QT252S-38.400MAHV-T
QT252S-38.400MAHV-T
    QST(矽睿)
    SMD2520_4P
    无源晶振 38.4MHz ±30ppm 8pF 60Ω -40℃~+85℃
QT252S-38.400MAHV-T 数据手册
QT252S MHz Crystal Fuel The Digital World Features ● ● ● ● ● Applications Frequency range : 12MHz to 66MHz Ceramic SMD package Seam sealing External dimensions (mm) L : 2.5 x W : 2.0 x H : 0.55 RoHS compliant & Pb free ● ● ● ● ● Bluetooth, Wireless LAN Microprocessor Mobile phone, Computer, Modem Audio, Video Consumer products Electrical Characteristics Item QT252S Frequency Range F0 12MHz ~ 66MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 3pF Max. Drive Level DL 1 ~ 200μW (100μW Typ.) Load Capacitance CL 6pF, 8pF, 10pF 12pF, 16pF, 18pF, 20pF Aging (at 25°C ± 3°C, first year) Faging ±3ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C Note [1] Notes: [1] Please contact us for low aging +/-1ppm grade crystals. Motional Resistance (ESR) Fundamental 12 ~ 13 MHz 14 ~ 30 MHz 30 ~ 66 MHz Rev. 1.08 150Ω Max. 100Ω Max. 60Ω Max. Page 1 www.qstproducts.com QT252S MHz Crystal Fuel The Digital World Dimensions (Unit: mm) Ordering Information QT252S - 24.000M A H E Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E B V Q E I J K ± 30 ppm ± 20 ppm ± 10 ppm 6 pF 8 pF 10 pF 12 pF 16 pF 18 pF 20 pF Frequency Stability (over Temp.) A D E T H I K Rev. 1.08 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 30 ppm ± 20 ppm ± 60 ppm ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.qstproducts.com QT252S MHz Crystal Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.08 60 sec Page 3 Time (sec) www.qstproducts.com
QT252S-38.400MAHV-T
物料型号:QT252S MHz Crystal
器件简介:QST的QT252S是一款用于数字世界的晶体振荡器,具有广泛的频率范围和陶瓷SMD封装。
引脚分配:文档中提供了晶体振荡器的引脚分配图,但未提供具体的引脚功能描述。
参数特性: - 频率范围:12MHz至66MHz - 频率容差:±30ppm, ±20ppm, ±10ppm(在25°C时) - 频率稳定性:在不同温度范围内变化,从±30ppm至±60ppm - 工作温度范围:-20°C至+70°C,-40°C至+85°C,-40°C至+125°C - 并联电容:最大3pF - 驱动电平:1至200mW(典型值100mW) - 负载电容:6pF至20pF - 老化率:第一年最大±3ppm - 存储温度范围:-55°C至+125°C
功能详解:文档提供了晶体振荡器的电气特性和运动电阻(ESR)的详细描述。
应用信息:QT252S晶体振荡器适用于蓝牙、无线局域网、微处理器、手机、计算机、调制解调器、音频、视频和消费产品。
封装信息:晶体振荡器采用陶瓷SMD封装,具有密封接缝,外部尺寸为长2.5mm、宽2.0mm、高0.55mm。
订购信息:提供了订购QT252S晶体振荡器时需要的频率、包装方法、负载电容和频率容差等信息。
回流焊温度曲线:提供了焊接晶体振荡器时的熔化点和峰值温度建议。
QT252S-38.400MAHV-T 价格&库存
很抱歉,暂时无法提供与“QT252S-38.400MAHV-T”相匹配的价格&库存,您可以联系我们找货
