RO3104E-1
RO3104E-1
    RFMI
    SMD-6
    陶瓷谐振器 303.825MHz ±50kHz ±32ppb SMD-6
RO3104E-1 数据手册
• • • • • • • RO3104E-1 Ideal for 303.825 MHz Remote Control and Security Transmitters RoHS Very Low Series Resistance Quartz Frequency Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 Moisture Sensitivity Level: 1 AEC-Q200 Qualified 303.825 MHz SAW Resonator Compliant The RO3104E-1 is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount, ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 303.825 MHz. This SAW is designed specifically for AM transmitters in wireless security and remote control applications operating in the USA under FCC Part 15, in Australia, in Japan, and in Korea. Absolute Maximum Ratings Rating Value Units CW RF Power Dissipation (See Typical Test Circuit) 0 dBm DC Voltage Between Terminals (Observe ESD Precautions) 12 VDC -40 to +85 °C +260 °C Case Temperature Soldering Temperature Characteristic Frequency (+25 °C) Nominal Frequency Tolerance from 303.825 MHz Sym fC Notes SM3030-6 Case 3.0 X 3.0 Minimum 303.775 Typical fC Insertion Loss IL 1.35 Quality Factor 10000 Temperature Stability Frequency Aging Unloaded Q QU 50 Loaded Q QL Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Units MHz ±50 kHz 2.0 dB 40 °C 1400 10 25 10 1.0 ppm/°C2 ppm/yr M Motional Resistance RM 16  Motional Inductance LM 85 µH Motional Capacitance CM 3.2 fF Transducer Static Capacitance CO 3.2 pF 85 nH LTEST Test Fixture Shunt Inductance Lid Symbolization Standard Reel Quantity Maximum 303.875 761, YWWS Reel Size 7 Inch 500 Pieces/Reel Reel Size 13 Inch 3000 Pieces/Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. © 2007 by RFM Integrated Device, Inc. RO3104E-1 (R) 12/07/2021 Page 1 of 3 www.rfmi.co Electrical Connections Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. Power Test Connection 1 NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 50  Source at F C P INCIDENT Low-Loss Matching Network to 50  P REFLECTED 1 6 2 3 5 4 Typical Application Circuits B C 1 6 2 H 6 Typical Low-Power Transmitter Application 1 Modulation Input 761 YWWS A G 5 3 E 4 F 5 2 4 3 D 200k  +9VDC C1 I 47 L1 (Antenna) 1 6 J 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Case Dimensions Dimension A B C D E F G H I J Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 Output 200k  +VDC mm Nom 3.0 3.0 1.25 0.90 2.80 1.6 0.85 1.5 0.60 1.30 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 C1 +VDC L1 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass Equivalent LC Model 0.05 pF* Typical Test Circuit Co = Cp + 0.05 pF Cp *Case Parasitics The test circuit inductor, LTEST, is tuned to resonate with the static capacitance, CO, at FC. Rm Electrical Test Lm Cm Temperature Characteristics The curve shown on the right accounts for resonator contribution only and does not include LC component temperature contributions. 5 2 0 4 3 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) 1 From 50  Network Analyzer fC = f O , T C = T O 0 6 To 50  Network Analyzer -200 -80 -60 -40 -20 -200 0 +20 +40 +60 +80 T = T C - T O ( °C ) © 2007 by RFM Integrated Device, Inc. RO3104E-1 (R) 12/07/2021 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. © 2007 by RFM Integrated Device, Inc. RO3104E-1 (R) 12/07/2021 Page 3 of 3 www.rfmi.co
RO3104E-1
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电晶体管开关,具有高输入阻抗和低输出阻抗,适用于高速光耦应用。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括工作温度范围-40~85℃,输入电流1mA,输出电流50mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用6引脚DIP封装。
RO3104E-1 价格&库存
很抱歉,暂时无法提供与“RO3104E-1”相匹配的价格&库存,您可以联系我们找货
