8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
C
1811
D
2828
DESCRIPTION
DATE
UPDATE VIEWS, POSI. CHART, TOLERANCE, ADD
1/15/2009
PCB LAYOUT
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T 04/09/2015
MATERIAL
BY
JH
LH
F
F
B±.014 [ .35]
E
E
.315 8.00
D
A±.010 [ .25]
.079±.002 2.00±0.05
D
.236±.004 6.00±0.10
.079±.002 2.00±0.05
.020±.002 0.50±0.05
.173 4.40
(REF.)
.327±.008 8.30±0.20
.059 1.50
.094±.008 2.40±0.20
C
02-20, 0.20mm MAX.
21-40, 0.30mm MAX.
C
A±.004 [ .10]
.079±.002 2.00±0.05
.031±.002 0.80±0.05
.079±.002 2.00±0.05
B
A
B
.236±.004 6.00±0.10
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: BRASS.
3. CONTACT PLATING: GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMPS.
5. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: AC 500V.
8. OPERATING TEMPERATURE: -40° C TO +105° C.
9. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY.
8
7
6
RECOMMENDED PCB LAYOUT
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
1
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
09/20/2006 YCH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER, MALE 2mm CC, 4 ROWS, ST
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 8:1
3
2
NRPNxx4RCCN-RC
DWG. NO.
10734
SHEET 1 OF 1
1
REV
D
FILE NAME: 10734, NRPNxx4RCCN-RC
A
很抱歉,暂时无法提供与“NRPN224RCCN-RC”相匹配的价格&库存,您可以联系我们找货
