Our Performance Your Reputation
100MHz Low Noise OCXO
NJ-100M-6800 Series
6800 Series in 25.4x22mm SMD package
NJ-100-6800 series is a 100.000 MHz high performance (VC)OCXO offering
low phase noise(LPN) and tight frequency stability down to ±50ppb(-20ºC to +70ºC).
The part comes in a small SMD package which makes it suitable for reflow soldering
during pick and place assembly
FEATURES
APPLICATIONS
RoHS Compliant Standard
Low Phase Noise
Instrument Reference
Small SMD Package
Microwave Communication
Tight Frequency Stability
Clock Reference for Microwave Signal Source
Low Power Consumption
Test & Measurement
Fast Warm-up Time
Telecom Systems
Electrical Frequency Tuning Input
Radar Systems
Reference Voltage Output
Satellite Communication
RoHS-Compliant (lead-free)
ELECTRICAL SPECIFICATIONS
Test conditions: VDC = +12 V; VCO = +5 V; at +25 ± 3°C unless otherwise identified
1. OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
Min.
Typ.
Max.
100.000000
Unit
1.1.
Frequency (Fo)
1.2.
Initial Accuracy
1.3.
Waveform
1.4.
Level
1.5.
Load
1.6.
Harmonics
-30
dBc
1.7.
Spurious
-100
dBc
Test Condition
MHz
@ +25 ±1°C
-0.3
+0.3
ppm
after turn on power 60 minutes
Vco=+5V
Sine wave
+10
dBm
Ω
50
http://www.taitien.com E-Mail: sales@taitien.com.tw
Specifications subject to change without notice
Rev(4)05/2017
Page 1of 4
2. FREQUENCY STABILITY
Parameter
2.1.
Min.
Ambient
Typ.
Max.
Unit
±20, ±50, ±100
ppb
-20oC ~ +70oC
-40oC ~ +85oC
°C
Test Condition
Refer to Table 1 :
Ordering Information
referenced to 25°C
Aging
Daily
-5
+5
ppb
Yearly
-500
+500
ppb
-2
+2
ppm
-5
+5
ppb
±5% change
0.05
ppb
root Allan variance for τ=1 sec
+5
ppb
±10% change
+50
ppb
in 5 minutes @ +25 ±1°C
2.2.
10 Years
2.3.
Voltage
2.4.
Short term
2.5.
Load
2.6.
Warm-up
-5
-50
Option A
2.7.
Phase Noise (Max.)
Option B
Option C
after 30 days
referenced to 1 hour
Refer to Table 1 : Ordering Information
-93
-97
-100
dBc/Hz
@ 10Hz
-125
-130
-135
dBc/Hz
@ 100Hz
-154
-157
-160
dBc/Hz
@ 1KHz
-173
-173
-170
dBc/Hz
@ 10KHz
-177
-175
-172
dBc/Hz
@ 100KHz
-180
-178
-175
dBc/Hz
@ 1MHz
3. ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
3.1.
Tuning Range
3.2.
Control Voltage
3.3.
Slope
3.4.
Center Voltage
3.5.
Linearity
Min.
Typ.
Max.
Unit
-3
ppm
VCO @ Min. Voltage
ppm
VCO @ Max. Voltage
+3
V
+10
Test Condition
Referenced to frequency at nominal
Center Voltage
Positive
+5
-10
V
4. INPUT POWER (PIN = “+VDC”)
4.1.
Parameter
Min.
Typ.
Max.
Unit
Voltage
+11.4
+12
+12.6
V
Steady State
2.1
W
During Warm-Up
380
mA
Test Condition
Current
4.2.
5. REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE")
5.1.
Parameter
Min.
Typ.
Max.
Units
Voltage
+9.5
+10
+10.5
V
Test Condition
Rev(4)05/2017
Page 2of 4
6. ENVIRONMENTAL
Parameter
Reference Std.
Test Condition
6.1.
Operating Temperature
-40°C to +85°C
6.2.
Storage Temperature
-55°C to +105°C
Note 1
6.3.
Humidity
MIL-STD-202, Method 103
Test Condition A
95% RH @ +40°C,non-condensing,240 hours
6.4.
Vibration (non-operating)
MIL-STD-202, Method 201
0.06” Total p-p, 10 to 55 Hz
6.5.
Shock (non-operating)
MIL-STD-202, Method 213,
Test Condition J
30g, 11ms, half-sine
Note 1 : Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the
temperature range in 2.1.
Table 1 : ORDERING INFORMATION
Ambient
Option
A
B
C
±100 ppb
NJ-100M-6805
NJ-100M-6806
NJ-100M-6807
±50 ppb
NJ-100M-6815
NJ-100M-6816
NJ-100M-6817
±20 ppb
NJ-100M-6835
NJ-100M-6836
NJ-100M-6837
±100 ppb
NJ-100M-6825
NJ-100M-6826
NJ-100M-6827
Temp. (°°C )
-20°°C ~+70oC
-40oC~+85oC
Phase Noise Option
Phase Noise Test Data
Rev(4)05/2017
Page 3of 4
OUTLINE DRAWING
Rev(4)05/2017
Page 4of 4
很抱歉,暂时无法提供与“NJ-100M-6816”相匹配的价格&库存,您可以联系我们找货
