OVETGLJANF-25.000000
    TAITIEN(泰艺)
    SMD5032_4P
    有源晶振 25.000000MHz 2.8V~3.3V-40℃~+85℃ CMOS
OVETGLJANF-25.000000 数据手册
OV Type 5.0 x 3.2 mm SMD Crystal Oscillator Actual Size FEATURE - Typical 5.0 x 3.2 x 1.2 mm ceramic SMD package. - Tight symmetry (45 to 55%) available. - Realize the standby function with Tri-State TYPICAL APPLICATION - GPS, Mobile Phone - WLAN, Wireless, Fiber/10Gbit Ethernet - Notebook, PDA, DSC OV DIMENSION (mm) RoHS Compliant SOLDER PAD L AYOUT (mm) [ BOTTOM VIEW ] #1 #2 #3 2.54 ± 0.15 #4 2.54 #2 1.20 ± 0.15 1.20 ± 0.10 [ SIDE VIEW ] Pin# 1 2 3 4 1.00 ± 0.15 2.20 ± 0.15 3.20 ± 0.20 #3 #1 0.1µF 2.20 5.00 ± 0.20 #4 1.20 [ TOP VIEW ] Function Tri-state GND Output VDD 1.50 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3V Parameter Min. 2.5V Max. Min. 1.8V Max. Min. Max. Supply Voltage Variation(VDD) VDD -10% VDD+10% VDD -10% VDD+10% VDD -10% VDD+10% Frequency Range 0.0137 160 0.0137 160 135 0.0137 Supply Frequency 2.048, 25, 26, 27, 50, 66.667, 100, 125 Supply Current _ _ _ 1 13.7 kHz Fo 93 kHz 1 1 _ _ _ 10 0.3125 MHz Fo < 50 MHz (A1) 7 8 _ _ _ 20 40 MHz Fo < 75 MHz 15 18 _ _ _ 35 75 MHz Fo < 135 MHz 25 30 _ _ _ _ 45 135 MHz Fo 40 _ _ _ 2.97 2.25 1.62 Output Level (CMOS) Output High (Logic “1”) _ _ _ Output Low (Logic “0”) 0.33 0.25 0.18 Transition Time:Rise/Fall Time _ _ _ 50 13.7 kHz Fo 93 kHz 50 50 _ _ _ 5 0.3125 MHz Fo < 100 MHz 5 5 _ _ _ 3 100 MHz Fo 3 3 _ _ _ 5 5 5 Start Time _ _ _ 15 15 15 Output Drive Capability (CL) Tri-State (Input to Pin 1) _ _ _ Enable (High voltage or floating) 2.31 1.75 1.26 _ _ _ 0.99 0.75 0.54 Disable (Low voltage or GND) _ _ _ Period Jitter(Pk-Pk) 40 40 40 _ _ _ RMS Phase Jitter (Integrated 12 kHz~20 MHz) 1 1 1 _ _ _ Standby Current 10 10 10 _ _ _ Aging (@ 25°C 1st year) ±3 ±3 ±3 Storage Temp. Range -55 125 -55 125 125 -55 unit V MHz MHz mA V nSec mSec pF V pSec pSec µA ppm °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. + Transition times are measured between 10% and 90% of VDD, with an output load of 15pF. FREQ. STABILIT Y vs. TEMP. RANGE Temp. (°C) ppm ±20 ±25 ±50 -10 ~ +60 -20 ~ +70 -40 ~ +85 -40 ~ +125 * ○: Available △:Conditional X: Not available * Inclusive of calibration @ 25 °C, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration Note: not all combination of options are available. Other specifications may be available upon request. 34 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(18)04/2019
OVETGLJANF-25.000000 价格&库存
很抱歉,暂时无法提供与“OVETGLJANF-25.000000”相匹配的价格&库存,您可以联系我们找货
    • 1+5.29373
    • 10+4.90115
    • 30+4.73300
    • 100+4.52304
