S32505T-27.000-X-R
S32505T-27.000-X-R
    AKER(安碁科技)
    SMD3225_4P
    有源晶振 27.000000MHz 2.5V -40℃~+85℃ HCMOS
S32505T-27.000-X-R 数据手册
Revisions Ltr Date Appr RoHS Compliant Pb - Lead Free Electrical Specifications: Frequency Range 1.000 ~ 156.250 MHz Frequency Stability ±20 ~ ±100 ppm ±3 ppm Max. Aging per Year Operating Temperature Range Standard -10 ~ +70 Extended -40 ~ +85 -55 ~ +125 Storage Temperature Range 1.8 ± 5% 2.5 ± 5% 3.3 ± 10% 1.000 to 9.999MHz 5 6 7 7 10.000 to 19.999MHz 6 8 7 7 20.000 to 31.999MHz 6 8 12 12 32.000 to 54.000MHz 15 20 20 20 54.001 to 79.999MHz 20 25 25 25 80.000 to 156.250MHz 25 30 30 30 Supply Voltage Input Current Output Voltage 1.62 ~ 3.63 VDD mA Max. Logic High (Voh) 90% VDD Min. Logic Low (Vol) 10% VDD Max. Output Symmetry (Duty Cycle) Standard 40 ~ 60 ( at 50% VDD) Tight 45 ~ 55 ( at 50% VDD) % Output Level CMOS Output Load 15 Rise and Fall Time °C pF Max. 1.000 to 9.999MHz 7 5 5 7 10.000 to 19.999MHz 7 5 5 7 20.000 to 31.999MHz 6 5 5 6 32.000 to 54.000MHz 6 5 5 6 54.001 to 79.999MHz 7 6 5 7 80.000 to 156.250MHz 7 6 5 7 ns Max. 1 Phase Jitter (12 KHz to 20 MHz) ps Max. RMS Tri-State Enable-Disable Function ms Max. 10 Start Up Time Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change, output load change, shock, vilbration, and 1st year aging at +25°C. Specification Title: No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan All dimensions are millimeters. CAD: TCR Review: EG Appr: JL Page: 1/4 Date: July 1,2020 HCMOS Output Clock Oscillator Miniature 3.2 x 2.5 millimeter Surface Mount General Product Specification Part Number: www.aker-usa.com S3 Series Mechanical Outline and Solder Pad Layout: 3.2 ± 0.15 Metal Lid #3 #4 2.5 ± 0.15 Ceramic Base AKER #1 #2 1.2 Max. 1.2 2.2 #4 #3 1.0 0.65 1.6 #2 1.0 #1 0.9 1.4 Pin Connection PIN No. #1 Enable/Disable Function PIN #1 Connection Enable/Disable #2 GND #3 Output #4 VDD PIN #3 HIGH or OPEN Operating LOW High Impedance Package is Seam Sealed Ceramic-Metal. Terminator Pads are Ni/Au. Dimensions are millimeters. Page: 2/4 Date : July 1,2020 www.aker-usa.com P/N: S3 Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION AKER AKER AKER AKER AKER AKER AKER AKER A 3.4 Pin #1 A 8.0 3.5 B B 1.0 4.0 1.4 2.7 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date : July 1,2020 www.aker-usa.com P/N: S3 Series How to build a Part Number: Series Package S 3 Parameter 3.2 x 2.5 mm Supply Voltage 33 25 18 M +3.3 VDD ± 10% +2.5 VDD ± 5% +1.8 VDD ± 5% +1.62 ~ +3.63 VDD Temperature Stability 10 05 03 025 ±100 ppm ±50 ppm ±30 ppm ±25 ppm Duty Cycle See Notes T 40%~60% 45%~55% Frequency 1.000~156.250 MHz Temperature Range See Notes X -10 ~ +70 °C -40 ~ +85 °C - Packaging M R R3 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: S33305T-50.000-X-R S3: 3.2 x 2.5 mm SMD Package 33: +3.3±10% VDD Supply Voltage 05: ±50 ppm Temperature Stability T: 45%~55% Tight Symmetry 50.000 MHz Nominal Frequency X: -40 ~ + 85°C Extended Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape only. 4- Specification subject to change without notice. Page: 4/4 Date : July 1,2020 www.aker-usa.com P/N: S3 Series
S32505T-27.000-X-R
1. 物料型号:S3系列。 2. 器件简介:这是一个HCMOS输出时钟振荡器,具有迷你3.2 x 2.5毫米的表面贴装封装。 3. 引脚分配: - #1:使能/禁用 - #2:地(GND) - #3:输出 - #4:电源(VDD) 4. 参数特性: - 频率范围:1.000~156.250 MHz - 频率稳定性:+20~±100 ppm最大 - 老化率:每年±3 ppm . 工作温度范围:标准-10~+70°C,扩展-40~+85°C - 存储温度范围:-55~+125°C - 供电电压:1.8±5%至3.3±10% VDD - 输入电流:在不同频率下从5 mA到30 mA不等 - 输出电压:逻辑高(Voh)至少90% VDD,逻辑低(Vol)最大10% VDD - 输出对称性(占空比):标准40~60%(在50% VDD时),紧密45~55%(在50% VDD时) - 输出负载:最大15 pF - 上升和下降时间:在不同频率下从5 ns到7 ns不等 - 相位抖动(12 kHz至20 MHz):最大1 ps RMS - 使能/禁用功能:三态 - 启动时间:最大10 ms 5. 功能详解:包括详细的电气规格和温度稳定性说明。 6. 应用信息:文档提供了如何构建部件编号的指南。 7. 封装信息:包括机械轮廓、焊盘布局、载体胶带尺寸和焊接再流特性。
S32505T-27.000-X-R 价格&库存
很抱歉,暂时无法提供与“S32505T-27.000-X-R”相匹配的价格&库存,您可以联系我们找货
S32505T-27.000-X-R
