5002DAC148M5000ABI
5002DAC148M5000ABI
    AEONSEMI(益昂半导体)
    SMD-6
    引脚可配置振荡器 1.8V~3.3V -40℃~+85℃ SMD-6 CMOS, LVDS
5002DAC148M5000ABI 数据手册
AS5002 Arcadium™ Pin Selectable Frequency Oscillator, 10 kHz to 350 MHz The AS5002 Arcadium™ all-silicon oscillator utilizes proprietary frequency synthesis and sensor technologies to provide a quartz-free, MEMS-free, low jitter clock at any output frequency. The device is factory-programmed to have 3 selectable frequencies ranging from 10 kHz to 350 MHz with 50 MHz — — 550 ps All formats 45 — 55 % Duty Cycle DC Output Enable (OE)2 VIH 0.7 × VDD — — V VIL — — 0.3 × VDD V Frequency Select (FS) Powerup Time TD Output Disable Time, FCLK >10 MHz — — 3 µs TE Output Enable Time, FCLK >10 MHz — — 20 µs VIH 0.7 × VDD — — V VIL — — 0.3 × VDD V — — 4 ms tOSC Time from 0.9 × VDD until output frequency (FCLK) within spec LVPECL Output Option3 VOC Mid-level VDD – 1.55 — VDD – 1.25 V (DC-Coupled) VO Swing (diff) 1.4 — 1.85 VPP LVPECL Output Option3 VO 1.4 — 1.85 VPP Swing (diff) (AC-Coupled) aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 3 AS5002 Datasheet Parameter Symbol Test Condition/Comment Min Typ Max Unit VOC Mid-level (2.5 V, 3.3 V VDD) 1.125 1.20 1.275 V Mid-level (1.8 V VDD) 0.795 0.85 0.905 V VO Swing (diff) 0.5 0.82 0.96 VPP VOH Output voltage high 695 815 935 mV VOL Output voltage low 0 5 10 mV HCSL Output Option5 (Rterm = 2 5 Ω; DC-Coupled) VOH Output voltage high 695 820 945 mV VOL Output voltage low 0 5 10 mV CML Output Option4 (AC-Coupled) VO Swing (diff) 0.725 0.8 0.89 VPP CMOS Output Option VOH IOH = 8/6/4 mA for 3.3/2.5/1.8V VDD 0.83 × VDD — — V VOL IOL = 8/6/4 mA for 3.3/2.5/1.8V VDD — 0.17 × VDD V LVDS Output Option3 (DC-Coupled) HCSL Output Option5 (Rterm = 50 Ω; DC-Coupled) — Notes: 1. Total Stability includes temperature stability, initial accuracy, load pulling, VDD variation, and aging for 10 years at 40 ºC. 2. OE includes a 50 k pull-up to VDD for OE active high Includes a 50 k pins include a 50 kΩ pull-down to GND. 3. Rterm = 50 Ω to VDD – 2.0 V (see Figure 4.1). pull-down to GND for OE active low. NC (No Connect) 4. Rterm = 100 Ω differential) see Figure 4.2). 5. Rterm = 50 Ω to GND see Figure 4.2). aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 4 AS5002 Datasheet Table 2.2. Clock Output Phase Jitter and PSRR VDD = 1.8 V, 2.5 or 3.3 V ± 5%, TA = –40 to 85 ºC; VDD = 1.8 V ± 5%, TA = –40 to 105 ºC Parameter Symbol Test Condition/Comment Min Typ Max Unit Phase Jitter (RMS, 12 kHz - 20 MHz)1,2 FCLK ≥ 10 MHz ϕJ Differential Formats — 350 750 fs CMOS, Dual CMOS — 350 — fs Phase Jitter (RMS, 50 kHz - 20 MHz) ϕJ Differential Formats — 150 250 fs CMOS, Dual CMOS — 100 — fs 100 kHz sine wave — -76 — 200 kHz sine wave — -75 — 500 kHz sine wave — -75 — 1 MHz sine wave — -75 — 100 kHz sine wave — -83 — 200 kHz sine wave — -83 — 500 kHz sine wave — -83 — 1 MHz sine wave — -82 — FCLK ≥ 156 25 MHz Spurs Induced by External Power Supply Noise, 50 mVpp Ripple. PSRR LVDS 156.25 MHz Output VDD = 1.8 V Spurs Induced by External Power Supply Noise, 50 mVpp Ripple. LVDS 156.25 MHz Output VDD = 2.5 or 3.3 V PSRR dBc dBc Note: 1. Applies to output frequency: 50, 100, 156.25, 212.5, 350 MHz. 2. Guaranteed by characterization. Jitter inclusive of any spurs. Figure 2.1. Phase Noise at 156.25 MHz aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 5 AS5002 Datasheet Table 2.3. Environmental Compliance and Package Information Parameter Test Condition Moisture Sensitivity Level 1 Note: For additional product information not listed in the data sheet (e.g. RoHS Certifications, MSDS data, qualification data, REACH Declarations, ECCN codes, etc.), contact aeonsemi.com/contact-us/ Table 2.4. Thermal Conditions Package Parameter Symbol Test Condition Value Unit Thermal Resistance Junction to Ambient ΘJA Still Air 105 ºC/W Thermal Resistance Junction to Board ΘJB Still Air 81 ºC/W Max Junction Temperature TJ Still Air 125 ºC Thermal Resistance Junction to Ambient ΘJA Still Air 108 ºC/W Thermal Resistance Junction to Board ΘJB Still Air 84 ºC/W Max Junction Temperature TJ Still Air 125 ºC 3.2 x 5 mm, 6-pin DFN 2.5 x 3.2 mm, 6-pin DFN Table 2.5. Absolute Maximum Ratings1 Parameter Symbol Rating Unit TAMAX 105 ºC TS -55 to 125 ºC Supply Voltage VDD -0.5 to 3.8 V Input Voltage VIN -0.5 to VDD + 0.3 V ESD HBM (JESD22-A114) HBM 4.0 kV Solder Temperature2 TPEAK 260 ºC Solder Time at TPEAK2 TP 20 - 40 sec Maximum Operating Temp. Storage Temperature Notes: 1. Stresses beyond those listed in this table may cause permanent damage to the device. Functional operation specification compliance is not implied at these conditions. Exposure to maximum rating conditions for extended periods may affect device reliability. 2. For VDD = 1.8V only; otherwise 85ºC. 3. The device is compliant with JEDEC J-STD-020. aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 6 AS5002 Datasheet 3. CMOS Buffer and Output Terminations Dual CMOS output format ordering options support either complementary or in-phase signals for two identical frequency outputs. This feature enables replacement of multiple XOs with a single AS5001 device. Figure Error! No text of specified style in document..1: Integrated 1:2 CMOS Buffer Supports In-Phase or Complementary Outputs AS50xx AS50xx VDD VDD CLK+ CLK CLK- CMOS Receiver NC CMOS Receiver Single CMOS Termination Dual CMOS Termination Figure Error! No text of specified style in document..2: CMOS Output Terminations aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 7 AS5002 Datasheet 4. Recommended Output Terminations The output drivers support AC-coupled or DC-coupled terminations as shown in figures below. AS50xx AS50xx VDD (3.3V, 2.5V) VDD (3.3V, 2.5V) VDD (3.3V, 2.5V) VDD (3.3V, 2.5V) R1 CLK+ 0.1 µF CLK- 0.1 µF R1 R1 R2 R2 CLK- R2 R2 LVPECL Receiver AC-Coupled LVPECL – Thevenin Termination LVPECL Receiver DC-Coupled LVPECL – 50 Ω w/ VTT Bias AS50xx AS50xx VDD (3.3V, 2.5V) VDD (3.3V, 2.5V) CLK+ VDD CLK- R1 CLK+ R1 CLK+ 0.1 µF VDD R2 CLK- 0.1 µF R1 R2 LVPECL Receiver LVPECL Receiver DC-Coupled LVPECL – Thevenin Termination AC-Coupled LVPECL – 50 Ω w/ VTT Bias Termination Resistor Values VDD 3.3 V 127 R1 82 5 R2 2.5 V 250 62 5 Figure 4.1. LVPECL Output Terminations aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 8 AS5002 Datasheet DC-Coupled LVDS AC-Coupled CML Figure Error! No text of specified style in document..3: LVDS / CML Output Terminations AS50xx AS50xx VDD VDD CLK+ CLK+ CLK- CLKHCSL Receiver HCSL Receiver Source Terminated HCSL Destination Terminated HCSL Figure Error! No text of specified style in document..4: HCSL Output Terminations aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 9 AS5002 Datasheet 5. Package Outline 5.1 Package Outline (3.2 x 5 mm) The figure below illustrates the package details for the 3.2 x 5 mm AS5002. The table below lists the values for the dimensions shown in the illustration. Figure 5.1. AS5002 (3.2 x 5 mm) Outline Diagram Table 5.1. Package Diagram Dimensions (mm) Dimension Min Nom Max A 0.8 0.85 0.9 A1 0 0.035 0.05 A2 -- 0.65 -- A3 b 0.203 REF 0.59 0.64 D 3.2 BSC E 4 BSC e 1.27 BSC L 0.7 0.75 L1 0.85 REF aaa 0.1 bbb 0.1 ccc 0.08 ddd 0.1 0.69 0.8 Notes: 1. All dimensions shown are in millimeters (mm) unless otherwise noted. 2. Dimensioning and Tolerancing per ANSI Y14.5M-1994. aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 10 AS5002 Datasheet 5.2 Package Outline (2.5 x 3.2 mm) The figure below illustrates the package details for the 3.2 x 2.5 mm AS5002. The table below lists the values for the dimensions shown in the illustration. Figure 5.2. AS5002 (2.5 x 3.2 mm) Outline Diagram Table 5.2. Package Diagram Dimensions (mm) Dimension Min Nom Max A 0.8 0.85 0.9 A1 0 0.035 0.05 A2 --- 0.65 --- A3 0.203 REF b 0.85 0.9 0.95 b1 0.45 0.5 0.55 D 2.5 BSC E 3.2 BSC e 1.05 BSC L 0.65 0.7 aaa 0.1 bbb 0.1 ccc 0.08 ddd 0.1 0.75 Notes: 1. The dimensions in parentheses are reference. 2. All dimensions in millimeters (mm). 3. Dimensioning and Tolerancing per ANSI Y14.5M-1994. aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 11 AS5002 Datasheet 6. PCB Land Pattern (3.2 x 5 mm and 2.5 x 3.2 mm) The figure below illustrates the 3.2 x 5 mm PCB land pattern for the AS5002. The table below lists the values for the dimensions shown in the illustration. Figure 6.1. AS5002 (3.2 x 5 mm and 2.5 x 3.2 mm) PCB Land Pattern Table 6.1. PCB Land Pattern Dimensions (mm) Dimension Description 3.2 x 5 mm Package 2.5 x 3.2 mm Package Value (mm) Value (mm) X1 Width - leads on long sides 0.75 0.7 Y1 Height - leads on long sides 0.64 0.9, 0.5 D1 Pitch in X directions of XLY1 leads 2.25 1.6 E1 Lead pitch XLY1 leads 1.27 1.05 Notes: The following notes and stencil design are shared as recommendations only. A customer or user may find it necessary to use different parameters and fine-tune their SMT process as required for their application and tooling. General 1. All dimensions shown are in millimeters (mm) unless otherwise noted. 2. Dimensioning and Tolerancing is per the ANSI Y14.5M-1994 specification. 3. This Land Pattern Design is based on the IPC-7351 guidelines. 4. All dimensions shown are at Maximum Material Condition (MMC). Least Material Condition (LMC) is calculated based on a Fabrication Allowance of 0.05 mm. Solder Mask Design 1. All metal pads are to be non-solder mask defined (NSMD). Clearance between the solder mask and the metal pad is to be 60 µm minimum, all the way around the pad. Stencil Design 1. A stainless steel, laser-cut and electro-polished stencil with trapezoidal walls should be used to assure good solder paste release. 2. The stencil thickness should be 0.125 mm (5 mils). 3. The ratio of stencil aperture to land pad size should be 0.8:1 for the pads. Card Assembly 1. A No-Clean, Type-3 solder paste is recommended. 2. The recommended card reflow profile is per the JEDEC/IPC J-STD-020 specification for Small Body Components. aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 12 AS5002 Datasheet 7. Top Marking (3.2 x 5 mm and 2.5 x 3.2 mm) The figure below illustrates the mark specification for the AS5002. The table below lists the line information. AS 5 0 0 2 F F F FF F Y Y W W Figure 7.1. AS5002 Top Mark Table 7.1. AS5002 Top Mark Description Line Position 1 1–6 Description Device Name 2 3 Trace Code 1–6 Field ID (Default = 000000) Position 1 Pin 1 orientation mark (dot) Position 2–3 Year (last two digits of the year), to be assigned by assembly site (ex: 2017 = 17) Position 4–5 Calendar Work Week number (1–53), to be assigned by assembly site aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 13 AS5002 Datasheet 8. Revision History Revision 0.9 Sept 2020 - Initial release aeonsemi.com | Enabling Edge Computing Network Rev. 0.9 | 14
5002DAC148M5000ABI 价格&库存
很抱歉,暂时无法提供与“5002DAC148M5000ABI”相匹配的价格&库存,您可以联系我们找货
