RO3112E
RO3112E
    RFMI
    SMD-6
    陶瓷谐振器 ±75kHz 433.42MHz ±32ppb SMD-6
RO3112E 数据手册
RO3112E • Designed for European 433.42 MHz Remote Control and Security Transmitters • Very Low Series Resistance • Quartz Stability • • • • RoHS Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 Moisture Sensitivity Level: 1 AEC-Q200 Qualified 433.42 MHz SAW Resonator Compliant The RO3112E is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 433.42 MHz. This SAW is designed specifically for remote control and wireless security transmitters operating in Europe under ETSI I-ETS 300 220. Absolute Maximum Ratings Rating Value Input Power Level 0 dBm DC Voltage 12 VDC Storage Temperature Range -40 to +85 °C Operating Temperature Range -40 to +85 °C 260 °C Soldering Temperature (10 seconds / 5 cycles maximum) SM3030-6 Case 3.0 X 3.0 Units Electrical Characteristics Characteristic Center Frequency, +25 °C Sym Insertion Loss Temperature Stability Frequency Aging Minimum IL 1.2 Unloaded Q QU 8400 50 Loaded Q QL 1000 Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| 10 25 10 DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Typical 433.345 fC Tolerance from 433.42 MHz Quality Factor Notes fC Absolute Frequency 1.0 Maximum Units 433.495 MHz ±75 kHz 2.5 dB 35 °C ppm/°C2 ppm/yr M Motional Resistance RM 14.0  Motional Inductance LM 43.4 µH Motional Capacitance CM 3.3 fF Shunt Static Capacitance CO 3.7 pF LTEST 36.5 nH Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) Standard Reel Quantity 684, YWWS Reel Size 7 Inch 500 Pieces/Reel Reel Size 13 Inch 3000 Pieces/Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. © 2010-2014 by RFM Integrated Device, Inc. RO3112E (R) 12/07/2021 Page 1 of 3 www.rfmi.co Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. B NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 6 684 YWWS A 2 5 E F The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. fC = f O , T C = T O 0 G C 1 Temperature Characteristics Connection 1 0 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) Electrical Connections -200 -80 -60 -40 -20 H 6 1 5 2 4 3 -200 0 +20 +40 +60 +80 T = TC - T O ( °C ) I Characterization Test Circuit Inductor LTEST is tuned to resonate with the static capacitance, CO, at FC. 3 4 D J 6 1 From 50  Network Analyzer 5 2 4 3 To 50  Network Analyzer K L N K N Power Dissipation Test O N M M 50  Source at F C Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 P INCIDENT Low-Loss Matching Network to 50  P REFLECTED Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 1 6 5 4 Typical Low-Power Transmitter Application Modulation Input 200k  +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k  C1 Equivalent RLC Model +VDC L1 0.05 pF* Cp Lm 3 Example Application Circuits +VDC Rm 2 1 Co = Cp + 0.05 pF 6 2 3 5 4 C2 *Case Parasitics ROXXXXC Bottom View RF Bypass Cm © 2010-2014 by RFM Integrated Device, Inc. RO3112E (R) 12/07/2021 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. © 2010-2014 by RFM Integrated Device, Inc. RO3112E (R) 12/07/2021 Page 3 of 3 www.rfmi.co
RO3112E 价格&库存
很抱歉,暂时无法提供与“RO3112E”相匹配的价格&库存,您可以联系我们找货
