RO3150E
RO3150E
    RFMI
    SMD-6
    陶瓷谐振器 ±75kHz ±32ppb SMD-6 304MHz
RO3150E 数据手册
RO3150E • • • • • • Designed for Low Power 304 MHz Transmitters Very Low Series Resistance Quartz Frequency Stability Miniature 3.0 x 3.0 mm Surface-mount Case Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RoHS Compliant 304 MHz SAW Resonator The RO3104E is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode quartz frequency stabilization of fixed-frequency transmitters operating at 304 MHz. This SAW is designed specifically for transmitters used in wireless security and remote control applications. Absolute Maximum Ratings Rating Value Units CW RF Power Dissipation (See Typical Test Circuit) 0 dBm DC Voltage Between Terminals (Observe ESD Precautions) 5 VDC -40 to +85 °C +260 °C Case Temperature Maximum Soldering Profile Temperature (10 s, 5 cycles maximum) SM3030-6 Case Electrical Characteristics Characteristic Sym Frequency, +25 °C fC Nominal Frequency Insertion Loss Temperature Stability Frequency Aging Units 303.925 304.000 304.075 MHz ±75 kHz 2.0 dB 40 °C Unloaded Q QU 14,590 50 Ω Loaded Q QL Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| 2,100 10 25 10 1.0 ppm/°C2 ppm/yr MΩ Motional Resistance RM 16 Ω Motional Inductance LM 125 µH Motional Capacitance CM 2.1 fF Transducer Static Capacitance CO 3.8 pF TBD nH LTEST Y - Year, WW = Week, S = Shift Standard Reel Quantity Maximum 1.35 Test Fixture Shunt Inductance Lid Symbolization: Typical IL DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Minimum ΔfC Tolerance from 304.000 MHz Quality Factor Notes 977, YWWS Reel Size 7 Inch 500 Pieces/Reel Reel Size 13 Inch 3000 Pieces/Reel ©2010-2015 by RFM Integrated Device, Inc. RO3150E (R) 09/21/2021 Page 1 of 4 www.rfmi.co CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. B 1 NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 6 A 2 5 3 4 E F The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. fC = f O , T C = T O 0 0 G C 1 Temperature Characteristics Connection -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) Electrical Connections -200 -80 -60 -40 -20 H 6 1 5 2 4 3 -200 0 +20 +40 +60 +80 ΔT = TC - T O ( °C ) I Characterization Test Circuit Inductor LTEST is tuned to resonate with the static capacitance, CO, at FC. D J 6 1 From 50 Ω Network Analyzer 5 2 4 3 To 50 Ω Network Analyzer Power Dissipation Test 50 Ω Source at F C K L P REFLECTED N K P INCIDENT Low-Loss Matching Network to 50 Ω 1 6 2 3 5 4 N O N M M ©2010-2015 by RFM Integrated Device, Inc. RO3150E (R) 09/21/2021 Page 2 of 4 www.rfmi.co Example Application Circuits Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Typical Low-Power Transmitter Application Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 Modulation Input 200k Ω 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k Ω +VDC C1 +VDC L1 1 Equivalent RLC Model 2 3 5 4 C2 ROXXXXC Bottom View 0.05 pF* Cp Lm 47 L1 (Antenna) 6 Rm +9VDC C1 RF Bypass Co = Cp + 0.05 pF *Case Parasitics Cm ©2010-2015 by RFM Integrated Device, Inc. RO3150E (R) 09/21/2021 Page 3 of 4 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2015 by RFM Integrated Device, Inc. RO3150E (R) 09/21/2021 Page 4 of 4 www.rfmi.co
RO3150E 价格&库存
很抱歉,暂时无法提供与“RO3150E”相匹配的价格&库存,您可以联系我们找货
