LFSPXO009682REEL
LFSPXO009682REEL
    IQD
    SMD2621_4P
    有源晶振 32.768kHz1.8V -40℃~+85℃ CMOS
LFSPXO009682REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO009682Reel Customer Part: Description Suitable for real time clock applications 32.768kHz output crystal oscillators Ceramic package with a seam sealed metal lid, hermetically sealed Model CFPS-107 Model Issue number 5 Frequency Parameters Frequency 32.7680kHz Frequency Stability ±50.00ppm Operating Temperature Range Ageing -40.00 to 85.00°C ±3ppm max per year Electrical Parameters 1.8V ±5% Supply Voltage Current Draw 1.500mA Outline (mm) Output Details CMOS 15pF max 50.0ns max 40/60% Output Compatibility Drive Capability Rise and Fall Time Duty Cycle Output Control Standby Operation: Logic ‘1’ to pad 1 enables oscillator output Logic ‘0’ to pad 1 disables oscillator output; when disabled the oscillator output goes to the high impedance state No connection to pad 1 enables oscillator output Start-up Time: 35ms max 2ms typ to 90% of final amplitude (under ideal conditions @ 25°C) Standby Current: 10µA max, 1.35µA typ @ 25°C Test Circuit Environmental Parameters Storage Temperature Range: –55 to 125°C Shock: MIL-STD-883F, Method 2002.4: 1500G, 0.5ms, 3 times in each of 3 mutually perpendicular planes. Vibration: MIL-STD-883F, Method 2007.3: 20G (20Hz-2000Hz), 1.52mm amplitude Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 28 Nov 21 13:03 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO009682Reel Customer Part: Alternative packing option available Wave Form Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 28 Nov 21 13:03 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFSPXO009682REEL
1. 物料型号:CFPS-107 和 CFRS-107 2. 器件简介:适用于实时时钟应用的32.768kHz输出晶体振荡器,采用陶瓷封装和密封金属盖,密封性良好。 3. 引脚分配: - 1. 待机操作:CMOS驱动能力,最大15pF - 2. GND:地线 - 3. 输出:振荡器输出 - 4. +Vs:电源正极 4. 参数特性: - 频率稳定性:±50.00ppm(-40.00至85.00°C) - 老化:每年最大±3ppm - 工作温度范围:-40.00至85.00°C - 供电电压:1.8V ±5% - 工作电流:1.500mA(包括夹具和设备电容) 5. 功能详解: - 输出控制:逻辑“1”使能振荡器输出,逻辑“0”禁用输出,无连接时使能输出 - 启动时间:最大35ms,典型2ms达到最终幅度的90%(在25°C的理想条件下) - 待机电流:最大10µA,典型1.35µA(在25°C) 6. 应用信息:适用于实时时钟应用 7. 封装信息: - 封装类型:LFSPXO009682Reel - 包装细节:符合EIA-481-D标准的带式卷装,每卷1000个 8. 环境参数: - 存储温度范围:-55至125°C - 冲击:MIL-STD-883F,方法2002.4:1500G,0.5ms,每个相互垂直的平面上3次 - 振动:MIL-STD-883F,方法2007.3:20G(20Hz-2000Hz),1.52mm振幅 9. 制造细节: - 端接:NiAu - 无铅回流温度:260°C,10秒 - 符合RoHS指令2015/863/EU和REACH法规 10. 联系方式:提供了美国、法国、英国和德国的销售办公室联系电话和电子邮件。
LFSPXO009682REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO009682REEL”相匹配的价格&库存,您可以联系我们找货
