LFPTXO000268BULK
LFPTXO000268BULK
    IQD
    SMD-4
    有源晶振 3.3V 16.384MHz SMD-4
LFPTXO000268BULK 数据手册
TCXO Specification Part No. + Packaging: LFPTXO000268Bulk Customer Part: Description Surface mount temperature compensated voltage controlled crystal oscillator. Freq Adj option Option A (standard): Ageing adjustment by means of external Control Voltage applied to pad 1 Range (frequency ≤ 20MHz) ≥ ±5ppm Range (frequency > 20MHz) ≥ ±7ppm Linearity ≤2% Slope Positive Input resistance ≥100kΩ Modulation bandwidth ≥2kHz Standard control voltage range 1.5V±1V Model CFPT-9301-A Model Issue number 7 Frequency Parameters Frequency 16.3840MHz Frequency Tolerance ±1.00ppm ±1.00ppm Frequency Stability Operating Temperature Range Ageing Outline (mm) -40.00 to 85.00°C ±1ppm max in 1st year (see Note 1) Supply Voltage Variation (@ ±5% change): Frequency
LFPTXO000268BULK 价格&库存
很抱歉,暂时无法提供与“LFPTXO000268BULK”相匹配的价格&库存,您可以联系我们找货
