S3A3305-100.000-P-X-R
    AKER(安碁科技)
    SMD3225_6P
    有源晶振 100.000000 MHz 3.3V -40℃~+85℃ LVPECL
S3A3305-100.000-P-X-R 数据手册
RoHS Compliant Pb - Lead Free Ltr Appr Date Revisions Electrical Specifications: Frequency Range 13.500 - 156.250 ±100 ±50 ±25 ±3 -10 to +70 -40 to +85 -55 to +125 Frequency Stability over Temperature Aging per Year Standard Extended Operating Temperature Range Storage Temperature Range Supply Voltage Input Current 13.500-156.250 Logic High (Voh) Logic Low (Vol) Output Voltage Output Symmetry Output Type Output Load Input Enable Voltage Input Disable Voltage Rise and Fall Time Phase Jitter (12 KHz to 20 MHz) 13.500-99.999Mhz 100.000 - 156.250Mhz 2.5 ± 5% 50 1.475 1.095 45 to 55 LVPECL 50 1.75 0.75 1 0.5 1 MHz PPM Max ºC 3.3 ± 5% 50 2.275 1.68 Vdd mA Max Vdd Min Vdd Max % - 2.31 0.99 1 0.5 V(Min) V(Max) Ω ns Max ps RMS Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: June 29, 2016 Clock Oscillator LVPECL - Complimentary Output 3.2 x 2.5 millimeter Surface Mount - 6 Pad General Product Specification Part Number: S3A Series www.aker-usa.com Mechanical Outline: Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. PCB Solder Pad Layout: Pad Connection: Top View Page: 2/4 Date: June 29, 2016 P/N: Pin Connection 1- INH 2- NC 3- GND 4- Output - Q 5- Comp. Output - QN 6- Vdd S3A Series www.aker-usa.com Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: June 29, 2016 P/N: www.aker-usa.com S3A Series How to build a Part Number: Series Package S 3A Parameter 3.2 x 2.5 mm - 6 Pad Supply Voltage 25 33 +2.5 Vdd ± 5% +3.3 Vdd ± 5% Temperature Stability 10 05 025 ±100 PPM ±50 PPM ±25 PPM Frequency 13.500 - 156.250 Output Load Temperature Range Packaging P See Notes X R - MHz LVPECL 0 to +70 ºC -40 to +85 ºC Tape and Reel Part Number Example: S3A3310-155.520-P-X-R S3A: 3.2 x 2.5 mm SMD Package - 6 Pad 33: +3.3 Vdd Supply Voltage 10: ±100 PPM Temperature Stability 155.520 MHz Nominal Frequency P: LVPECL - Complimentary Output X: -40 to + 85° C Extended Temperature Range R: Tape and Reel Notes: 1- Standard Temperature Range does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Quantities less than 1000 are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date: June 29, 2016 P/N: www.aker-usa.com S3A Series
1. 物料型号:S3A系列,例如S3A3310-155.520-P-X-R,包括3.2 x 2.5毫米的SMD封装,6个焊盘,+3.3V供电电压,±100 PPM的温度稳定性,155.520 MHz的标称频率,LVPECL互补输出,扩展温度范围-40至+85°C,以及胶带和卷轴包装。
2. 器件简介:该振荡器是一个表面安装的6焊盘时钟振荡器,具有3.2 x 2.5毫米的尺寸,提供LVPECL互补输出。
3. 引脚分配:文档提供了顶视图和引脚连接,包括INH(输入使能)、NC(无连接)、GND(地)、Output(输出Q)、Comp. Output - QN(互补输出QN)和Vdd(供电电压)。
4. 参数特性:包括频率范围(13.500-156.250 MHz)、电源电压(2.5V至5.5V)、输入电流(最大50 mA)、逻辑高电平(Voh)、逻辑低电平(Vol)、输出电压、输出负载、频率稳定性、工作温度范围(-40至+85°C)和存储温度范围(-55至+125°C)。
5. 功能详解:文档详细描述了电气规格,包括温度稳定性、电源电压变化、输出负载变化、冲击、振动和1年老化对频率稳定性的影响。
6. 应用信息:文档提供了构建部件编号的方法和示例,以及产品以胶带和卷轴配置发货的信息。
7. 封装信息:提供了机械轮廓和PCB焊盘布局的详细信息,以及焊接回流特性。
S3A3305-100.000-P-X-R 价格&库存
很抱歉,暂时无法提供与“S3A3305-100.000-P-X-R”相匹配的价格&库存,您可以联系我们找货
