QT252T
Temperature Sensing Crystal
Fuel The Digital World
Features
Applications
Frequency range : 12MHz to 54MHz
SMD seam sealing ceramic package
Crystal with thermally coupled
temperature sensor (Thermistor)
External dimensions (mm)
L : 2.5 x W : 2.0 x H : 1.0
RoHS compliant & Pb free
Mobile communications
WiFi, Bluetooth
GPS
Mobile phone, Tablet, Wearables
Electrical Characteristics
Item
QT252T
Conditions
Frequency Range
F0
12MHz ~ 54MHz
Frequency Tolerance
Ftol
±10 ppm
at 25°C
Frequency Stability over
Operating Temperature Range
Fstab
±10 ppm
refer to 25°C
TOTR
-30°C ~ +85°C
Shunt Capacitance
C0
3 pF Max.
Drive Level
DL
1μW ~ 200μW (50μW Typ.)
Load Capacitance
CL
6pF, 7pF, 8pF
Aging
Faging
±1 ppm Max.
Storage Temperature Range
TSTR
-40°C ~ +105°C
Resistance
100 KΩ ± 1%
at 25°C; Note [1]
B-constant
4250 K ± 1%
25°C~+50°C; Note [1]
at 25°C, first year
NTC Thermistor
Notes:
[1] Please contact us for other specifications.
Motional Resistance (ESR)
Fundamental
12 ~ 13 MHz
14 ~ 30 MHz
30 ~ 54 MHz
Rev. 1.01
150Ω Max.
100Ω Max.
60Ω Max.
Page 1
www.qstproducts.com
QT252T
Dimensions
Block diagram and Pin function
Symbol
Function
Pin 1
XT1
XTAL Terminal 1
Pin 2
RT2
Thermistor Terminal 2
Pin 3
XT2
XTAL Terminal 2
Pin 4
RT1
Thermistor Terminal 1
Note:
(a) Pin 2 is connected to the metal lid and thermistor
(b) Pin 4 is connected to the thermistor only
(c) RT2 is recommended to GND
Recommended pad layout
(Unit: mm)
Ordering Information
QT252T
19.200M
E T V - T
Frequency in Hz
Packaging Method
available frequencies
T
Tape & Reel
Load Capacitance
Frequency Tolerance (at 25°C)
E
± 10 ppm
B
Y
V
6 pF
7 pF
8 pF
Frequency Stability (over Temp.)
T
Rev. 1.01
± 10 ppm ( -30°C ~ +85°C )
Page 2
www.qstproducts.com
QT252T
Packing
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min.
Peak temperature : 260°C ± 10°C, 10 sec. Min.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.01
60 sec
Page 3
Time (sec)
www.qstproducts.com
QT252T-26.000METY-T 价格&库存
很抱歉,暂时无法提供与“QT252T-26.000METY-T”相匹配的价格&库存,您可以联系我们找货
