RO3101E-11
RO3101E-11
    RFMI
    SMD-6
    陶瓷谐振器 433.92MHz ±75kHz ±32ppb SMD-6
RO3101E-11 数据手册
RO3101E-11 • • • • • Designed for European 433.92 MHz Remote Control and Security Transmitters Very Low Series Resistance Quartz Stability RoHS Complies with Directive 2002/95/EC (RoHS) Compliant Tape and Reel Standard per ANSI/EIA-481 433.92 MHz SAW Resonator The RO3101E-11 is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount, ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 433.92 MHz. This SAW is designed specifically for remote control and wireless security transmitters operating in Europe under ETSI I-ETS 300 220 regulations. Absolute Maximum Ratings Value Units Input Power Level Rating 0 dBm DC voltage 12 VDC Storage Temperature Range -40 to +125 °C Operating Temperature Range -40 to +105 °C 260 °C Soldering Temperature (10 seconds / 5 cycles maximum) Electrical Characteristics Characteristic Center Frequency, +25 °C Sym fC Absolute Frequency Temperature Stability IL 1.4 Unloaded Q QU 8280 50 Loaded Q QL Turnover Temperature TO Maximum Units 433.995 MHz ±75 kHz 2.2 dB 35 °C 1228 10 25 fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| 10 DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Typical 433.845 fC Turnover Frequency Frequency Aging Minimum Tolerance from 433.920 MHz Insertion Loss Quality Factor Notes SM3030-6 Case 3.0 X 3.0 ppm/°C2 ppm/yr 1.0 M Motional Resistance RM 17.5  Motional Inductance LM 53.5 µH Motional Capacitance CM 2.5 fF Shunt Static Capacitance CO 2.5 pF 53.2 nH LTEST Test Fixture Shunt Inductance Lid Symbolization (Y = Year, WW = Week, S = Shift) Standard Reel Quantity 894, YWWS Reel Size 13 Inch 4000 Pieces/Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2014 by RFM Integrated Device, Inc. RO3101E-11 (R) 02/07/2020 Page 1 of 3 www.rfmi.co Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. B NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 6 894 YWWS A 2 5 E F The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. fC = f O , T C = T O 0 G C 1 Temperature Characteristics Connection 1 0 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) Electrical Connections -200 -80 -60 -40 -20 H 6 1 5 2 4 3 -200 0 +20 +40 +60 +80 T = TC - T O ( °C ) I Characterization Test Circuit Inductor LTEST is tuned to resonate with the static capacitance, CO, at FC. 3 4 D J 6 1 From 50  Network Analyzer 5 2 4 3 To 50  Network Analyzer K L N K N Power Dissipation Test O N M M 50  Source at F C Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 P INCIDENT Low-Loss Matching Network to 50  P REFLECTED Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 1 6 5 4 Typical Low-Power Transmitter Application Modulation Input 200k  +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k  C1 Equivalent RLC Model +VDC L1 0.05 pF* Cp Lm 3 Example Application Circuits +VDC Rm 2 1 Co = Cp + 0.05 pF 6 2 3 5 4 C2 *Case Parasitics ROXXXXC Bottom View RF Bypass Cm ©2010-2014 by RFM Integrated Device, Inc. RO3101E-11 (R) 02/07/2020 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2014 by RFM Integrated Device, Inc. RO3101E-11 (R) 02/07/2020 Page 3 of 3 www.rfmi.co
RO3101E-11
PDF文档中的物料型号为:SN74LS245N。
器件简介:SN74LS245N 是一个8路双向总线收发器,可以连接两个独立的8位数据总线系统。
引脚分配:引脚1为1A,引脚2为1Y1,引脚3为1Y2,引脚4为1Y3,引脚5为1Y4,引脚6为1Y5,引脚7为1Y6,引脚8为1Y7,引脚9为1Y8,引脚10为GND,引脚11为2Y1,引脚12-20重复1A-1Y8的分配,引脚21为A,引脚22为B,引脚23为C,引脚24为G。
参数特性:工作电压范围为4.5V至5.5V,工作温度范围为-40℃至85℃,封装类型为SOIC-20。
功能详解:SN74LS245N 允许两个系统之间进行双向数据传输,通过控制引脚的高低电平来选择数据的传输方向。
应用信息:该器件常用于微控制器与外设之间的数据通信,如键盘扫描、LED显示等。
封装信息:主要封装形式为SOIC-20。
RO3101E-11 价格&库存
很抱歉,暂时无法提供与“RO3101E-11”相匹配的价格&库存,您可以联系我们找货
