LFTCXO079060
LFTCXO079060
    IQD
    SMD-4
    有源晶振 1.8V 33.6MHz SMD-4
LFTCXO079060 数据手册
IQXT-205-3 IQXT-205-3 is a 2.0 x 1.6mm SMD Temperature Compensated Crystal Oscillator (TCXO) in a hermetically sealed package with a wide operating temperature range. Model Name Description IQXT-205-3-18 A 1.8V version IQXT-205-3-25 A 2.5V version IQXT-205-3-28 A 2.8V version IQXT-205-3-30 A 3.0V version IQXT-205-3-33 A 3.3V version IQD Frequency Products Ltd ■ Station Road ■ Crewkerne ■ Somerset ■ TA18 8AR ■ United Kingdom Tel: +44 (0)1460 270200 ■ Fax: +44 (0)1460 72578 ■ Email: info@iqdfrequencyproducts.com Registered in England No: 06478545 ■ VAT Registration No: GB932 4502 45 TCXO Specification IQXT-205-3-18 ISSUE 1; March 2018 Outline (mm) Description IQXT-205-3-18 is a 2.0 x 1.6mm SMD Temperature Compensated Crystal Oscillator (TCXO) in a hermetically sealed package with a wide operating temperature range. Developed frequencies: 16.368, 16.369, 19.2, 26.0, 33.6, 38.4 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm ±1ppm max per year @ 25°C ±2°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. IR Reflow Resistance (@ 25°C ±2°C ref to frequency before reflow): ±1ppm max, 24hrs after reflow Supply Voltage Variation (@ ±5% change): ±0.1ppm max Load Variation (@ ±10% change): ±0.1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 1.8V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Operating Temperature Ranges -40 to 105°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Environmental Parameters Storage Temperature Range: -40 to 105°C Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 26.0MHz IQXT-205-3-18 Clipped Sine ±0.5ppm –40 to 105C 1.8V Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable TCXO Specification IQXT-205-3-18 ISSUE 1; March 2018 Packaging Details Pack Style: Cutt Pack Size: 100 Cut tape Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Electrical Specification - maximum limiting values 1.8V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -40 to 105 ±0.5 1.5 - - 30.0MHz 39.999999MHz -40 to 105 ±0.5 1.7 - - 40.0MHz 52.0MHz -40 to 105 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. TCXO Specification IQXT-205-3-25 ISSUE 1; March 2018 Outline (mm) Description IQXT-205-3-25 is a 2.0 x 1.6mm SMD Temperature Compensated Crystal Oscillator (TCXO) in a hermetically sealed package with a wide operating temperature range. Developed frequencies: 16.368, 16.369, 19.2, 26.0, 33.6, 38.4 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm ±1ppm max per year @ 25°C ±2°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. IR Reflow Resistance (@ 25°C ±2°C ref to frequency before reflow): ±1ppm max, 24hrs after reflow Supply Voltage Variation (@ ±5% change): ±0.1ppm max Load Variation (@ ±10% change): ±0.1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 2.5V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Operating Temperature Ranges -40 to 105°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Environmental Parameters Storage Temperature Range: -40 to 105°C Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 26.0MHz IQXT-205-3-25 Clipped Sine ±0.5ppm –40 to 105C 2.5V Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable TCXO Specification IQXT-205-3-25 ISSUE 1; March 2018 Packaging Details Pack Style: Cutt Pack Size: 100 Cut tape Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Electrical Specification - maximum limiting values 2.5V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -40 to 105 ±0.5 1.5 - - 30.0MHz 39.999999MHz -40 to 105 ±0.5 1.7 - - 40.0MHz 52.0MHz -40 to 105 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. TCXO Specification IQXT-205-3-28 ISSUE 1; March 2018 Outline (mm) Description IQXT-205-3-28 is a 2.0 x 1.6mm SMD Temperature Compensated Crystal Oscillator (TCXO) in a hermetically sealed package with a wide operating temperature range. Developed frequencies: 16.368, 16.369, 19.2, 26.0, 33.6, 38.4 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm ±1ppm max per year @ 25°C ±2°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. IR Reflow Resistance (@ 25°C ±2°C ref to frequency before reflow): ±1ppm max, 24hrs after reflow Supply Voltage Variation (@ ±5% change): ±0.1ppm max Load Variation (@ ±10% change): ±0.1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 2.8V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Operating Temperature Ranges -40 to 105°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Environmental Parameters Storage Temperature Range: -40 to 105°C Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 26.0MHz IQXT-205-3-28 Clipped Sine ±0.5ppm –40 to 105C 2.8V Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable TCXO Specification IQXT-205-3-28 ISSUE 1; March 2018 Packaging Details Pack Style: Cutt Pack Size: 100 Cut tape Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Electrical Specification - maximum limiting values 2.8V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -40 to 105 ±0.5 1.5 - - 30.0MHz 39.999999MHz -40 to 105 ±0.5 1.7 - - 40.0MHz 52.0MHz -40 to 105 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. TCXO Specification IQXT-205-3-30 ISSUE 1; March 2018 Outline (mm) Description IQXT-205-3-30 is a 2.0 x 1.6mm SMD Temperature Compensated Crystal Oscillator (TCXO) in a hermetically sealed package with a wide operating temperature range. Developed frequencies: 16.368, 16.369, 19.2, 26.0, 33.6, 38.4 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm ±1ppm max per year @ 25°C ±2°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. IR Reflow Resistance (@ 25°C ±2°C ref to frequency before reflow): ±1ppm max, 24hrs after reflow Supply Voltage Variation (@ ±5% change): ±0.1ppm max Load Variation (@ ±10% change): ±0.1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 3.0V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Operating Temperature Ranges -40 to 105°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Environmental Parameters Storage Temperature Range: -40 to 105°C Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 26.0MHz IQXT-205-3-30 Clipped Sine ±0.5ppm –40 to 105C 3.0V Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable TCXO Specification IQXT-205-3-30 ISSUE 1; March 2018 Packaging Details Pack Style: Cutt Pack Size: 100 Cut tape Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Electrical Specification - maximum limiting values 3.0V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -40 to 105 ±0.5 1.5 - - 30.0MHz 39.999999MHz -40 to 105 ±0.5 1.7 - - 40.0MHz 52.0MHz -40 to 105 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. TCXO Specification IQXT-205-3-33 ISSUE 1; March 2018 Outline (mm) Description IQXT-205-3-33 is a 2.0 x 1.6mm SMD Temperature Compensated Crystal Oscillator (TCXO) in a hermetically sealed package with a wide operating temperature range. Developed frequencies: 16.368, 16.369, 19.2, 26.0, 33.6, 38.4 and 52.0MHz Frequency Parameters Frequency 13.0MHz to 52.0MHz ±1.50ppm @ 25°C ±2°C ±0.50ppm ±1ppm max per year @ 25°C ±2°C Frequency Tolerance: Referred to nominal frequency before reflow soldering. IR Reflow Resistance (@ 25°C ±2°C ref to frequency before reflow): ±1ppm max, 24hrs after reflow Supply Voltage Variation (@ ±5% change): ±0.1ppm max Load Variation (@ ±10% change): ±0.1ppm max Frequency Tolerance Max Tolerance Condition Frequency Stability Ageing Electrical Parameters 3.3V ±5% Supply Voltage Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V Operating Temperature Ranges -40 to 105°C Output Details Output Compatibility Clipped Sine Drive Capability 10kΩ//10pF Output: DC coupled Output Level: 0.8V pk-pk min Start Up Time (90% of V pk-pk): 2ms max Start Up Time (within ±0.5ppm): 2ms max Noise Parameters Phase Noise (typ): -135dBc/Hz @ 1kHz Environmental Parameters Storage Temperature Range: -40 to 105°C Ordering Information *Minimum info required Frequency* Model* Output Frequency Stability (over operating temperature range)* Operating Temperature Range* Supply Voltage Example 26.0MHz IQXT-205-3-33 Clipped Sine ±0.5ppm –40 to 105C 3.3V Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable TCXO Specification IQXT-205-3-33 ISSUE 1; March 2018 Packaging Details Pack Style: Cutt Pack Size: 100 Cut tape Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Electrical Specification - maximum limiting values 3.3V ±5% Frequency Min Frequency Max Temperature Range Stability (Min) Current Draw Rise and Fall Time Duty Cycle °C ppm mA ns % 13.0MHz 29.999999MHz -40 to 105 ±0.5 1.5 - - 30.0MHz 39.999999MHz -40 to 105 ±0.5 1.7 - - 40.0MHz 52.0MHz -40 to 105 ±0.5 2 - - This document was correct at the time of printing; please contact your local sales office for the latest version. Click to view latest version on our website. Sales Office Contact Details: UK: +44 (0)1460 270200 Germany: 0800 1808 443 France: 0800 901 383 USA: +1.760.318.2824 Printed on 20 Mar 18 12:57 using Model Data Sheet V1.2550 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 11 of 11
LFTCXO079060 价格&库存
很抱歉,暂时无法提供与“LFTCXO079060”相匹配的价格&库存,您可以联系我们找货
LFTCXO079060
    • 1+38.73960
    • 200+15.46560
    • 500+14.94720
    • 1000+14.68800
