RO3075E
RO3075E
    RFMI
    SMD-6
    陶瓷谐振器 ±100kHz 345MHz ±32ppb SMD-6
RO3075E 数据手册
RO3075E • • • • • Ideal for 345 MHz Remote Control and Security Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RoHS Compliant 345.0 MHz SAW Resonator The RO3075E is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 345 MHz. The RO3075E is designed for wireless remote control and security transmitters operating in the USA under FCC Part 15. Absolute Maximum Ratings Rating Value Units Input Power Level 0 dBm SM3030-6 Case DC Voltage 12 VDC Storage Temperature Range -40 to +125 °C 3.0 X 3.0 Operating Temperature Range -40 to +105 °C 260 °C Soldering Temperature (10 seconds / 5 cycles maximum) Electrical Characteristics Characteristic Frequency, +25 °C Sym fC Absolute Frequency Temperature Stability Frequency Aging 1.4 Unloaded Q QU 27000 50 Loaded Q QL 4200 Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| 10 10 25 Maximum Units 345.100 MHz ±100 kHz 2.2 dB 35 °C ppm/°C2 ppm/yr 1.0 M Motional Resistance RM 18  Motional Inductance LM 240 µH Motional Capacitance CM 0.9 fF Shunt Static Capacitance CO 4.3 pF LTEST 50 nH Test Fixture Shunt Inductance 694, YWWS Lid Symbolization Standard Reel Quantity Typical 344.900 IL DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Minimum fC Tolerance from 345.000 MHz Insertion Loss Quality Factor Notes Reel Size 7 Inch 500 Pieces / Reel Reel Size 13 Inch 3000 Pieces / Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2014 by RFM Integrated Device, Inc. RO3075E (R) 09/20/2021 Page 1 of 3 www.rfm.co Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. B NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 6 694 YWWS A 2 5 E F The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. fC = f O , T C = T O 0 G C 1 Temperature Characteristics Connection 1 0 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) Electrical Connections -200 0 +20 +40 +60 +80 -200 -80 -60 -40 -20 H 6 1 5 2 4 3 T = TC - T O ( °C ) I Characterization Test Circuit Inductor LTEST is tuned to resonate with the static capacitance, CO, at FC. 3 4 D J 6 1 From 50  Network Analyzer 5 2 4 3 To 50  Network Analyzer K L N K N Power Dissipation Test O N M M 50  Source at F C Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 P INCIDENT P REFLECTED Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 Low-Loss Matching Network to 50  1 6 5 4 Typical Low-Power Transmitter Application Modulation Input 200k  +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k  C1 +VDC L1 Equivalent RLC Model 0.05 pF* Cp Lm 3 Example Application Circuits +VDC Rm 2 1 Co = Cp + 0.05 pF 6 2 3 5 4 C2 *Case Parasitics ROXXXXC Bottom View RF Bypass Cm ©2010-2014 by RFM Integrated Device, Inc. RO3075E (R) 09/20/2021 Page 2 of 3 www.rfm.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2014 by RFM Integrated Device, Inc. RO3075E (R) 09/20/2021 Page 3 of 3 www.rfm.co
RO3075E 价格&库存
很抱歉,暂时无法提供与“RO3075E”相匹配的价格&库存,您可以联系我们找货
