501-33924
501-33924
    WENZEL(文策尔)
    DIP-5
    有源晶振 12V 100MHz DIP-5
501-33924 数据手册
OUTPUT Frequency 100 MHz Level +10 ±2 dBm into 50 ohms STABILITY Aging -6 ±1 x 10 per year after 30 days operating, typical Phase Noise L(f), typical, Static 10 Hz -90 dBc/Hz* 100 Hz -126 dBc/Hz 1 kHz -145 dBc/Hz 10 kHz -166 dBc/Hz 100 kHz -170 dBc/Hz *typical at 10 Hz Temperature Stability ADJUSTMENT Electrical Tuning REV DATE - 04-28-21 REVISION RECORD Draft DWN AUTH BH LR -6 ±7 x 10 nominal, 0 - 10 VDC, Positive slope CRYSTAL Type SC-cut, 3e-10/g typical OTHER Label Label as follows: 501-33924 10 MHz VDC SN – Date Code ≤ ±2 x 10-7, 0° to +50°C (Ref +25°C) ≤ ±5 x 10-7, -20° to +70°C (Ref +25°C) ≤ ±1.1 x 10-6, -40° to +85°C (Ref +25°C) Harmonics ≤ -30 dBc Spurious ≤ -80 dBc MECHANICAL Dimensions ≤ 1.03” x 1.03” x 0.515” Connectors Solder pins on base, glass stand-offs Packaging Solder sealed steel can POWER REQUIREMENTS Warm-Up Power ≤ 3W for 2.5 min Total Power ≤ 1.1W at +25°C steady state, typical Supply Voltage +12 VDC ±1 VDC Wenzel Associates, Inc. Austin, Texas Title: 100 MHz-SC ONYX IV Crystal Oscillator P/N: Rev: 501-33924 olerances: (except as noted) Dimensions are in inches Date: 0.XX Dec: 0.030” Drawn: Ref: 24760 04-28-21 0.XXX Dec: 0.010” FSCM: 62821 Page 1 of 1
501-33924 价格&库存
很抱歉,暂时无法提供与“501-33924”相匹配的价格&库存,您可以联系我们找货
