BC020-04-A-0200-0300-L-D
    GCT
    插件,P=1mm
    排针 间距:1mm 1x4P 直插
BC020-04-A-0200-0300-L-D 数据手册
No. of Contacts H B±0.25 1.00 .50 Ø0 G 1.00±0.08 Recommended PCB Layout A±0.10 F 1.27 D C±0.2 Plating Contact Area: Gold Flash or Tin Electrical Current Rating: 1 Amp per pin Contact Resistance: 20 mΩ max. Insulating Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 300V AC 0.30 sq. Pin C Ordering Grid BC020 XX X XXXX XXXX L No. of Contacts 02 to 40 B A or specify custom Post Height eg. 0250 = 2.50mm (Maximum 0500=5.00mm) (Minimum 0050=0.50mm) 1 Request Samples and Quotation Packing Options G = Plastic Box (Standard) D = Tube E = Tube with Cap Contact Plating A = Gold Flash All Over (Standard) C = Tin All Over Dimension C (1/100mm) (Post Height) 0200 = 2.00mm (Standard) 0240 = 2.40mm (Standard) 0380 = 3.80mm (Standard) X Insulator Material L = LCP (Standard) Dimension D (1/100mm) (Tail Length) 0160 = 1.60mm (Standard) 0300 = 3.00mm (Standard) or specify custom Tail Length eg. 0250 = 2.50mm (Maximum 0500=5.00mm) (Minimum 0050=0.50mm) 2 3 Specifications Material Insulator: LCP, UL94V-0, Black Contact: Copper Alloy D±0.2 1.00 10mm Maximum 1.00±0.08 E 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 Mechanical & Environmental Operating Temperature: -40°C to +105°C Soldering Process: IR Reflow: 260°C for 10 sec. Wave: 250°C for 5-10 sec Manual Solder: 350°C for 3-5 sec Mates with(Subject to pin length) BC065 BC070 BC075 Part Number Product Description BC020 1.0mm Pitch Pin Header, Single Row, Through-Hole, Vertical Drawing Date 20th May 2008 By Detail 4 Revision Date 5 CC Tolerances (Except as Noted) BC020 E PCN E2 18/08/17 X. ± 0.30 X.° ± 5° X.X° ± 3° X.X ± 0.20 X.XX ± 0.15 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 Dimensions A 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.00 11.00 12.00 13.00 14.00 15.00 16.00 17.00 18.00 19.00 20.00 21.00 22.00 23.00 24.00 25.00 26.00 27.00 28.00 29.00 30.00 31.00 32.00 33.00 34.00 35.00 36.00 37.00 38.00 39.00 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE B 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.00 11.00 12.00 13.00 14.00 15.00 16.00 17.00 18.00 19.00 20.00 21.00 22.00 23.00 24.00 25.00 26.00 27.00 28.00 29.00 30.00 31.00 32.00 33.00 34.00 35.00 36.00 37.00 38.00 39.00 40.00 www.gct.co Not to Scale Drawn By ASE 8 Sheet No. 1/1
BC020-04-A-0200-0300-L-D 价格&库存
很抱歉,暂时无法提供与“BC020-04-A-0200-0300-L-D”相匹配的价格&库存,您可以联系我们找货
  • 1+9.030311+1.16888
  • 10+7.6361810+0.98843
  • 149+6.30656149+0.81632
  • 596+5.71805596+0.74015
  • 1043+5.496641043+0.71149
  • 5066+4.916775066+0.63643
  • 10132+4.6822910132+0.60608
库存:963
