Our Performance Your Reputation
Oven Controlled Crystal Oscillator
NI-10 MHz-2800 series
2800 Series in 36.3x27.2mm DIP package
NI-10M-2800 series oscillators is designed for applications where space is at a premium
and good frequency stability is required. The oscillators can be used in many
communications applications. A choice of quartz resonators offers a variety of
performance versus cost options to fit most applications.
RoHS Compliant Standard
ELECTRICAL SPECIFICATIONS
1.
OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
1.1.
Min.
Frequency
Typ.
Max.
10.000000
Unit
Test Condition
MHz
@ +25 ±1°C
1.2.
Initial Accuracy
-0.1
+0.1
ppm
after turn on power 15 ±1 minutes
≤ 90 days following date code
VCO Input at 2.5 ±0.001V
1.3.
Waveform
Rectangular
Level
1.4.
LVTTL
“1” level
+2.6
V
“0” level
1.5.
Load
1.6.
Duty cycle
1.7.
Rise/fall time
1.8.
Spurious
2.
V
13.5
15
16.5
pF
45
50
55
@ +1.65V
6
ns
10% to 90%
-60
dBc
Max.
Unit
FREQUENCY STABILITY
Parameter
2.1.
+0.4
Min.
Ambient
Aging
2.2.
Typ.
±3, ±5, ±10
ppb
-30 ~ +70
-40 ~ +85
°C
Test Condition
referenced to 25°C
Refer to Table 1 : Ordering Information
-0.5
+0.5
ppb
per day, at time of shipment
after 30 days
Daily
-0.5
+0.5
ppb
Yearly
-50
+50
ppb
10 Years
-0.3
+0.3
ppm
-0.5
+0.5
ppb
2.3.
Voltage
±5% change
2.4.
Short term
0.05
ppb/s
2.5.
Load
-0.5
+0.5
ppb
±5% change
2.6.
Warm-up
-10
+10
ppb
in 10 minutes @ +25 ±1°C
root Allan variance
referenced to 1 hour
Page 1of 3
http://www.taitien.com E-Mail: sales@taitien.com.tw
Specifications subject to change without notice
Rev(1)05/2015
Parameter
2.7.
3.
Min.
Phase Noise
Max.
Unit
Test Condition
-95
-90
dBc/Hz
@ 1Hz
-125
-120
dBc/Hz
@ 10Hz
-140
-135
dBc/Hz
@ 100Hz
-148
-145
dBc/Hz
@ 1KHz
-156
-155
dBc/Hz
@ 10KHz
-158
-155
dBc/Hz
@ 100KHz
ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
3.1.
Tuning Range
Min.
Typ.
Max.
Unit
-0.5
ppm
VCO @ 0V
ppm
VCO @ 5V
+0.5
3.2.
Control Voltage
3.3.
Slope
3.4.
Center Voltage
3.5.
Linearity
-10
3.6.
Input Impedance
100
4.
Typ.
V
+10
Test Condition
Positive
+2.5
V
Note 1
kΩ
INPUT POWER (PIN = “+VDC”)
Parameter
Min.
Typ.
Max.
Unit
4.1.
Voltage
+11.4
+12
+12.6
V
4.2.
Current
400
mA
@ turn on
4.3.
Steady State
1.3
W
@ +25°C
5.
Test Condition
REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE")
(Optional Function. Refer to Table 1 : Ordering Information.)
5.1.
5.2.
6.
Referenced to frequency at nominal
Center Voltage
Parameter
Min.
Typ.
Max.
Voltage
+4.75
+5
+5.25
Load
9
Units
V
kΩ
Test Condition
Over temperature range in 2.1.
ENVIRONMENTAL
Parameter
6.1.
Operating Temperature
6.2.
Storage Temperature
Reference Std.
-40°C to +85°C
Test Condition
Note 2
-55°C to +105°C
6.3.
Humidity
MIL-STD-202, Method 103
Test Condition A
6.4.
Vibration (non-operating)
MIL-STD-202, Method 201
0.06” Total p-p, 10 to 55 Hz
6.5.
Shock (non-operating)
MIL-STD-202, Method 213,
Test Condition J
30g, 11ms, half-sine
Note 1.
Note 2.
95% RH @ +40°C,non-condensing,240 hours
When not connected, VCO INPUT is internally held at this voltage.
Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the
Page 2of 3
Rev(1)05/2015
Table 1 : ORDERING INFORMATION
TAITIEN
Model No.
ppb
±3
±5
±10
NI-10M-2800
NI-10M-2803
NI-10M-2850
NI-10M-2853
NI-10M-2801
NI-10M-2804
NI-10M-2851
NI-10M-2854
NI-10M-2802
NI-10M-2805
NI-10M-2852
NI-10M-2855
Temp. (℃
-30~+70
-40~+85
-30~+70
-40~+85
Control
Voltage
Reference
Voltage
+2.5V
N/A
+2.5V
+5.0V
OUTLINE DRAWING
Page 3of 3
Rev(1)05/2015
很抱歉,暂时无法提供与“NI-10M-2853”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+754.778155+97.65070
