 64.52 58.42 53.34 9.5 16.5 9 87.14 79.54 72.14 66.04 60.96 9.5 16.5 9 84.71 78.11 70.10 66.04 60.96 9.4 15.49 7.62 99.84 92.24 84.84 78.74 73.66 9.5 16.5 9 102.38 94.78 87.38 81.28 76.20 9.5 16.5 9 CR22 - 50D-2.54DSA(70) CL522-0027-5-70 CR22B- 50D-2.54DSA(70) CL522-0045-7-70 CR22 - 60D-2.54DSA(70) CL522-0028-8-70 CR22 - 62D-2.54DSA(70) CL522-0029-0-70 CR22A- 62D-2.54DSA(70) CL522-0040-3-70 50 60 62 --------- --------- 87.38 81.28 76.20 9.5 16.5 9 CR22 - 68D-2.54DSA(70) CL522-0030-0-70 68 110.00 102.40 95.00 88.90 83.82 9.5 16.5 9 CR22 - 72D-2.54DSA(70) CL522-0031-2-70 72 115.08 107.48 100.08 93.98 88.90 9.5 16.5 9 150.64 143.04 135.64 129.54 124.46 9.5 16.5 9 --------- --------- 135.64 129.54 124.46 9.5 16.5 9 CR22 -100D-2.54DSA(70) CL522-0033-8-70 CR22A-100D-2.54DSA(70) CL522-0044-4-70 100 RoHS YES A5 CR22 Series●2.54mm Pitch Card Edge Connector BPCB Dimensions 30 to 45° 30 to 45° Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0 Note 1. The 120 contacts type indicates 154.69 –0.25 . Note 2. The 120 contacts type indicates 2.415. Unit: mm Number of Contacts 12 30 34 36 44 50 60 62 68 72 A 22.86 35.56 40.64 43.18 53.34 60.96 73.66 76.20 83.82 88.90 B 27.84 40.54 45.62 48.16 58.32 65.94 78.64 81.18 88.80 93.88 104.04 129.44 154.69 80 100 120 99.06 124.46 149.86 ■Polarizing Key CR13-GPIN(A) Part Number CL No. Material Color RoHS CR13-GPIN(A) 513-0010-1 Polyacetal White YES Note: Using the polarizing key prevents mis-insertion in the printed board. To use the polarizing key, insert the polarizing key so as to hit the mold bottom. : ■PCB mounting pattern Unit: mm Number of Contacts 12 30 34 36 44 50 60 62 68 72 A 22.86 35.56 40.64 43.18 53.34 60.96 73.66 76.2 83.82 88.9 Note : The contact DSA type indicates 2.54mm±0.05. A6 80 100 120 99.06 124.46 149.86
物料型号:CR22系列
器件简介:CR22系列是2.54mm间距的卡边连接器,具有多种接触点数量和安装类型。
引脚分配:提供直插式和直角型两种类型,接触点数量有20、30、34、36、44、50、60、62、68、72、80、100和120等。
参数特性: - 电流额定值:3A - 电压额定值:300VAC - 工作温度范围:-30至+85℃ - 存储温度范围:-10至+60℃ - 绝缘电阻:最小1000MΩ - 接触电阻:最大20mΩ - 耐电压:500V DC,1000V AC/1分钟
功能详解: - 可防止在PCB上错误插入,使用极化键防止错误插入。 - 提供选择性金镀和锡镀的接触点。
应用信息:适用于需要卡边连接的应用场景。
封装信息: - 绝缘体材料:PBT - 接触材料:铜合金 - 接触区域:黑色 - 符合UL94V-0防火等级
订购信息:提供了详细的订购指南,包括系列名称、是否带安装孔、接触对齐方式、接触类型等选项。
CR22A-44D-2.54DSA(70) 价格&库存
很抱歉,暂时无法提供与“CR22A-44D-2.54DSA(70)”相匹配的价格&库存,您可以联系我们找货
