YP32K76800S003
YP32K76800S003
    NEXTGEN
    SMD-4
    无源晶振 12.5pF 50KΩ ±20ppm -40℃~+85℃ SMD-4 32.768KHz
YP32K76800S003 数据手册
PART CODE: YP32K76800S003 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0223- YP32K76800S003 DATE Feb. 23, 2021 REVISION A0 DESCRIPITION KHz Plastic SMD Crystals, L8.0*W3.8*H2.4mm, 4 Pads, CCMC series 32.76800KHz, +/-20ppm, CL 12.5pF, Operating Temp. Range -40°C ~+85°C, ESR 50 Kohm Max, Reflow Profile Condition 260 °C Max. Tape/Reel, RoHS/RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863) CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CCMC 32K768A20-12.5-40-50TLH PART CODE YP32K76800S003 VENDOR APPROVE Issued/Checked/Approved DATE: Feb. 23, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YP32K76800S003 KHZ PLASTIC SMD SMDCRYSTALS CRYSTAL 2520 8038 TYPE 4 PADS MAIN FEATURE • SMD Package, 8038 Type, L8.0*W3.8*H2.4mm, 4 Pads • Low cost and short lead time • Industry standard • Reflow Profile Condition 260 °C Max. • Cross more competitors part • RoHS/RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863) APPLICATION • Clock source for Portable • Microcomputer & Automotive Equipment with Low power consumption RFQ PART CODE GUIDE Request For Quotation YP 32K76800 S 003 1 2 3 4 1) YP: Part family Code for KHz Plastic SMD Crystals, L8.0*W3.8*H2.4mm, 4 Pads, CCMC series 2) 32K76800: Frequency range code for 32.76800KHz 3) S: SMD type, Package Tape/Reel, 3000pcs/Reel 4) 003: Specification code for original part No.: TGS CCMC 32K768A20-12.5-40-50TLH MORE FREQUENCY RANGE AVAILABLE (KHz) 32.768 100.00 153.60 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YP32K76800S003 KHZ PLASTIC SMD CRYSTALS 8038 TYPE 4 PADS DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking Line 1: Frequency Range CCMC Note: • • • Recommend Pad Layout Do not connect pad 2 and Pad 3 to external devices. Metal inside may be exposed on the top or bottom of plastic case It isn't Quality problem. This will not affect any quality, reliability and electrical specification when used Pin Function #1 Crystal #2 Ground #3 Ground #4 Crystal NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YP32K76800S003 KHZ PLASTIC SMD CRYSTALS 8038 TYPE 4 PADS ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Holder Type Frequency Range TGS Crystals CCMC KHz Plastic SMD Crystals, L8.0*W3.8*H2.4mm, 4 Pads 32K768 KHz A Frequency Tolerance 20 ppm -12.5 pF Frequency/Temp Coefficient Operation Temperance -40 -50 32.76800 AT Fundamental ppm/C² Storage Temperance Equivalent Series Resistance (ESR) Max. TGS Mode of Oscillation Load Capacitance Typical Condition -20 +20 12.5 0.028 0.034 0.04 °C -40 +85 °C -40 +85 KΩ 50 Drive Level μW 1.0 Shunt Capacitance (C0) pF Dynamic Capacitance fF Turnover Temp °C 0.9 1.35 2.0 1.8 +20 +25 Quality Factor +30 60000 Capacitance Ratio 450 Aging ppm/year Insulation Resistance MΩ ±3 500 @1st year @100VDC ± 15VDC Package T Tape/Reel, 3000pcs/Reel RoHS Status LH RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863) Other @25°C Add Value N/A Internal Control Code * N/A Note: 1) Original Part Number: TGS CCMC 32K768A20-12.5-40-50TLH 2) * Internal Control Code- 2 letter or digits; Blank: N/A NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YP32K76800S003 KHZ PLASTIC SMD CRYSTALS 8038 TYPE 4 PADS RELIABILITY Test Items Test Method And Conditions Reference Documents High Temperature High Humidity Storage Temperature: 85℃±3℃ Relative Humidity:85%RH Time: 96 Hours JIS C5023 High Temperature Storage Temperature: 125℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1005.8 Low Temperature Storage Temperature: -40℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1013 Thermal Shock Temperature 1: -55℃±5℃ Temperature 2: 85℃±5 ℃ Temperature change between T1 and T2 5 min 10cycles maintain T1 and T2 for 30 minutes each cycle MIL-STD-202F Method 107 Condition A Resistance to Solder Heat Solder Temperature: 260℃±5℃ Time: 10±1 Seconds MIL-STD-202F Method 210E Solderability The solder pot temperature is 245±5℃ , dwell time 5±0.5sec J-STD-002B Drop Test 3 Times Free Fall from 50cm height table to 3cm thickness hard wood board J-STD-002B Mechanical Shock Half sine wave,1000 G 3 Times for all 3 directions(X,Y Z) MIL STD 202F Method 213B Vibration Frequency Range: 10Hz~55Hz Amplitude: 0.75mm 2 Hours in each direction, total 6 Hours MIL-STD-883E Method 2007.3 Leakage Test Take measurements with a helium Leakage detector Leakage Rate≤1×10ˉ³Pa cm³/s MIL-STD-883E NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YP32K76800S003 KHZ PLASTIC SMD CRYSTALS 8038 TYPE 4 PADS SUGGESTED REFLOW PROFILE (For Reference Only) Total time: 200 Sec. Max. Solder melting point: 220℃ Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 125℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YP32K76800S003 KHZ PLASTIC SMD CRYSTALS 8038 TYPE 4 PADS TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and specifications, 3000pcs/Reel DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
YP32K76800S003 价格&库存
很抱歉,暂时无法提供与“YP32K76800S003”相匹配的价格&库存,您可以联系我们找货
