QT216S-24.576MAAV-T
QT216S-24.576MAAV-T
    QST(矽睿)
    SMD2016_4P
    无源晶振 24.576MHz ±30ppm 8pF 90Ω -20℃~+70℃
QT216S-24.576MAAV-T 数据手册
QT216S MHz Crystal Fuel The Digital World Features ● ● ● ● ● Applications Frequency range : 16MHz to 66MHz Ceramic SMD package Seam sealing External dimensions (mm) L : 2.0 x W : 1.6 x H : 0.5 RoHS compliant & Pb free ● ● ● ● ● Bluetooth, Wireless LAN Microprocessor Mobile phone, Computer, Modem Audio, Video Consumer products Electrical Characteristics Item QT216S Frequency Range F0 16MHz ~ 66MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 3pF Max. Drive Level DL 1 ~ 200μW (50μW Typ.) Load Capacitance CL 6pF, 8pF, 9pF 10pF, 12pF, 18pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 16 ~ 19.2 MHz 19.2 ~ 30 MHz 30 ~ 66 MHz Rev. 1.07 120Ω Max. 90Ω Max. 50Ω Max. Page 1 www.qstproducts.com QT216S MHz Crystal Fuel The Digital World Dimensions Ordering Information QT216S - 24.000M A H E Frequency in Hz T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E - B V C Q E J ± 30 ppm ± 20 ppm ± 10 ppm 6 pF 8 pF 9 pF 10 pF 12 pF 18 pF Frequency Stability (over Temp.) A D E T H I K Rev. 1.07 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 30 ppm ± 20 ppm ± 60 ppm ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.qstproducts.com QT216S MHz Crystal Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.07 60 sec Page 3 Time (sec) www.qstproducts.com
QT216S-24.576MAAV-T
物料型号:QST QT216S MHz Crystal
器件简介:QST品牌的QT216S是一款MHz级别的晶体振荡器,用于数字世界。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 频率范围:16MHz 至 66MHz - 频率容差:±30ppm, ±20ppm, ±10ppm(在25°C时) - 频率稳定性:在不同温度范围内变化 - 工作温度范围:-20°C至+70°C,-30°C至+85°C,-40°C至+85°C,-40°C至+125°C - 并联电容:最大3pF - 驱动电平:1~200mW(典型值50mW) - 负载电容:6pF, 8pF, 9pF, 10pF, 12pF, 18pF - 老化:第一年在25°C±3°C时最大±3ppm - 存储温度范围:-55°C至+125°C
功能详解:文档中未提供详细的功能解释。
应用信息:适用于蓝牙、无线局域网、微处理器、手机、计算机、调制解调器、音频、视频和消费产品。
封装信息:尺寸为2.0mm x 1.6mm x 0.5mm,符合RoHS标准,无铅。
QT216S-24.576MAAV-T 价格&库存
很抱歉,暂时无法提供与“QT216S-24.576MAAV-T”相匹配的价格&库存,您可以联系我们找货
QT216S-24.576MAAV-T
  • 3000+2.783743000+0.36015
  • 6000+2.668666000+0.34527
  • 9000+2.603579000+0.33684
  • 15000+2.5238815000+0.32653
  • 21000+2.4727421000+0.31992
  • 30000+2.4196930000+0.31306
库存:3000
QT216S-24.576MAAV-T
  • 1+4.505781+0.58295
  • 10+3.9292110+0.50835
  • 25+3.7156625+0.48072
  • 50+3.5636250+0.46105
  • 100+3.41628100+0.44199
  • 250+3.23028250+0.41793
  • 500+3.09677500+0.40065
  • 1000+2.968661000+0.38408
库存:3000
