RBB92DHRQ-S378
RBB92DHRQ-S378
    SULLINS
    CONN PCI CARDEDGE FEMALE 184POS
RBB92DHRQ-S378 数据手册
High Density Card Edge .050” [1.27 mm] Contact Centers, .610” [15.49 mm] Insulator Height, [PCI] Dip Solder/Card Extender/SMT High Density Card Edge SPECIFICATIONS • • • • • • Industry Standard Part READOUT Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board PPS or PA9T insulator Molded-in key available High reliability/high cycle hairpin bellow contacts 1 Amp current rating per contact for contacts fully energized UL Flammability Rating: 94V-0 DUAL (D) DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. 3.940±.020 100.08±0.51 FIRST POSITION INDICATOR 3.626±.010 92.10±0.25 3.050 77.47 .500 12.70 (11 POSITIONS) .150 3.81 2.400 60.96 (49 POSITIONS) .370 9.40 .070 1.78 .590 14.99 .050 1.27 TYP. 2X 2.490 63.24 3.150 80.01 .125 3.18 THRU. 3.340±.015 84.84±0.38 .300 7.62 INSERTION DEPTH .610 15.49 .250 6.35 .018 X .012 [0.46 X 0.30] FITS .040 [1.02] MIN. 2.550 64.77 .575 14.61 2X .093[2.36] GBB60DHHD-S578, 60 (11/49) POSITIONS,32 BIT, 3.3 OR 5 VOLT 5.640±.020 143.26±0.51 FIRST POSITION INDICATOR .500 12.70 (11 POSITIONS) 5.326±.010 135.28±0.25 4.750 120.65 .150 3.81 2.400 60.96 (49 POSITIONS) 1.550 39.37 (32 POSITIONS) .150 3.81 .370 9.40 .590 14.99 .070 1.78 .050 1.27 TYP. 1.650 41.91 .050 1.27 2.490 63.25 4.850 123.19 .125 3.18 THRU. 2X 5.040±.015 128.02±0.38 .300 7.62 INSERTION DEPTH .610 15.49 .250 6.35 .575 14.61 .018 X .012 [0.46 X 0.30] FITS .040 [1.02] MIN. 3X 2.550 64.77 .093[2.36] 1.700 43.18 GBB92DHHD-S330, 92 (11/49/32) POSITIONS, 64 BIT, 3.3 VOLT 5.640±.020 143.26±0.51 5.326±.010 135.28±0.25 4.750 120.65 FIRST POSITION INDICATOR .150 3.81 .500 12.70 (11 POSITIONS) .150 3.81 1.550 39.37 (32 POSITIONS) 2.400 60.96 (49 POSITIONS) .370 9.40 .050 1.27 TYP. 2.490 63.25 .070 1.78 .050 1.27 1.650 41.91 .590 14.99 2X .125 3.18 THRU. 4.850 123.19 5.040±.015 128.02±0.38 .300 7.62 INSERTION DEPTH .610 15.49 .250 6.35 .075 1.91 .018 X .012 [0.46 X 0.30] FITS .040 [1.02] MIN. 2.550 64.77 3X .093[2.36] .078 1.98 2.350 59.69 GBB92DHHD-S378, 92 (49/11/32) POSITIONS, 64 BIT, 5 VOLT 28 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com High Density Card Edge .050” [1.27 mm] Contact Centers, .610” [15.49 mm] Insulator Height, [PCI] Dip Solder/Card Extender/SMT Industry Standard Part PART NUMBER OPTIONS G B B 60 D HH D - S578 CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface B = .000010” Gold C = .000030” Gold Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte CONTACT CENTERS B = .050” [1.27 mm] NUMBER OF CONTACT POSITIONS *60 = 11/49 (32 Bit, 3.3 or 5 Volt) 92 = 11/49/32 (64 Bit, 3.3 Volt) 92 = 49/11/32 (64 Bit, 5 Volt) READOUT D = Dual *Turn connector or board 180° for 3.3 or 5 Volt High Density Card Edge MODIFICATION (Consult Factory) PCI WITH GUIDE POSTS *-S578 = 60 (11/49) Positions (32 Bit, 3.3 or 5 Volt) -S330 = 92 (11/49/32) Positions (64 Bit, 3.3 Volt) -S378 = 92 (49/11/32) Positions (64 Bit, 5 Volt) PCI WITHOUT GUIDE POSTS *-S621 = 60 (11/49) Positions (32 Bit, 3.3 or 5 Volt) -S329 = 92 (11/49/32) Positions (64 Bit, 3.3 Volt) -S250 = 92 (49/11/32) Positions (64 Bit, 5 Volt) MOUNTING STYLE D = Flush Mounting N = No Mounting T = Flush Mounting With Threaded Insert Q = Straddle Mount (Card Extender Only - Consult Factory) R = Metal Board lock TERMINATION TYPE HH = Staggered Dip Solder HR = Card Extender HF = Surface Mount HL = .250” [6.35 mm] X .160” [4.06 mm] Dip Solder HN = .100” [2.54 mm] X .125” [3.18 mm] Dip Solder MATERIALS (INSULATOR/CONTACT) G = PA9T/Phosphor Bronze R = PPS/Phosphor Bronze J = PA9T/Beryllium Copper A = PPS/Beryllium Copper Refer to Page 7 for Operating/Processing Temperatures FOR PC BOARD LAYOUTS REFER TO www.sullinscorp.com TERMINATION TYPE .160” [4.06] .125” [3.18] .160” [4.06] .125” [3.18] .100” [2.54] 3X .100” [2.54] ACCEPTS .062” [1.57] PCB STAGGERED DIP SOLDER (HH) CARD EXTENDER (HR) SURFACE MOUNT (HF) DIP SOLDER (HL) MOUNTING STYLE #4-40 .134” [3.40] .250” [6.35] .025” [0.64] NO MOUNTING EARS (N) FLUSH MOUNTING (D) DIP SOLDER (HN) .188” [4.78] Ø .125” [3.18] .250” [6.35] .100” [2.54] .250” [6.35] METAL BOARD LOCK (with no mounting ears) (R) .062” [1.57] .128” [3.25] Ø.078” [1.98] FLUSH MOUNTING WITH THREADED INSERT (T) STRADDLE MOUNT (Q) Formerly (Z) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 29
RBB92DHRQ-S378 价格&库存
很抱歉,暂时无法提供与“RBB92DHRQ-S378”相匹配的价格&库存,您可以联系我们找货
