RO3101E
RO3101E
    RFMI
    SMD-6
    陶瓷谐振器 433.92MHz ±75kHz ±32ppb SMD-6
RO3101E 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. • • • • • RO3101E Designed for European 433.92 MHz Remote Control and Security Transmitters Very Low Series Resistance Quartz Stability RoHS Complies with Directive 2002/95/EC (RoHS) Compliant Tape and Reel Standard per ANSI/EIA-481 433.92 MHz SAW Resonator The RO3101E is a true one-port, surface acoustic wave (SAW) resonator in a surface mount ceramic case. It provides reliable, fundamental mode, quartz frequency stabilization of fixed frequency transmitters operating at 433.92 MHz. This SAW is designed specifically for remote control and wireless security transmitters operating in Europe ETSI I-ETS 300 200 regulations. Absolute Maximum Ratings Rating Value Input Power Level 0 dBm DC voltage 12 VDC Storage Temperature Range -40 to +125 °C Operating Temperature Range -40 to +105 °C 260 °C Soldering Temperature (10 seconds / 5 cycles maximum) Electrical Characteristics Characteristic Center Frequency, +25 °C Sym Absolute Frequency Temperature Stability Frequency Aging IL 1.4 Unloaded Q QU 8280 50 Loaded Q QL Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| Maximum Units 433.995 MHz ±75 kHz 2.2 dB 35 °C 1228 10 25 10 1.0 ppm/°C2 ppm/yr M Motional Resistance RM 17.5  Motional Inductance LM 53.5 µH Motional Capacitance CM 2.5 fF Shunt Static Capacitance CO 2.5 pF 53.2 nH LTEST Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) Standard Reel Quantity Typical 433.845 fC DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Minimum Tolerance from 433.920 MHz Insertion Loss Quality Factor Notes fC SM3030-6 Case 3.0 X 3.0 Units 701, YWWS Reel Size 7 Inch 500 Pieces/Reel Reel Size 13 Inch 3000 Pieces/Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. Copyright © 2014 by RFM Integrated Device, Inc. RO3101E (R) 06/14/2021 Page 1 of 3 www.rfmi.co Temperature Characteristics Electrical Connections B Pin 1 2 3 4 5 6 NC Terminal NC NC Terminal NC C 701 YWWS A 2 5 E F fC = f O , T C = T O 0 0 G 6 1 The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. Connection -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. -200 -80 -60 -40 -20 H 6 1 5 2 4 3 -200 0 +20 +40 +60 +80 T = T C - T O ( °C ) I Characterization Test Circuit Inductor LTEST is tuned to resonate with the static capacitance, CO, at FC. 4 3 D J 6 1 From 50  Network Analyzer 5 2 4 3 To 50  Network Analyzer K L N K Power Dissipation Test N O N M M 50  Source at F C Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 P INCIDENT Low-Loss Matching Network to 50  P REFLECTED Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 1 6 Modulation Input 4 200k  +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k  C1 +VDC L1 0.05 pF* Cp 1 Co = Cp + 0.05 pF 6 *Case Parasitics ROXXXXC Bottom View 2 3 5 4 C2 RF Bypass Cm Copyright © 2014 by RFM Integrated Device, Inc. RO3101E (R) 06/14/2021 5 Typical Low-Power Transmitter Application Equivalent RLC Model Lm 3 Example Application Circuits +VDC Rm 2 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. Copyright © 2014 by RFM Integrated Device, Inc. RO3101E (R) 06/14/2021 Page 3 of 3 www.rfmi.co
RO3101E 价格&库存
很抱歉,暂时无法提供与“RO3101E”相匹配的价格&库存,您可以联系我们找货
