QTM750-35.328MBB-T
QTM750-35.328MBB-T
    QST(矽睿)
    SMD7050_4P
    有源晶振 35.328000MHz 3.3V -10℃~+70℃ CMOS
QTM750-35.328MBB-T 数据手册
7W MHz CMOS Oscillator Features Frequency range : 1MHz to 170MHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Tri-state function available External dimensions (mm) L : 7.0 x W : 5.0 x H : 1.3 RoHS compliant & Pb free Applications Networking, Server, Storage Wireless communications Fibre channel, Ethernet, SATA, SAS, PCI-E, USB, WLAN, xDSL, xPON PC mainboard, Notebook, HDD, SSD, Graphics card, Computer peripherals Audio, Video, Gaming, Printer, DSC, IP CAM, Consumer products Electrical Characteristics Item Frequency Range (F 0) Frequency Stability (F stab) Operating Temperature Range (T OTR) Supply Voltage (VDD) Current Consumption (IDD) 7W 1MHz ~ 170MHz ±50ppm, ±30ppm, ±25ppm 1.8V, 2.5V, 3.3V 1MHz ~ 75MHz 20 mA Max. 75MHz ~ 170MHz Output Load (CL) 15 pF Output Voltage High (VOH) 90% VDD Min. Output Voltage Low (VOL) 10% VDD Max. Rise & Fall Time (Tr / Tf) 8 ns Max. Duty Cycle 40% ~ 60% Start-up Time 5 ms Max. Enable Voltage High, Logic "1" 70% VDD Min. Enable Voltage Low, Logic "0" 30% VDD Max. Storage Temperature Range (T STR) VDD ± 10% 10 mA Max. CMOS Aging (Faging) Note [1] -40°C ~ +85°C Output Type Phase Jitter, RMS Conditions 1 ps Max. ±3 ppm Max. 10% ~ 90% of VDD Input to Pin1 Note [2] Note [3] at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, supply voltage, and load. [2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0". [3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz. Rev. 1.03-a Page 1 www.txccrystal.com 7W MHz CMOS Oscillator Dimensions (Unit: mm) Ordering Information 7W 30.000M B B - T - Frequency in Hz Packaging Method T Please contact us for available frequencies Frequency Stability Supply Voltage B C D Rev. 1.03-a Tape & Reel B C F 3.3 V 2.5 V 1.8 V Page 2 ± 50 ppm (-10˚C ~ +70˚C) ± 100 ppm (-10˚C ~ +70˚C) ± 100 ppm (-40˚C ~ +85˚C) www.txccrystal.com 7W MHz CMOS Oscillator Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.03-a 60 sec Page 3 Time (sec) www.txccrystal.com
QTM750-35.328MBB-T 价格&库存
很抱歉,暂时无法提供与“QTM750-35.328MBB-T”相匹配的价格&库存,您可以联系我们找货
