8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2268
INITIAL RELEASE
03/21/2011
LH
B
2422
ADD 'P' PLATING OPTION, OBSOLETE 11139
08/04/2011
LH
F
F
B .012[ 0.30]
E
E
.100 2.54
A
D
D
HEAD DIM.
.098 2.50
TAIL DIM.
.025 0.64
.100 2.54
C
C
A
.100 2.54
.039 1.00
RECOMMENDED PCB LAYOUT
B
A
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK.
2. CONTACT MATERIAL: SEE PART NUMBER CODING.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS PER CONTACT.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 1000 VAC.
8. OPERATING TEMPERATURE: SEE PART NUMBER CODING.
9. *PROCESSING TEMP.: SEE PART NUMBER CODING.
DRAWN
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING
TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB,
AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
7
6
5
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES[MM]
Pb
TOLERANCES: ANGULAR:
.XX= .012 [.30]
.XXX= .008 [.20]
.XXXX= .0040 [.100]
RoHS COMPLIANT
4
INTERPRET DIMENSIONS
AND TOLERANCING
PER: ASME Y14.5M-2009
DATE
NAME
03/21/2011
LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
3
HEADER MALE .100" PITCH, STRAIGHT
_ R_C_ _ _S_ _N-RC
CAGE CODE
54453
DWG. NO.
REV
11635
B
SCALE: 5:1
SHEET 1 OF 1
2
1
FILE NAME: Z:\ECO PENDING\2422, TAIWAN HEADER 100 CC ADD P PLATING\11635, _ R_C_ _ _S_ _N-RC, ST PRINT: 8/26/2011
A
很抱歉,暂时无法提供与“PREC037SADN-RC”相匹配的价格&库存,您可以联系我们找货
