HIF3H-50PB-2.54DSA(71)
    HRS(广濑)
    CONN HEADER VERT 50POS 2.54MM
HIF3H-50PB-2.54DSA(71) 数据手册
2.54mm Pitch Board to Board Connector HIF3H Series ■Features 1. Product Variation Afford to connect the board to board horizontally or vertically. 2. Compatibility Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Achieve combination with other HIF3H series. ■Applications Computers, termination equipment, various kinds of electronic equipment, Office Automation machines and so on ■Product Specifications Rating Current rating : 3A Operating Temperature Range : -55 to +85ç (Note 1) Voltage rating : 300V AC Operating Humidity Range : 40 to 80% Item Storage Temperature Range : -10 to +60ç (Note 2) Operating Humidity Range : 40 to 70% (Note 2) Specification Condition 1. Insulation Resistance 1000Mø 500V DC 2. Withstanding Voltage No flashover or insulation breakdown. 1000V AC/1 minute. 3. Contact Resistance 15mø max. Measured at 0.1A 4. Vibration No electrical discontinuity of 1μs or more Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Insulation resistance : 1000ø min. 6. Temperature Cycle 96 hours at temperature of 40ç and humidity of 90% to 95% ( -55ç : 30 minutes→15 to 35ç: 5 minutes max.→ (125ç : 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles No damage, cracks, or parts looseness. 7. Durability (Mating/un-mating) Contact resistance : 15mø max. 500 cycles 8. Resistance to Soldering heat No deformation of components affecting performance. Solder bath : 260ç for 10 seconds Manual soldering : 360ç for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material / Finish Parts Insulator Receptacle Contact DS Material Finish Remarks PBT Black UL94V-0 Phosphor bronze Selective gold plated DSA Pin header ––––––– Brass or phosphor bronze Selective gold plated B53 HIF3H Series●2.54mm Pitch Board to Board Connector ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Pin Header HIF3H - * P B - 2.54 DSA q w q Series Name e r t y : HIF3H w Number of contacts : 4, 6, 10, 12, 14, 16, 20, 24, 26, 30, 34, 40, 50, 60 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. e P : Pin header r Contact material A : Phosphor bronze (DS : brass) B : Brass t Contact pitch : 2.54mm y Contact type DS : Right angle type DSA : Straight type W : Wrapping type ●Socket HIF3H q A - * D A - 2.54 DSA w q Series Name e r t y u : HIF3H w No symbol : Standard A : With mis-insertion preventive guide B : Similarly, guide position center 1 point type for 50, 60 and 64 contacts e Number of contacts : 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 25, 26, 30, 34, 40, 50, 60, 64 r Contact alignment : D : double rows S : single row t A : Straight selective gold plated B : Right angle selective gold plated y Contact pitch : 2.54mm u Contact type DS : Right angle type DSA : Straight type B54 HIF3H Series●2.54mm Pitch Board to Board Connector Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle Straight Through hole Type Unit : mm Part No. HRS No. No. of Contacts HIF3HA- 6DA-2.54DSA(61) 618-0139-8 61 HIF3HA-10DA-2.54DSA(61) 618-0101-5 61 HIF3HA-10DA-2.54DSA(61) 618-0121-2 61 HIF3HA-12DA-2.54DSA(61) 618-0102-8 61 HIF3HA-16DA-2.54DSA(61) 618-0103-0 61 HIF3HA-16DA-2.54DSA(61) 618-0123-8 61 HIF3HA-18DA-2.54DSA(61) 618-0111-9 61 HIF3HA-20DA-2.54DSA(61) 618-0104-3 61 HIF3HA-20DA-2.54DSA(61) 618-0124-0 61 HIF3HA-24DA-2.54DSA(61) 618-0113-4 61 HIF3HA-26DA-2.54DSA(61) 618-0105-6 61 HIF3HA-26DA-2.54DSA(61) 618-0125-3 61 6 A B Part No. RoHS 10 13.7 10.16 12 16.24 12.7 16 21.32 17.78 18 23.86 20.32 20 26.4 22.86 24 31.46 27.94 26 34.02 30.48 HRS No. HIF3HA-30DA-2.54DSA(61) 618-0106-9 61 8.62 5.08 HIF3HA-30DA-2.54DSA(61) 618-0126-6 61 HIF3HA-34DA-2.54DSA(61) 618-0107-1 61 HIF3HA-34DA-2.54DSA(61) 618-0127-9 61 HIF3HA-40DA-2.54DSA(61) 618-0108-4 61 YES HIF3HA-40DA-2.54DSA(61) 618-0128-1 61 No. of Contacts A B RoHS 30 39.1 35.56 34 44.18 40.64 40 51.8 48.26 50 64.5 60.96 YES 60 77.2 73.66 64 82.28 78.74 HIF3HA-50DA-2.54DSA(61) 618-0109-7 61 HIF3HA-50DA-2.54DSA(61) 618-0129-4 61 HIF3HB-50DA-2.54DSA(61) 618-0131-6 61 HIF3HA-60DA-2.54DSA(61) 618-0110-6 61 HIF3HA-60DA-2.54DSA(61) 618-0130-3 61 HIF3HB-60DA-2.54DSA(61) 618-0132-9 61 HIF3HA-64DA-2.54DSA(61) 618-0112-1 61 HIF3HA-64DA-2.54DSA(61) 618-0134-4 61 HIF3HB-64DA-2.54DSA(61) 618-0133-1 61 ■Receptacle Straight Through hole Type Part No. HRS No. HIF3H-6SA-2.54DSA(61) No. of Contacts A Unit : mm B RoHS 562-0713-1 61 6 16.24 12.7 HIF3H-10SA-2.54DSA(61) 562-0719-8 61 10 26.4 HIF3H-12SA-2.54DSA(61) 562-0723-5 61 12 31.48 27.94 HIF3H-14SA-2.54DSA(61) 562-0655-7 61 14 36.56 33.02 HIF3H-20SA-2.54DSA(61) 562-0704-0 61 20 51.8 48.26 HIF3H-25SA-2.54DSA(61) 562-0705-3 61 25 64.5 60.96 22.86 YES B55 HIF3H Series●2.54mm Pitch Board to Board Connector Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle Right Angle Through hole Type B56 Part No. HRS No. No. of Contacts HIF3H- 4DB-2.54DS(61) 618-0150-0 61 4 HIF3H- 8DB-2.54DS(61) 618-0153-9 61 8 HIF3H-10DB-2.54DS(61) 618-0141-0 61 10 13.7 10.16 HIF3H-12DB-2.54DS(61) 618-0152-6 61 12 16.24 12.70 HIF3H-14DB-2.54DS(61) 618-0154-1 61 14 HIF3H-16DB-2.54DS(61) 618-0142-2 61 16 RoHS B 6.0 2.54 HIF3H-18DB-2.54DS(61) 618-0165-8 61 18 23.86 20.32 11.16 7.62 HIF3H-20DB-2.54DS(61) 618-0143-5 61 20 26.4 22.86 HIF3H-24DB-2.54DS(61) 618-0216-7 61 24 31.48 27.94 HIF3H-26DB-2.54DS(61) 618-0144-8 61 26 34.02 30.48 18.78 15.24 HIF3H-30DB-2.54DS(61) 618-0145-0 61 30 39.1 35.56 YES 21.32 17.78 HIF3H-34DB-2.54DS(61) 618-0146-3 61 34 44.18 40.64 HIF3H-40DB-2.54DS(61) 618-0147-6 61 40 51.8 48.26 HIF3H-50DB-2.54DS(61) 618-0148-9 61 50 64.5 60.96 HIF3H-60DB-2.54DS(61) 618-0149-1 61 60 77.2 73.66 YES Part No. HRS No. No. of Contacts A Unit : mm B RoHS A HIF3H Series●2.54mm Pitch Board to Board Connector Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Pin Header Through hole Type Part No. HRS No. No. of Contacts A B RoHS Part No. HRS No. HIF3H-04PA-2.54DS(61) 618-0073-1 61 4 6 HIF3H-30PB-2.54DSA(61) 618-0207-6 61 HIF3H-06PB-2.54DSA(61) 618-0215-4 61 6 8.62 5.08 HIF3H-30P0-2.54W 618-0186-8 HIF3H-10PB-2.54DSA(61) 618-0201-0 61 HIF3H-10P0-2.54W 618-0185-5 10 13.7 10.16 HIF3H-34PB-2.54DSA(61) 618-0208-9 61 HIF3H-34P0-2.54W 618-0181-4 HIF3H-12PB-2.54DSA(61) 618-0202-2 61 12 HIF3H-14PB-2.54DSA(61) 618-0213-9 61 14 16.24 12.7 HIF3H-40PB-2.54DSA(61) 618-0209-1 61 18.78 15.24 HIF3H-40P0-2.54W 618-0182-7 HIF3H-16PB-2.54DSA(61) 618-0203-5 61 HIF3H-16PA-2.54DS(61) 618-0065-3 61 16 21.3 17.78 YES HIF3H-50PB-2.54DSA(61) 618-0210-0 61 HIF3H-60PB-2.54DSA(61) 618-0211-3 61 HIF3H-20PB-2.54DSA(61) 618-0204-8 61 HIF3H-60P0-2.54W 618-0187-0 HIF3H-20P0-2.54W 618-0183-0 HIF3H-24PB-2.54DSA(61) 618-0205-0 61 HIF3H-24PA-2.54DS(61) 618-0067-9 61 HIF3H-26PB-2.54DSA(61) 618-0206-3 61 HIF3H-26P0-2.54W 618-0184-2 2.54 20 26.4 22.86 24 31.46 27.94 26 34.02 30.48 No. of Contacts A Unit : mm B RoHS 30 39.1 35.56 34 44.18 40.64 40 51.8 48.26 50 64.5 60.96 60 77.2 73.66 YES Note 1 : The stitch line area is divided in two for 50 and 60 contacts. Note 2 : *indicates the number of contacts. Note 3 : Wrapping is 6.0. Note 4 : Wrapping is 16.0. B57 HIF3H Series●2.54mm Pitch Board to Board Connector BPCB mounting pattern ●Pin Header Straight and Right Angle Type Size A List Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Receptacle Right Angle Type ●Receptacle Straight Type B58 No. of Contacts A 4 2.54 6 5.08 8 7.62 10 10.16 12 12.7 14 15.24 16 17.78 18 20.32 20 22.86 24 27.94 26 30.48 30 35.56 34 40.64 40 48.26 50 60.96 60 73.66 64 78.74
HIF3H-50PB-2.54DSA(71) 价格&库存
很抱歉,暂时无法提供与“HIF3H-50PB-2.54DSA(71)”相匹配的价格&库存,您可以联系我们找货
