TX22-33025S-19.200-X-CT
    AKER(安碁科技)
    SMD-4
    有源晶振 19.2MHz 3.3V SMD-4
TX22-33025S-19.200-X-CT 数据手册
Ltr Date Revisions Appr RoHS Compliant Pb - Lead Free Electrical Specifications: Frequency Range 10.000 to 52.000 Frequency Tolerance MHz ±2.0 Frequency Stability vs. Operating Temperature ±0.5 ~ ±2.5 Frequency Stability vs. Supply Voltage Change ±0.2 Frequency Stability vs. 10% Load Change ±0.2 Aging per Year ±1.0 Operating Temperature Range Standard -20 to +70 Extended -40 to +85 Storage Temperature Range ppm Max. °C -55 to +125 1.8 ± 5% Supply Voltage 2.5 ± 5% VDC 3.3 ± 5% Input Current 2.5 mA Max. Output Level 0.8 Vp-p Min. Output Waveform Clipped Sinewave Output Load 10KΩ // 10pF Phase Noise @100Hz Offset -114 @1KHz Offset -131 @10KHz Offset -148 Start Up Time 2 dBc/Hz Typ. ms Max. Specification Title: No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan, ROC TCXO - Ceramic Package All dimensions are millimeters. CAD: TCR Review: EG Appr: JL Page: 1/4 Temperature Compensated Crystal Oscillator 2.5 x 2.0 millimeter Surface Mount Date: Jan 8,2020 Part Number: www.aker-usa.com TX22 Series Mechanical Outline and Solder Pad Layout: 2.5 ¡ Ó0.15 #4 Ceramic Base Metal Lid #3 2.0 ¡ Ó0.15 AKER #1 #2 0.95 Max. 0.95 1.625 #4 #3 0.575 0.675 0.9 #2 0.65 #1 1.225 1.0 PIN No. Connection #1 NC / GND #2 GND #3 Output #4 VDC Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date : Jan 8,2020 P/N: TX22 Series www.aker-usa.com B-B SECTION AKER AKER AKER AKER B 4.0 0.8 2.25 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 2.75 3.5 B Pin #1 AKER AKER 1.0 A AKER AKER A 4.0 8.0 1.5 2.0 1.75 Carrier Tape Dimensions: Date : Jan 8,2020 P/N: TX22 Series www.aker-usa.com How to build a Part Number: Series TX Parameter Package 22 2.5 x 2.0 mm - Supply Voltage Temperature Stability Output Waveform 18 1.8 VDC ± 5% 25 2.5 VDC ± 5% 33 3.3 VDC ± 5% 005 ±0.5 ppm 010 ±1.0 ppm 020 ±2.0 ppm 025 ±2.5 ppm S Clipped Sinewave - Frequency 10.000~52.000 MHz - Temperature Range See Notes -20 to +70 °C X -40 to +85 °C - Packaging M 250pcs Reel R 1000pcs Reel R3 3000pcs Reel Part Number Example: TX22-33020S-26.000-X-R TX22: 2.5 x 2.0 mm SMD Package 33: +3.3 VDC Supply Voltage 020: ±2.0 ppm Temperature Stability S: Clipped Sinewave Output 26.000 MHz Nominal Frequency X: -40 to + 85°C Temperature Range R: Tape and Reel Packaging Notes: 1- Standard Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 1000 are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date : Jan 8,2020 P/N: TX22 Series
- 物料型号:TX22系列 - 器件简介:这是一个2.5 x 2.0毫米的表面贴装TCXO,具有温度补偿功能,以确保频率稳定性。 - 引脚分配: - #1:NC/GND(空脚/地) - #2:GND(地) - #3:Output(输出) - #4:VDC(直流电源) - 参数特性: - 频率范围:10.000至52.000 MHz - 频率容差:最大+2.0 ppm - 频率稳定性:对操作温度、电源电压变化和负载变化的稳定性 - 老化率:每年±1.0 - 工作温度范围:标准-20至+70°C,扩展-40至+85°C - 存储温度范围:-55至+125°C - 电源电压:1.8VDC、2.5VDC、3.3VDC,±5%容差 - 输入电流:最大2.5 mA - 输出电平:最小0.8 Vp-p - 输出波形:裁剪正弦波 - 输出负载:10KΩ//10pF - 相位噪声:在不同频率偏移下的dBc/Hz值 - 启动时间:最大2 ms - 功能详解:文档提供了详细的电气规格和性能参数,以及如何构建部件编号的指南。 - 应用信息:适用于需要高精度和温度稳定性的应用。 - 封装信息:2.5 x 2.0毫米的表面贴装陶瓷金属封装,带有密封接缝。
TX22-33025S-19.200-X-CT 价格&库存
很抱歉,暂时无法提供与“TX22-33025S-19.200-X-CT”相匹配的价格&库存,您可以联系我们找货
