S7A33025-100.000-P-X-R 数据手册
RoHS Compliant
Pb - Lead Free
Ltr
Re
Appr
Date
isions
Electrical Specifications:
Frequency Range
13.500 - 160.000
±100
±50
±25
±3
-20 to +70
-40 to +85
-40 to +125
-55 to +125
Frequency Stability over Temperature
Aging per Year
Standard
Extended
Automotive
Operating Temperature Range
Storage Temperature Range
Supply Voltage
Input Current
Output Voltage
13.500 - 160.000Mhz
Logic High (Voh)
Logic Low (Vol)
PPM Max
ºC
3.3 ± 5%
70
2.275
1.68
45 to 55
LVPECL - Complimentary Output
50
Output Symmetry
Output Type
Output Load
Rise and Fall Time
2.5 ± 5%
70
1.475
1.095
MHz
13.500 - 99.999Mhz
100.000 - 160.000Mhz
1
0.5
Enable-Disable Function
Enable High Input Voltage
Enable Low Input Voltage
Phase Jitter (12 KHz to 20 MHz)
1
Ω
1
0.5
ns Max
Q Pin 4 - QN Pin 5
Operating
High Impedance
2.31
0.99
Vdd Min
Vdd Max
ps RMS
Tri-State
INH - Pin 1
High - Pin 1
Low - Pin 1
1.75
0.75
Vdd
mA Max
Vdd Min
Vdd Max
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply
voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C.
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
Re iew: EG
MK
Appr:
1/4
Page:
Date: Sept 6, 2014
Clock Oscillator
5.0 x 7.0 mm Surface Mount - 6 Pad
General Product Specification
Part Number:
S7A LVPECL Series
www.aker-usa.com
Solder Pattern:
Mechanical Outline:
C1: 0.01 uF or 0.1 uF decoupling capacitor is
recommended.
C2: By-Pass capacitor for noise suppression.
Contact Aker for suggested values.
*Package Height:
1.4 mm Max for 13.500 to 160.000 MHz
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Pad Connection:
Pin Connection
1- INH
2- NC
3- GND
4- Output - Q
5- Comp. Output - QN
6- Vdd
Top View
Page:
2/4
Date:
Sept 6, 2014
P/N:
S7A LVPECL Series
.w aker-usa.com
AKER
AKER
+0.1
1.7 -0.0
AKER
AKER
A
A
B
8.0 ¡ Ó0.1
Ko:2.0
Ao:5.4
5¢X(max)
Dimensions
are millimeters.
A-A SECTION
Solder Reflow Characteristics:
Page:
3/4
B-B SECTION
Pin #1
5¢X(max)
7.5 ¡ Ó0.1
B
0.3 ¡ Ó0.05
Bo:7.9
4.0 ¡ Ó0.1
16.0 ¡ Ó0.3
+0.1
1.5 -0.0
2.0 ¡ Ó0.1
1.75 ¡ Ó0.1
Carrier Tape Dimensions:
Date: Sept 7, 2014
P/N:
S7A LVPECL Series
www.aker-usa.com
How to build a Part Number:
Series
Package
S
7A
Parameter
7.0 x 5.0 mm - 6 Pad
Supply Voltage
25
33
+2.5 Vdd ± 5%
+3.3 Vdd ± 5%
Temperature Stability
10
05
025
±100 PPM
±50 PPM
±25 PPM
Frequency
Output Load
Temperature Range
Packaging
13.500 - 160.000
P
See Notes
X
X1
M
R
MHz
LVPECL
-20 to +70 ºC
-40 to +85 ºC
-40 to +125 ºC
250pcs Ree1
1000pcs Reel
Part Number Example:
S7A3305-156.250-P-X-R
S7A: 5.0 x 7.0 mm SMD Package - 6 Pad
33: +3.3 Vdd Supply Voltage
05: ±50 PPM Temperature Stability
156.250 MHz Nominal Frequency
P: LVPECL Output
X: -40 to + 85° C Extended Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Standard Temperature Range does not need to be included in Part Number description.
*25PPM not available in X1 temp range
2- Product is shipped in Tape and Reel configuration.
3- Quantities less than 250pcs are shipped in tape.
4- Specification subject to change without notice.
Page:
4/4
Date: Sept 6, 2014
P/N:
S7A LVPECL Series
www.aker-usa.com
S7A33025-100.000-P-X-R 价格&库存
很抱歉,暂时无法提供与“S7A33025-100.000-P-X-R”相匹配的价格&库存,您可以联系我们找货
