LFTVXO079055
LFTVXO079055
    IQD
    SMD-4
    有源晶振 1.8V SMD-4
LFTVXO079055 数据手册
IQXT-205-2 IQXT-205-2 is a 2.0 x 1.6mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator (VCTCXO) in a hermetically sealed package. Model Name Description IQXT-205-2-18 A 1.8V version IQXT-205-2-25 A 2.5V version IQXT-205-2-28 A 2.8V version IQXT-205-2-30 A 3.0V version IQXT-205-2-33 A 3.3V version IQD Frequency Products Ltd ■ Station Road ■ Crewkerne ■ Somerset ■ TA18 8AR ■ United Kingdom Tel: +44 (0)1460 270200 ■ Fax: +44 (0)1460 72578 ■ Email: info@iqdfrequencyproducts.com Registered in England No: 06478545 ■ VAT Registration No: GB932 4502 45 VCTCXO Specification IQXT-205-2-18 ISSUE 1; March 2018 Description IQXT-205-2-18 is a 2.0 x 1.6mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator (VCTCXO) in a hermetically sealed package. Developed frequencies: 16.2, 16.368, 16.369, 19.2, 20.0, 24.0, 25.0, 26.0, 27.456, 28.925, 28.974, 30.0, 32.0, 33.6, 38.4, 48.0, 50.0 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm to ±2.00ppm ±1ppm max per year @ 25°C ±3°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. Supply Voltage Variation: @ ±5% change for ±0.5ppm stability: ±0.1ppm max @ ±5% change for ±2.0ppm stability: ±0.2ppm max Load Variation: @ ±10% change for ±0.5ppm stability: ±0.1ppm max @ ±10% change for ±2.0ppm stability: ±0.2ppm max Short Term Stability (Allan variance): ±1ppb max (Tau = 0.1s) IR Reflow Resistance (ref to frequency before reflow): ±1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 1.8V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Control Voltage: -0.6V to Vs+0.6V Frequency Adjustment Pulling ±8ppm min to ±13ppm max Control Voltage 0.9V ±0.8V Slope: Positive Operating Temperature Ranges -30 to 85°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Harmonic Distortion: -5.0dBc max Environmental Parameters Storage Temperature Range: -40 to 85°C Outline (mm) VCTCXO Specification IQXT-205-2-18 ISSUE 1; March 2018 Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 20.0MHz IQXT-205-2-18 Clipped Sine ±0.5ppm –30 to 85C 1.8V ±8ppm min to ±13ppm max Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Cutt Pack Size: 100 Cut tape Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Electrical Specification - maximum limiting values 1.8V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -30 to 85 ±0.5 1.5 - - 30.0MHz 39.999999MHz -30 to 85 ±0.5 1.7 - - 40.0MHz 52.0MHz -30 to 85 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. VCTCXO Specification IQXT-205-2-25 ISSUE 1; March 2018 Description IQXT-205-2-25 is a 2.0 x 1.6mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator (VCTCXO) in a hermetically sealed package. Developed frequencies: 16.2, 16.368, 16.369, 19.2, 20.0, 24.0, 25.0, 26.0, 27.456, 28.925, 28.974, 30.0, 32.0, 33.6, 38.4, 48.0, 50.0 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm to ±2.00ppm ±1ppm max per year @ 25°C ±3°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. Supply Voltage Variation: @ ±5% change for±0.5ppm stability: ±0.1ppm max @ ±5% change for±2.0ppm stability: ±0.2ppm max Load Variation: @ ±10% change for ±0.5ppm stability: ±0.1ppm max @ ±10% change for ±2.0ppm stability: ±0.2ppm max Short Term Stability (Allan variance): ±1ppb max (Tau = 0.1s) IR Reflow Resistance (ref to frequency before reflow): ±1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 2.5V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Control Voltage: -0.6V to Vs+0.6V Frequency Adjustment Pulling ±9ppm min to ±15ppm max Control Voltage 1.25V ±1.0V Slope: Positive Operating Temperature Ranges -30 to 85°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Harmonic Distortion: -5.0dBc max Environmental Parameters Storage Temperature Range: -40 to 85°C Outline (mm) VCTCXO Specification IQXT-205-2-25 ISSUE 1; March 2018 Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 20.0MHz IQXT-205-2-25 Clipped Sine ±0.5ppm –30 to 85C 2.5V ±9ppm min to ±15ppm max Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Cutt Pack Size: 100 Cut tape Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Electrical Specification - maximum limiting values 2.5V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -30 to 85 ±0.5 1.5 - - 30.0MHz 39.999999MHz -30 to 85 ±0.5 1.7 - - 40.0MHz 52.0MHz -30 to 85 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. VCTCXO Specification IQXT-205-2-28 ISSUE 1; March 2018 Description IQXT-205-2-28 is a 2.0 x 1.6mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator (VCTCXO) in a hermetically sealed package. Developed frequencies: 16.2, 16.368, 16.369, 19.2, 20.0, 24.0, 25.0, 26.0, 27.456, 28.925, 28.974, 30.0, 32.0, 33.6, 38.4, 48.0, 50.0 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm to ±2.00ppm ±1ppm max per year @ 25°C ±3°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. Supply Voltage Variation: @ ±5% change for±0.5ppm stability: ±0.1ppm max @ ±5% change for±2.0ppm stability: ±0.2ppm max Load Variation: @ ±10% change for ±0.5ppm stability: ±0.1ppm max @ ±10% change for ±2.0ppm stability: ±0.2ppm max Short Term Stability (Allan variance): ±1ppb max (Tau = 0.1s) IR Reflow Resistance (ref to frequency before reflow): ±1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 2.8V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Control Voltage: -0.6V to Vs+0.6V Frequency Adjustment Pulling ±9ppm min to ±15ppm max Control Voltage 1.4V ±1.0V Slope: Positive Operating Temperature Ranges -30 to 85°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Harmonic Distortion: -5.0dBc max Environmental Parameters Storage Temperature Range: -40 to 85°C Outline (mm) VCTCXO Specification IQXT-205-2-28 ISSUE 1; March 2018 Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 20.0MHz IQXT-205-2-28 Clipped Sine ±0.5ppm –30 to 85C 2.8V ±9ppm min to ±15ppm max Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Pack Style: Cutt Pack Size: 100 Cut tape Electrical Specification - maximum limiting values 2.8V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -30 to 85 ±0.5 1.5 - - 30.0MHz 39.999999MHz -30 to 85 ±0.5 1.7 - - 40.0MHz 52.0MHz -30 to 85 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. VCTCXO Specification IQXT-205-2-30 ISSUE 1; March 2018 Description IQXT-205-2-30 is a 2.0 x 1.6mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator (VCTCXO) in a hermetically sealed package. Developed frequencies: 16.2, 16.368, 16.369, 19.2, 20.0, 24.0, 25.0, 26.0, 27.456, 28.925, 28.974, 30.0, 32.0, 33.6, 38.4, 48.0, 50.0 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm to ±2.00ppm ±1ppm max per year @ 25°C ±3°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. Supply Voltage Variation: @ ±5% change for±0.5ppm stability: ±0.1ppm max @ ±5% change for±2.0ppm stability: ±0.2ppm max Load Variation: @ ±10% change for ±0.5ppm stability: ±0.1ppm max @ ±10% change for ±2.0ppm stability: ±0.2ppm max Short Term Stability (Allan variance): ±1ppb max (Tau = 0.1s) IR Reflow Resistance (ref to frequency before reflow): ±1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 3.0V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Control Voltage: -0.6V to Vs+0.6V Frequency Adjustment Pulling ±9ppm min to ±15ppm max Control Voltage 1.5V ±1.0V Slope: Positive Operating Temperature Ranges -30 to 85°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Harmonic Distortion: -5.0dBc max Environmental Parameters Storage Temperature Range: -40 to 85°C Outline (mm) VCTCXO Specification IQXT-205-2-30 ISSUE 1; March 2018 Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 20.0MHz IQXT-205-2-30 Clipped Sine ±0.5ppm –30 to 85C 3.0V ±9ppm min to ±15ppm max Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Cutt Pack Size: 100 Cut tape Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Electrical Specification - maximum limiting values 3.0V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -30 to 85 ±0.5 1.5 - - 30.0MHz 39.999999MHz -30 to 85 ±0.5 1.7 - - 40.0MHz 52.0MHz -30 to 85 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. VCTCXO Specification IQXT-205-2-33 ISSUE 1; March 2018 Description IQXT-205-2-33 is a 2.0 x 1.6mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator (VCTCXO) in a hermetically sealed package. Developed frequencies: 16.2, 16.368, 16.369, 19.2, 20.0, 24.0, 25.0, 26.0, 27.456, 28.925, 28.974, 30.0, 32.0, 33.6, 38.4, 48.0, 50.0 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm to ±2.00ppm ±1ppm max per year @ 25°C ±3°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. Supply Voltage Variation: @ ±5% change for±0.5ppm stability: ±0.1ppm max @ ±5% change for±2.0ppm stability: ±0.2ppm max Load Variation: @ ±10% change for ±0.5ppm stability: ±0.1ppm max @ ±10% change for ±2.0ppm stability: ±0.2ppm max Short Term Stability (Allan variance): ±1ppb max (Tau = 0.1s) IR Reflow Resistance (ref to frequency before reflow): ±1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 3.3V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Control Voltage: -0.6V to Vs+0.6V Frequency Adjustment Pulling ±9ppm min to ±15ppm max Control Voltage 1.65V ±1.0V Slope: Positive Operating Temperature Ranges -30 to 85°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Harmonic Distortion: -5.0dBc max Environmental Parameters Storage Temperature Range: -40 to 85°C Outline (mm) VCTCXO Specification IQXT-205-2-33 ISSUE 1; March 2018 Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 20.0MHz IQXT-205-2-33 Clipped Sine ±0.5ppm –30 to 85C 3.3V ±9ppm min to ±15ppm max Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Pack Style: Cutt Pack Size: 100 Cut tape Electrical Specification - maximum limiting values 3.3V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -30 to 85 ±0.5 1.5 - - 30.0MHz 39.999999MHz -30 to 85 ±0.5 1.7 - - 40.0MHz 52.0MHz -30 to 85 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. Sales Office Contact Details: UK: +44 (0)1460 270200 Germany: 0800 1808 443 France: 0800 901 383 USA: +1.760.318.2824 Printed on 22 Mar 18 10:10 using Model Data Sheet V1.2550 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 11 of 11
LFTVXO079055 价格&库存
很抱歉,暂时无法提供与“LFTVXO079055”相匹配的价格&库存,您可以联系我们找货
LFTVXO079055
  • 3000+27.684913000+3.57668
库存:4928
LFTVXO079055
  • 1+45.089171+5.82517
  • 10+39.1639010+5.05967
  • 25+37.0340425+4.78451
  • 50+35.5033150+4.58675
  • 100+34.03530100+4.39710
  • 250+32.33825250+4.17785
库存:4928
