345/395 SERIES
Card Edge Connectors 0.100” (2.54mm) Pitch
Features:
0.100” (2.54mm) contact spacing x 0.200” (5.08mm) row spacing
Accepts 0.062” (1.57mm) nominal thickness P.C. board
High profile insulator body, 0.600” (15.24mm)
Contact termination options include P.C. tail, wire wrap, 90 degree bends and extender board bends
Single or dual row configurations
Large variety of mounting options, flush or offset lugs
Accepts between contact and in-contact polarizing keys
Pre-assembled card guides are available
Automatic wire wrap positioning holes
RoHS Compliant & UL Certified
Specifications:
Insulator Material
UL 94V-0 Thermoplastic Polyester
Contact Material
Copper Alloy
Contact Plating
Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
Current Rating
3 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
1200 V AC rms at sea level between adjacent contacts
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-40°C to +105°C
Insertion Force
16 oz (4.45 N) maximum per contact pair when tested with .070” (1.78mm) thick gauge
Withdrawal Force
1 oz (0.28 N) minimum per contact pair when tested with .054” (1.37mm) thick gauge
Contact Code:
Tail Description:
Tail Size:
Tail Length
“G”:
500
Wire Hole
.050 x .025 (1.27 x 0.64)
.260 (6.60)
520
P.C. Tail
.030 x .018 (0.76 x 0.46)
.175 (4.45)
Contact Code
521
P.C. Tail
.025 Square (0.64 Square)
.150 (3.81)
Contact Rows and Insulator Style
523
P.C. Tail
.390 (9.91)
Mounting Options
524
P.C. Tail
.018 Square (0.46 Square)
.175 (4.45)
525
P.C. Tail
.150 (3.81)
540
Wire Wrap
.560 (14.22)
541
Wire Wrap
.750 (19.05)
542
Wire Wrap
.645 (16.38)
544
Wire Wrap
.750 (19.05)
555
EXTENDER BOARD BEND
(CODE 500 CONTACTS)
556
EXTENDER BOARD BEND
(CODE 520 CONTACTS)
558
90 DEGREE BEND
(CODE 541 CONTACTS)
559
90 DEGREE BEND
(CODE 541 CONTACTS)
560
EXTENDER BOARD BEND
(CODE 523 CONTACTS)
Example Part Number:
345-050-520-202
Series
Total Number of Contacts
Series:
Insulator Color:
345
Thermoplastic Polyester, Green
395
Thermoplastic Polyester, Black
Total Number of Contacts:
Contact Rows:
005, 006, . . . . 072
Single Row
010, 012, . . . . 144
Dual Row
Insulator Style:
Description:
Insulator Style
1
Single Row
Flush Mounting Lugs
2
Dual Row
Flush Mounting Lugs
4
Single Row
.110 (2.79) Offset Lugs
5
Dual Row
Mounting Options:
Description:
No Mounting Lug
6
Single Row
.170 (4.32) Offset Lugs
01
8
Dual Row
02
Ø.128” (Ø3.25mm) Mounting Holes
03
Ø.116” (Ø2.95mm) I.D. Floating Eyelets
04
Ø.156” (Ø3.96mm) Mounting Holes
07
M3-0.5 Metric Threaded Inserts
08
#4-40 Unified Threaded Inserts
12
Ø.128” (Ø3.25mm) Side Mounting Holes
58
.468” (11.89mm) Offset Card Guides
78
In-Line Card Guides 2.750” (69.85mm) Long
88
In-Line Card Guides 1.250” (31.75mm) Long
Ordering Code Notes:
1) All connector sizes up to 72 contacts single row / 144
contacts dual row are available upon request.
2) The 500 contact code is only available in the 345 series.
Green Diallyl Phthalate insulator material will be supplied.
3) For details of the extender board and 90 degree bends refer
to next pages.
4) For lug-less connectors, code 01 mounting, specify contact
row code 1 or 2.
5) For details of the mounting options refer to page 3 & page 4.
www.edac.net
customerservice@edac.net
345/395 SERIES
SECTIONS THROUGH
CONTACT POSITION
DUAL ROW
SINGLE ROW
0.025±0.005
(NOSE GAP)
"A"
AUTOMATIC
WIRE WRAP
POSITIONING
HOLE AND SLOT
"B"
.330 (8.38)
CARD SLOT
"C"
.600
(15.24)
.160 (4.06) POINT
OF CONTACT
.370
(9.40)
EVEN
NUMBERED
SIDE OF
CONNECTOR
(2,4,6,8...)
0.200(5.08)
CARD SLOT ACCEPTS .054 (1.37)
TO .070 (1.78) THICK P.C. BOARD
.128 (3.25) DIA
THROUGH HOLES
B
"D"
.250
(6.35)
.250 (6.35)
.170 (4.32)
OR
.110 (2.79)
OFFSET LUGS
G
0.125(3.18)
B
FLUSH MTG. LUG
FOR RIGHT ANGLE MOUNTING
WITH FLUSH OR OFFSET LUGS
.100 (2.54)
.030 (0.76) X .080
(2.03) WIRE HOLE
.125 (3.18)
"E"
SEE SHEET 3
"F"
.200 (5.08)
FOR CONTACT CODES, DESCRIPTION
AND TAIL SIZES, SEE SHEET 1
FOR 90°, EXTENDER BOARD BENDS
CONTACTS, SEE SHEET 3
FOR IN CONTACTS AND BETWEEN
CONTACTS POLARIZING KEYS PART NO.,
SEE SHEET 1
.136 (3.45)
DIA REF
0.100
.400 (10.16)
0.055
(1.40)
.042
(1.07)
.080
(2.03)
CUT OUT FOR
IN-CONTACT
POLARIZING KEY.
CUT OUT FOR
BETWEEN CONTACT
POLARIZING KEY.
+.000
D MINUS .012 (0.30) -.015 (0.38)
RECOMMENDED DAUGHTER BOARD
NUMBER OF CONTACTS
"A"±.015 (±0.38)
.200
PANEL MOUNT
(5.08)
CUT OUT
.350
(8.89)
.100 (2.54)
.140 (3.56)
PANEL MOUNT
E
.042 (1.07) +.004 (0.10)/-.000
FOR ALL P.C. TAILS
EXCEPT CODE 524
.031 (0.79) +.004 (0.10)/-.000
FOR CODE 524 P.C. TAIL
.008 (0.20) DIA
CONNECTOR MOUNTING PATTERN
"B"±.010 (±0.25)
B
"C"±.015 (±0.38)
"D"+.010 /-.006 (+0.25/-0.15)
“E”±.005 (±0.13)
Single
Double
Inch
mm
Inch
mm
Inch
mm
Inch
mm
Inch
mm
5
10
1.335
33.91
1.075
27.31
0.760
19.30
0.600
15.24
0.400
10.16
10
46.61
1.575
40.01
1.260
32.00
1.100
27.94
0.900
22.86
13
26
2.135
54.23
1.875
47.63
1.560
39.62
1.400
35.56
1.200
30.48
15
30
2.335
59.31
2.075
52.71
1.760
44.70
1.600
40.64
1.400
35.56
18
36
2.635
66.93
2.375
60.33
2.060
52.32
1.900
48.26
1.700
43.18
22
44
3.035
77.09
2.775
70.49
2.460
62.48
2.300
58.42
2.100
53.34
25
50
3.335
84.71
3.075
78.11
2.760
70.10
2.600
66.04
2.400
60.96
30
60
3.835
97.41
3.575
90.81
3.260
82.80
3.100
78.74
2.900
73.66
31
62
3.935
99.95
3.675
93.35
3.360
85.34
3.200
81.28
3.000
76.20
36
72
4.435
112.65
4.175
106.05
3.860
98.04
3.700
93.98
3.500
88.90
43
86
5.135
130.43
4.875
123.83
4.560
115.82
4.400
111.76
4.200
106.68
50
100
5.835
148.21
5.575
141.61
5.260
133.60
5.100
129.54
4.900
124.46
60
120
6.835
173.61
6.575
167.01
6.260
159.00
6.100
154.94
5.900
149.86
72
144
8.035
204.09
7.775
197.49
7.460
189.48
7.300
185.42
7.100
180.34
www.edac.net
345/395 SERIES
.250 (6.35) DIA
A
.010 (0.25) RADIAL
FLOAT
DIA THROUGH
HOLES
0.328(8.33)
CONNECTOR
CONNECTOR
C
DIMENSION
DIMENSION
CONNECTOR
B
MOUNTING OPTION
CODES x02 AND xO4
(THROUGH MOUNTING HOLES)
MOUNTING OPTION
CODE x01
(NO MOUNTING LUGS)
B
DIMENSION
.005 (0.51) VERTICAL
FLOAT
.116 (2.95) I.D.
FLOATING EYELETS
MOUNTING OPTION
CODE x03
(FLOATING EYLETS)
CODE x07
M3-0.5 METRIC
CODE x08
#4-40 UNC
THREADED INSERTS
.128 (3.25) DIA
THROUGH HOLES
CODE X02 AND X04- THROUGH MTG. HOLES
0.125(3.18)
CONNECTOR
DIMENSION
CONNECTOR
DIMENSION
B
"A" DIA.
B
CODE X08
M3-0.5(METRIC)
CODE X17
#4-40 UNC
CODE X18
M3-0.5(METRIC)
#4-40 UNC
CODES X78 AND X88- IN-LINE CARD GUIDES
.120
(3.05)
"A"
CODE X78
CODE X88
2.750(69.85)
1.250(31.75)
CARD GUIDE
2.755
(69.98)
A
CONNECTOR
CONNECTOR
.250 (6.35)
.250 (6.35)
#4-40 UNC
THREADED
INSERT
#4-40 UNC
THREADED
INSERT
B
MOUNTING OPTION
CODES x78 & x88
(IN-LINE CARD GUIDE)
www.edac.net
0.156(3.96)
SIDE MOUNTING HOLES WITH INSERTS
.468
(11.89)
0.083(2.11)
CONNECTOR
DIMENSION
0.128(3.25)
CODE X07
INSERT
INSERT
CARD GUIDE
CODE X04
CODE X07 AND X08- THREADED INSERTS
MOUNTING OPTION
CODES x07 & xO8
(THREADED INSERTS)
MOUNTING OPTION
CODE x12
(SIDE MOUNTING HOLES)
WITH INSERTS: CODES X17 & X18,
SEE TABLE
CODE X02
CONNECTOR
DIMENSION
B
.402
(10.21)
MOUNTING OPTION
CODES x58
(OFFSET CARD GUIDES)
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
EDAC:
345-048-524-478 345-048-524-603 345-048-524-607 345-048-524-658 345-048-540-108 345-048-540-112 345048-540-478 345-048-540-603 345-048-540-608 345-048-541-102 345-048-541-107 345-048-541-404 345-048541-412 345-048-541-488 345-048-541-603 345-048-541-608 345-048-541-678 345-048-542-107 345-048-542-404
345-048-542-408 345-048-542-478 345-048-542-608 345-048-544-101 345-048-544-112 345-048-544-188 345048-544-402 345-048-544-488 345-048-544-588 345-048-544-604 345-048-544-612 345-048-544-878 345-048544-888 345-048-555-203 345-048-555-208 345-048-555-278 345-048-555-558 345-048-555-578 345-048-555-803
345-048-555-858 345-048-556-288 345-048-556-578 345-048-556-803 345-048-558-101 345-048-558-112 345048-558-404 345-048-558-458 345-048-558-507 345-048-558-512 345-048-558-588 345-048-558-803 345-048558-808 345-048-559-278 345-048-559-403 345-048-559-558 345-048-559-602 345-048-559-607 345-048-560-208
345-048-560-807 345-048-560-858 345-049-500-103 345-049-500-402 345-049-500-602 345-049-520-103 345049-520-188 345-049-520-403 345-049-520-408 345-049-520-478 345-049-520-658 345-049-521-104 345-049521-107 345-049-521-112 345-049-521-188 345-049-521-478 345-049-521-488 345-049-521-612 345-049-523-102
345-049-523-404 345-049-523-488 345-049-523-604 345-049-524-402 345-049-524-403 345-049-524-458 345049-524-658 345-049-540-103 345-049-540-108 345-049-540-178 345-049-540-478 345-049-540-602 345-049540-607 345-049-541-178 345-049-541-404 345-049-541-408 345-049-541-603 345-049-541-608 345-049-542-104
345-049-542-188 345-049-542-688 345-049-544-107 345-049-544-158 345-049-544-412
很抱歉,暂时无法提供与“345-045-500-688”相匹配的价格&库存,您可以联系我们找货
