S11805T-27.000-X-R
S11805T-27.000-X-R
    AKER(安碁科技)
    SMD2016_4P
    有源晶振 27.000000MHz 1.8V -40℃~+85℃ HCMOS
S11805T-27.000-X-R 数据手册
Revisions Ltr Date Appr RoHS Compliant Pb - Lead Free Electrical Specifications: Frequency Range 1.250 ~ 60.000 MHz Frequency Stability ±20 ~ ±100 ppm ±3 ppm Max. Aging per Year Operating Temperature Range Standard -10 ~ +70 Extended -40 ~ +85 -55 ~ +125 Storage Temperature Range 1.8 ± 5% 2.5 ± 5% 3.3 ± 10% 1.62 ~ 3.63 1.250 to 9.999MHz 3 4 5 5 10.000 to 19.999MHz 4 5 6 6 20.000 to 31.999MHz 5 6 7 7 32.000 to 60.000MHz 6 7 8 8 Supply Voltage Input Current Output Voltage VDD mA Max. Logic High (Voh) 90% VDD Min. Logic Low (Vol) 10% VDD Max. Output Symmetry (Duty Cycle) Standard 40 ~ 60 ( at 50% VDD) Tight 45 ~ 55 ( at 50% VDD) % Output Level CMOS Output Load 15 Rise and Fall Time °C pF Max. 1.250 to 9.999MHz 6 5 5 6 10.000 to 19.999MHz 6 5 5 6 20.000 to 31.999MHz 5 5 5 5 32.000 to 60.000MHz 5 5 5 5 ns Max. 1 Phase Jitter (12 KHz to 20 MHz) ps Max. RMS Tri-State Enable-Disable Function 10 Start Up Time ms Max. Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change, output load change, shock, vilbration, and 1st year aging at +25°C. Specification Title: No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan All dimensions are millimeters. CAD: TCR Review: EG Appr: JL Page: 1/4 Date: July 1,2020 HCMOS Output Clock Oscillator Ultra Miniature 2.0 x 1.6 millimeter Surface Mount General Product Specification Part Number: www.aker-usa.com S1 Series Mechanical Outline and Solder Pad Layout: 2.0 ± 0.15 1.6 ± 0.15 #4 Ceramic Base #3 Metal Lid AKER #1 #2 0.8 Max. 1.28 0.7 #2 #4 #3 0.78 0.48 0.5 0.98 #1 0.88 0.58 Pin Connection PIN No. #1 Enable/Disable Function PIN #1 Connection Enable/Disable #2 GND #3 Output #4 VDD PIN #3 HIGH or OPEN Operating LOW High Impedance Package is Seam Sealed Ceramic-Metal. Terminator Pads are Ni/Au. Dimensions are millimeters. Page: 2/4 Date : July 1,2020 www.aker-usa.com P/N: S1 Series 1.55 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION AKER AKER AKER AKER AKER AKER AKER AKER A 2.3 Pin #1 A 8.0 3.5 B B 1.1 4.0 0.9 1.9 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date : July 1,2020 www.aker-usa.com P/N: S1 Series How to build a Part Number: Series Package S 1 Parameter 2.0 x 1.6 mm Supply Voltage 33 25 18 M +3.3 VDD ± 10% +2.5 VDD ± 5% +1.8 VDD ± 5% +1.62 ~ +3.63 VDD Temperature Stability 10 05 025 ±100 ppm ±50 ppm ±25 ppm See Notes T 40%~60% 45%~55% Duty Cycle Frequency 2.000~60.000 MHz - Temperature Range See Notes X -10 ~ +70 °C -40 ~ +85 °C - Packaging M R R3 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: S13305T-50.000-X-R S1: 2.0 x 1.6 mm SMD Package 33: +3.3±10% VDD Supply Voltage 05: ±50 ppm Temperature Stability T: 45%~55% Tight Symmetry 50.000 MHz Nominal Frequency X: -40 ~ + 85°C Extended Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape only. 4- Specification subject to change without notice. Page: 4/4 Date : July 1,2020 www.aker-usa.com P/N: S1 Series
S11805T-27.000-X-R
物料型号:S1系列 HCMOS输出时钟振荡器,超小型表面贴装。
器件简介:该振荡器是一款超小型的表面贴装时钟振荡器,具有优良的温度稳定性和低功耗特性。
引脚分配: - #1:使能/禁用 - #2:地(GND) - #3:输出 - #4:电源(VDD)
参数特性: - 频率范围:1.250~60.000 MHz - 频率稳定性:±20~±100 ppm - 老化率:每年±3 ppm - 工作温度范围:标准 -10~+70°C,扩展 -40~+85°C - 存储温度范围:-55~+125°C - 供电电压:1.8±5%、2.5±5%、3.3±10% 或 1.62~3.63 VDD - 输入电流:1.250到9.999MHz时为3到5 mA,其他频率范围为4到8 mA - 输出电压:高电平(Voh)至少90% VDD,低电平(Vol)最大10% VDD - 输出对称性(占空比):标准为40~60%(在50% VDD时),紧凑为45~55%(在50% VDD时) - 输出负载:最大15 pF - 上升和下降时间:在不同频率下为5到6 ns - 相位抖动:12KHz到20MHz时最大1 ps RMS - 使能/禁用功能:三态
功能详解:当PIN#1为高电平或开路时,振荡器工作;当PIN#1为低电平时,振荡器进入高阻态。
应用信息:该振荡器适用于需要小型化和低功耗的时钟源应用。
S11805T-27.000-X-R 价格&库存
很抱歉,暂时无法提供与“S11805T-27.000-X-R”相匹配的价格&库存,您可以联系我们找货
S11805T-27.000-X-R
    • 1+11.89080
    • 200+4.75200
    • 500+4.59000
    • 1000+4.51440
